Thanks for your answer, if the bug is in the make qubes-vm point, and tried to introduce the following command make vmm-xen-vm and the answer is the same. I have plenty of disk space. I use Qube OS 4.0.4 and appVM Builder is Fedora 34, from the other questions I can’t tell you because I don’t know where to look. I’m new to the system.
The build log file name is available on the start of the build:
-> Building vmm-xen (archlinux) for archlinux vm (logfile: build-logs/vmm-xen-vm-archlinux.log)
Check-it.
If you see the sudo: effective uid is not 0, is /usr/sbin/sudo on a file system with the 'nosuid' option set or an NFS file system without root privileges? message then check the sudo: effective uid is not
0 section of the build guide, then make remount and make vmm-xen-vm .
I checked [1], it works for me with the above fix.
[1] Note that I use Qubes-OS 4.1, the other is same as you.
I cannot pass the step 4 of the guide (make qubes-vm)
Qubes 4.1.1, buider VM Fedora-36
builder.conf made with setup script (same values as dislayed in the guide, except Qubes version). Tried both minimal and “full” Arch distribution, same result
I have the same problem and can’ t find any answer in the forums.
make vmm-xen-vm fails to build:
umount: /home/user/qubes-builder/cache/archlinux/bootstrap/mnt: no mount point specified.
make[1]: *** [/home/user/qubes-builder/qubes-src/builder-archlinux/Makefile.archlinux:88: /home/user/qubes-builder/chroot-vm-archlinux/home/user/.prepared_base] Error 1
make: *** [Makefile:265: vmm-xen-vm] Error 1
I use xen 4.14.5 and a fedora 36 template with plenty of free space as well following the archlinux guide in the documentation. Would love to paste some logfile here but my $HOME/qubes-builder/build-logs only has .gitignore in it.
Maybe I can look for something else? If anyone could point me in the right direction, I would be most gratefull.
@sodomak@snot1 This issue has already been reported, and there’s a PR waiting to be merged, however you can easily fix it yourself by modifying the file that was updated in the PR.
