Apparmor profiles for docker containers available need tester
I’ve made a apparmor profiles for the docker container "searxng " it works really great for me i’d like people test it to see if you have some issue with it or not
  1. To use it go take the file at my repo Cigarettes through the window of a quart, and there’s. (? why my link have this name wtf?)
  2. Take the profile for “docker” and go to “containers” and take “docker-searxng”
  3. Place them sudo mv docker /etc/apparmor.d/ && sudo mv docker-searxng /etc/apparmor.d/ && sudo aa-enforce /etc/apparmor.d/docker && sudo aa-enforce /etc/apparmor.d/docker-searxng
  4. If u have a error protocol complaining run the aa-enforce command again it’s a bug i opened a issue about that in the gitlab of apparmor Apparmor 4.1.0-1 in Qubes OS Profile does not conform to protocol error (#592) · Issues · AppArmor / apparmor · GitLab
  5. Then go into your dispvm or appvm or whatever and run this command
docker run --security-opt apparmor=docker-searxng -p 80:8080 -d --name apparmor-docker-searxng searxng/searxng
  1. You can replace the port with the port you would like to use
  2. As sudo do aa-status you must see something like this
Tell me if it worked for you it was really hard to create this apparmor profiles because the official documentation AppArmor security profiles for Docker | Docker Docs do not explain how to create apparmor profiles for docker containers… i spend like 2 hours to learn how to do that
Test: Cigarettes through the window of a quart, and there’s.
Test: Were yells of all the.
Test: The stricken elbow with his eyes he barely moved. One thing.
Maybe it’s an anti-scraping prophylactic that Codeberg has implemented? Something to confuse AIs?
I searched on the web and i didn’t find a single post or annoucement from them it’s annoying but maybe you’re right
I think it’s because of the “anti AI” proxy that will give this kind of random information when the Discourse server queries for the open graph protocol metadata to update the link title.
I can’t do nothing about it so?
Sorry, but I’ll have to cut the discussion short. This is a Qubes forum and the content is unrelated. I’ll close off soon. Feel free to continue in DMs.
This topic was automatically closed after 4 hours. New replies are no longer allowed.
