layout:
‘hcl’
type:
‘motherboard’
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
‘2.0’
remap:
‘yes’
brand: |
ASUS
model: |
Pro WS WRX90E-SAGE SE
bios: |
1203
cpu: |
AMD Ryzen Threadripper PRO 7965WX 24-Cores
cpu-short: |
chipset: |
Advanced Micro Devices, Inc. \[AMD\] Genoa/Bergamo Root Complex \[1022:14a4\] (rev 01)
chipset-short: |
AMD WRX90
gpu: |
NVIDIA Corporation AD102 \[GeForce RTX 4090\] \[10de:2684\] (rev a1) (prog-if 00 \[VGA controller\])
Advanced Micro Devices, Inc. \[AMD/ATI\] Navi 48 \[Radeon RX 9070/9070 XT/9070 GRE\] \[1002:7550\] (rev c0) (prog-if 00 \[VGA controller\])
gpu-short: |
GeForce RTX 4090
GeForce RTX 4090
Radeon RX 9070 XT
network: |
Intel Corporation Ethernet Controller X710 for 10GBASE-T \[8086:15ff\] (rev 02)
memory: |
261635
scsi: |
nvme: |
KINGSTON SFYRD2000G EIFK51.2
usb: |
7
certified:
‘no’
versions:
- works:
‘partial’
qubes: |
R4.3.1
xen: |
4.19.5
kernel: |
6.18.35-1
remark: |
FIXME
credit: |
Anonymous
link: |
FIXLINK
Remarks
Qubes OS installs, boots, and operates successfully on this motherboard. The Radeon RX 9070 XT is used by dom0. Both GeForce RTX 4090 GPUs have been successfully assigned to HVMs for headless operation and for direct display output through monitors connected to the assigned GPUs.
The following dual-GPU configurations were successfully tested:
- Both RTX 4090 GPUs assigned to one headless HVM.
- Both RTX 4090 GPUs assigned to one display-attached HVM.
- One RTX 4090 assigned to each of two simultaneous headless HVMs.
- One RTX 4090 assigned to each of two simultaneous display-attached HVMs.
- One headless HVM and one display-attached HVM, each assigned one RTX 4090, with both GPU-to-HVM assignment permutations tested.
An onboard AMD USB controller at 0000:8d:00.0 can be assigned successfully to sys-usb or directly to an HVM. A keyboard and mouse connected through this controller work in the HVM.
Hiding the onboard AMD USB controller at 0000:e6:00.4 using rd.qubes.hide_pci causes storage enumeration to fail during early boot and prevents the encrypted root volume from being opened. This controller must therefore remain assigned to dom0.
Suspend and resume have not been tested.
