Application missing on freshly installed Qubes OS 4.1.2
Just installed a fresh copy of Qubes OS 4.1.2.
Facing following problems:
  1. Application missing in templates.
  2. Unable to open application from others’ Qubes (Personal, Vault, Untrusted, Fedora and Debian)
Can’t do a thing…!
The refresh button under Qubes Settings > Applications should reset these for you. If the button is still greyed out for some reason, try:
qvm-scan-appmenus <vmname>
You can find more information in the Qubes documentation:
I am having the same issue. Did you figure out how to solve it?
Did you try @ephile’s suggestion?
I tried qvm-sync-appmenus sys-usb. I get the error “Appmenus can be retrieved only from running VM.”
When I try to start sys-usb, I get the error: "has failed to start internal error: libxenlight has filed to create new domain ‘sys-usb’, see /var/log/libvirt/libxl/libxl-driver.log for details’
When I open that file, I these lines (among others):
libxl: libxl_dm.c:2857:stubdom_xswait_cb:domain 5:Stubdom 6 for 5 startup: startup timed out.
libxl_create.c:1975:domcreate_devmodel_started: Domain 5:device model did not start: -9
I should note that I ripped the wifi card out of my laptop because I want to use this as an air-gapped computer.
I should also note that NONE of the Qubes are usable except for Dom0.
Maybe you had some issue during installation.
Reinstalling Qubes OS helped in similar case:
Try to install Qubes OS 4.2.2-rc1. Maybe you can also install it with kernel-latest option so you can test the latest kernel if the issue persists with stable kernel after reinstall.
