Asus N751JX
layout:
‘hcl’
type:
‘notebook’
hvm:
‘yes’
iommu:
‘yes’
slat:
‘yes’
tpm:
‘unknown’
remap:
‘yes’
brand: |
ASUSTeK COMPUTER INC.
model: |
N751JX
bios: |
N751JX.211
cpu: |
Intel(R) Core™ i7-4750HQ CPU @ 2.00GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Crystal Well DRAM Controller [8086:0d04] (rev 08)
chipset-short: |
FIXME
gpu: |
Intel Corporation Crystal Well Integrated Graphics Controller [8086:0d26] (rev 08) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Wireless 7260 (rev bb)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
memory: |
11985
scsi: |
DVDRAM GUC0N Rev: AS01
Samsung SSD 860 Rev: 2B6Q
HGST HTS721010A9 Rev: A3J0
usb: |
3
versions:
  • works:
    ‘FIXME:yes|no|partial’
    qubes: |
    R4.1
    xen: |
    4.14.5
    kernel: |
    5.15.52-1
    remark: |
    FIXME
    credit: |
    FIXAUTHOR
    link: |
    FIXLINK
I can’t upload HCL Info .yml and GZ or the HCL Support Files .cpio.gz files because of my account/new membership limitations. so …
Qubes-HCL-ASUSTeK_COMPUTER_INC_-N550JK-20180911-131707.yml (908 Bytes)
Thank you @bloeblah for your HCL report, which is online now.
You didn’t indicate any problems, so am I correct in assuming everything works?
At first glance it does. Some considerations
  • first off secure boot must be off and i had PCI troubleshooting | Qubes OS this issue.
    -I’m further testing it all. I’m a bit time constraint. I should compare it with a faster and newer device because some things work but so slow or take so much time to start. I don’t know if it’s a device thing or general issue.
  • The PCI “Unable to reset PCI device” errors is easy to solve if you have that issue for me it was 0000:04:00.1 see PCI troubleshooting | Qubes OS
  • all USB devices work
    -NVIDIA GPU works
    -OpenVPN works
