i installed the template and created an app vm, it doesn’t open at all, i installed it through the ui of the qubes os which allows installing templates
Doesn’t update through the ui either, of qubes os
Qubes os 4.2 R4.2
Qubes os 4.2 R4.2
I use AppVMs from the archlinux template.
From Qubes Template Manager (i.e. : qvm-template-gui) ?
[user@dom0 ~]$ qvm-template list
Installed Templates
archlinux 0:4.2.0-202309141139 qubes-templates-community
In Qubes-OS 4.2, you update the archlinux template from the template it self because it fails from Qubes OS Update. You open a root terminal for the template:
[user@dom0 ~]$ qvm-run --user root archlinux xterm
and run the ArchLinux OS update:
[root@archlinux ~]# pacman -Syu
Try the above template update, then retry the AppVM. If it failed, explore the below different ways, try to understand and give us the error messges or logs:
test-archlinux):[user@dom0 ~]$ qvm-run test-archlinux xterm
Running 'xterm' on test-archlinux
