I currently use syncthing and veracrypt in same AppVM,
When I try to sync folders in veracrypt-mounted external HDD, the AppVM unexpectedly harts, and I don’t know exact reason why.
I guess there are reasons:
- lack of memory.
- Veracrypt bugs.
2-1. When system try to access a damaged portion of the volume(if volume is somewhere damaged), then it could halt, but it’s mysterious why the VM itself shuts down? - other reasons…
I think the second issue is the most suspicious, because file copy/move without syncthing also makes the same issue. But I’m not sure because just viewing the file in the mounted disk doesn’t cause the halting.
In addition, using a veracrypt with same external disk in windows qubes doesn’t cause the sudden stop without any warning.
I feel uncomfortable about this because the encrypted external HDD may be damaged by this force stop.
Could someone help me? Any ideas? Furthermore, are there a way to analyze the exact reason why AppVM is suddenly turned off?
I’m going to check logfile tonight. For that, How to save logs
EDIT
Here is the log file :
guest-temp-ss.log (154.3 KB)
