I’m trying to set up a cacher using this guide: shaker/cacher at main · unman/shaker · GitHub. I’m confused about whether to set the netvm to a VPN or sys-whonix. For those who have used the cacher, what do you recommend for the netvm?
Thanks!
Thanks!
Hi. You can set the netvm to whatever best suits your use case.
I dont use whonix, but I do route traffic over Tor.
The choice is entirely up to you.
Hello,
Thank you for your response.
Do you have Tor running within the cacher, or is sys-whonix the only netvm you are using?
I came across this discussion: sys-cacher questions · Issue #122 · ben-grande/qusal · GitHub, where @ben-grade recommended against using sys-whonix as a netvm or running Tor inside it. What do you think?
I’m not a believer in mixing up things, so I wouldn’t run Tor in a cacher
qube.
I dont use Whonix, but I do run Tor proxies.
I place cacher downstream from a Tor proxy.
I dont see why you wouldn’t place cacher downstream from sys-whonix. This
looks wrong to me.
You can no longer run Tor over Tor, so you cant have any repo definitions
that use tor+https - you’d need to amend them just like you amend any
definitions that use https://.
Something like this would work in these cases:
sed -i s^tor+https://^http://HTTPS///^ REPO_DEFINITION
or
sed -i s^tor+http://^http://^ REPO_DEFINITION
Placing the caching proxy depends entirely on your needs.
Need to use Tor? Set the netvm as sys-whonix.
Need to use a VPN? Set the netvm to the VPN proxy.
Need both? i think you’ll see where this is going.
Need neither? Just set netvm as sys-firewall.
Hi @unman
I’ve successfully set up the cacher, and everything is functioning properly. However, I’m getting an error with the Fedora 41 templates. I tried to remove them from the cacher, but the error persists.
>>> Curl error (56): Failure when receiving data from the peer for https://codecs.fedoraproject.org/openh264/41/x86_64/os/repodata/repomd.xml
Solved by changing the fedora-cisco-openh264.repo to
baseurl=http://HTTPS///codecs.fedoraproject.org/openh264/41/x86_64/os/
I wrote a guide explaining how to use a reverse proxy to cache flatpak updates, it could easily be adapted to qubes os
Did not know setting up an update cache is this easy. Would be awesome if you could adapt it to Qubes
I’ve ran this command
flatpak remote-modify flathub --url=http://my-cache.local:8082/repo/`
When I try to install a package, I get a 403 error, which is weird. I thought it was tor, but it was working fine without a cacher so I’m a bit lost can’t find anything on the internet too…
