AppVM repeatedly freezing, how to troubleshoot?
I’ve tried increasing the allocated RAM and CPU, but continues to freeze.
after re-starting it I don’t see much here:
comp$ sudo tail -50 /var/log/messages
Nov 8 :53:56 localhost rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="526" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
Nov 8 :53:56 localhost kernel: [ 8.612111] hid-generic 0005:F055:F1D0.0001: hidraw0: BLUETOOTH HID v10205.ff Device [Qubes OS U2F proxy to sys-usb] on
Nov 8 :53:56 localhost kernel: [ 9.024625] fbcon: Taking over console
Nov 08 13:53:51 localhost kernel: ACPI Error: No handler or method for GPE 03, disabling event (20180810/evgpe-841)
Nov 08 13:53:51 localhost kernel: ACPI Error: No handler or method for GPE 01, disabling event (20180810/evgpe-841)
Nov 08 13:53:51 localhost kernel: ACPI Error: No handler or method for GPE 00, disabling event (20180810/evgpe-841)
Nov 08 13:53:51 localhost kernel: ACPI: Enabled 1 GPEs in block 00 to 0F
Nov 08 13:53:51 localhost kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Nov 08 13:53:51 localhost kernel: ACPI: Using platform specific model for interrupt routing
Nov 08 13:53:51 localhost kernel: ACPI: (supports S0)
Nov 08 13:53:51 localhost kernel: ACPI: Interpreter enabled
Nov 08 13:53:51 localhost kernel: ACPI: SCI (ACPI GSI 9) not registered
Nov 08 13:53:51 localhost kernel: ACPI: 1 ACPI AML tables successfully acquired and loaded
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(Linux-Dell-Video)
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(Processor Aggregator Device)
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(Processor Device)
Nov 08 13:53:51 localhost kernel: ACPI: Added _OSI(Module Device)
Nov 08 13:53:51 localhost kernel: cryptd: max_cpu_qlen set to 1000
Nov 08 13:53:51 localhost kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Nov 08 13:53:51 localhost kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Nov 08 13:53:51 localhost kernel: PCI: Fatal: No config space access function found
Nov 08 13:53:51 localhost kernel: ACPI: bus type PCI registered
Nov 08 13:53:57 computing5 pulseaudio[852]: source cork req state =1, now state=-2
Nov 08 13:53:57 computing5 pulseaudio[852]: sink cork req state =1, now state=-2
Nov 08 13:53:57 computing5 pulseaudio[852]: rec libvchan_fd_for_select=23, ctrl=0x5fd497075510
Nov 08 13:53:57 computing5 pulseaudio[852]: play libvchan_fd_for_select=19, ctrl=0x5fd497075370
Nov 08 13:53:57 computing5 pulseaudio[852]: using domid: 0
Nov 08 13:53:57 computing5 pulseaudio[852]: vchan module loading
most are colored red above
dom0$ qvm-prefs comp
autostart D False
backup_timestamp - 15993
debug D False
default_dispvm - None
default_user D user
gateway D
gateway6 D
include_in_backups D True
installed_by_rpm D False
ip D 10.137.
ip6 D
kernel D 4.19.152-1
kernelopts D nopat
klass D AppVM
label - yellow
mac D 00:16:3
management_dispvm D default-mgmt-dvm
maxmem - 5000
memory - 500
name - comp
netvm - sys-firewall
provides_network - False
qid - 46
qrexec_timeout D 60
shutdown_timeout D 60
start_time D 1604879625.2
stubdom_mem U
stubdom_xid D -1
template - debian-10
template_for_dispvms D False
updateable D False
uuid - cefad713-90
vcpus D 2
virt_mode D pvh
visible_gateway D 10.137.
visible_gateway6 D
visible_ip D 10.137.
visible_ip6 D
visible_netmask D 255.255.255.255
xid D 43
