ASRock B450M Pro4 + AMD Ryzen 7 1700 + amdgpu
Remarks
Many trials trying to get the suspend/resume working, ever since version 4.0, with zero success up to now.
Finally, the setup/settings detailed below seem to fix it, at least for a single monitor connected via SVGA.
Qubes freshly installed from qubes 4.1.1 iso.
BIOS
BIOS is restricted to 3.50 and below, because of the Summit Ridge series Processor.
Bios settings:
  • Setting 1: Advanced / CPU configuration / SVM mode → enabled
  • Setting 2: Advanced / Onboard Devices configuration / SR-IOV support → enabled
  • Setting 3: Advanced / AMD CBS /NBIO common options / IOMMU —> enabled
  • Setting 4: Advanced / AMD CBS /NBIO common options / PCIe ARI support → Auto (removes some corrupted pixels which appear on the top panel.
As installed, suspend/resume of Qubes causes hard lockup of display and sometimes reboot. lsmod shows both radeon and amdgpu in use.
Modules/parameters
Create /etc/modprobe.d/radeon-amdgpu.conf and add:
  blacklist radeon
  options amdgpu si_support=1
  options amdgpu cik_support=1
Update initrd (I think this is necessary):
  sudo dracut --force
Up to now, changes mean we can boot with only amdgpu module, and no radeon.
Command line parameters
Also, edit /etc/default/grub, and add “mem_sleep_default=deep” to the end of GRUB_CMDLINE_LINUX, and update grub. For me, the command was :
sudo grub2-mkconfig -o /boot/efi/EFI/qubes/grub.cfg
(Not sure that this command line option is necessary.)
xorg amdgpu driver
Install the amdgpu xorg driver:
  qubes-dom0-update xorg-x11-drv-amdgpu
This is version 22.0.0-2.fc32.
Driver option: create /etc/X11/xorg.conf.d/50-amdgpu.conf :
  Section "Device"
    	Identifier "card0"
    	Driver "amdgpu"
    	Option "AccelMethod" "none"
  EndSection
Not sure what that does - the ‘amdgpu’ man page says it only turns off 2D acceleration. glxgears looks OK, and the option seems to be necessary for resume to work.
Now suspend/resume seems to work. At least, over 100 cycles without problems…
  • Tested/working: Network, SATA, USB…
  • Not tested: audio, non-svga video outputs, instrumentation/sensors, fTPM.
  • Am crossing fingers!
layout:
  'hcl'
type:
  'desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  ASRock
model: |
  B450M Pro4
bios: |
  P3.50
cpu: |
  AMD Ryzen 7 1700 Eight-Core Processor
cpu-short: |
  FIXME
chipset: |
  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex [1022:1450]
chipset-short: |
  FIXME
gpu: |
  Advanced Micro Devices, Inc. [AMD/ATI] Oland PRO [Radeon R7 240/340] [1002:6613] (rev 87) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
memory: |
  32699
scsi: |
  CT4000MX500SSD1  Rev: 045
  CT2000MX500SSD1  Rev: 033
  iHAS124   F      Rev: CL9M
  CT1000X8SSD9     Rev: PMAP
  STORE N GO       Rev: 0000
usb: |
  2
versions:
- works:
    'yes'
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    5.15.81-1
  remark: |
  credit: |
    CharlieC
  link: |
    FIXLINK
Thank you @phceac for your HCL report, which is online now!
