Older Qubes is not supported, but new has a bug that stops me from starting it on my new laptop.
Are there chances on fixing issue 11039 this year? Generally, I want Qubes be my third boot OS to use it as a member of test team.
It is possible to workaround the bug by temporary moving files of other OSes from efi partition and later getting them back. But if there’re chances to have that fixed in nearest month or two I’d better wait.
If the plan is for example the february or march or so, then I’d try a workaround.
BTW: The installer is not quite handy for those who wanna prepare install, look what installer prepared and change it on the fly. Minimalism works well for those who set things as a single boot Qubes OS.
Link for the bug in installer that stops me from testing new Qubes:
I tried to instal Qubes OS by choosing ‘custom’ for initialization of the drive. I chose to delete EFI-volume, MSR-volume, “BitLocker”-volume and the main volume, then used automatic configuration. I made sure the button for disk encryption was checked. I continued the procedure. The installation failed.
I reinstalled Windows11. This time I did not find “BitLocker”-volume. I tried installation in the same way and failed again.
(The reason, I did not choose to erase the entire disk was a volume, which I suspect to contain recovery data of OEM.)
I used linux live-USB for initializing the built-in drive. (I lost the OEM-data.)
I suspect the EFI-volume was encrypted by Microsoft and the installer of Qubes OS could not manipulate it. In a series of trials, the PC became not bootable. I experienced it several times. I verified Windows related volumes were left. So, I believe the installer destroyed the EFI-volume.
I want the installer to have the option of
adding a dedicated EFI-volume, preserving the other EFI-volumes untouched.
For reinstallation, I want the option of
choosing an EFI-volume,
and resizing the EFI-volume.
I believe these options will solve the issue and enable multiboot and also preservation of some particular volumes.
And yes, I would be happy to see the option of
installing and booting Qubes OS under SecureBoot enabled.
