Arch Linux Template
Getting an error message when trying to install the Arch Linux Template
Curl Error 6 couldn’t resolve host name for https://mirrors.fedoraproject.org/metalink?repo=f
dns resolution likely a transitory network condition, particularly if
you use Tor
The network VM is not using Tor, it’s using the default sys-firewall
2 posts were split to a new topic: Error updating fedora-32-minimal: cannot import name "_supported_dists’
i was not using tor
Same problem. I was going to ask it here. On the first try I was using a Whonix gateway VM, as netVM, but it didn’t work with sys-firewall ether
