Asus gl552vw
Installation
I had to reinstall Qubes 4.2 about 3 times. It appears to be error user and it booted up fine on the third attempt. The only thing I had to do was remove a PCI error I was getting and that was easy to fix. It was an Realtek Ethernet PCI that I had to disable under sys-net.
Basic Input
  • Keyboard input works
  • Touch-pad works
  • Touch-pad supports “tap as click” and scrolling with 2 fingers works
  • Display brightness change shortcuts does not work for me.
Internet and bluetooth
  • Wi-fi internet works after fixing PCI error
  • Sound / audio works via USB Bluetooth headset
Personal Experiences:
  • Creating/deleting/renaming/managing/using Qubes works fine
  • Installation worked after a 3rd attempt (User error)
  • Login screen and logging on has no issues
  • YouTube runs smoothly
Qubes-HCL-ASUSTeK_COMPUTER_INC_-GL552VW-20240703-141842.yml (1.0 KB)
