Hello all,
I’ve got a ParrotOS AppVM that connects to a ProxyVM for HTB that acts as the OpenVPN tunnel that is needed. This all worked fine up until now.
In my ProxyVM I can ping both machines inside the VPN and google.com fine. Same goes for AppVM ping works fine.
Now when I use curl for google.com in the ProxyVM it responds as expected with some HTML contents.
This fails inside the AppVM:
curl: (7) Failed to connect to google.com port 80 after 13 ms: No route to host
Therefor Firefox is not working inside the AppVM…
I’ve restarted both machines, but that didn’t help.
Greetings,
Bloged
