I tested to load every profile in my repository in the Qubes kernel by doing apparmor_parser -r see and it works great without any issue at this time.
But… i’d ike to know something what exactly could happen if Qubes update the Qubes kernel for the vm ? Do the qubes kernel update will remove the profile inside the current debian-13 kernel ? It’s unclear to me if a qubes kernel update will break the vm or not and in this case i must find something to do about that
The only way to find out is by testing. The only way to find out is by testing. Think like a QA person, do the “negative tests” and “positive tests” (in QA terminology) that come to your mind.
Some users have a “non stock” kernel configuration and run kernels built when kernel patches are released (probably not built on the same machine that Qubes runs on). Users that have this usually don’t run the same kernel for each qube or dom0.
Thanks for the idea i switched the current kernel from the vm to a old qubes kernel version and it works completely fine the apparmor profile is still loaded in the kernel. But i don’t understand how is it possible i need to talk with apparmor specialist or Qubes dev about that but this scenario was not really what i wanted i will install a kernel in dom0 and see what happens for my vm
Run zcat /proc/config.gz > kernelconfig.txt on each kernel and compare the output.
Sounds like you haven’t run cd /usr/src/linux && make menuconfig before. This is part of the Gentoo Handbook.
If you are already this involved with AppArmor that you take note of what Linux kernels have configurations tha line up with what you are trying to do with AppArmer, you are prepared to get your feet wet with the Linux process.
I’ve made multiples test so if dom0 update the kernel the apparmor profile loaded inside the debian template kernel do not disappears , it doesn’t break the template , it doesn’t break the appvm and dispvm there is no issue at all. When dom0 update the kernel somehow every profiles “rotate” to the new kernel. I thought a kernel update from dom0 could “erase” the custom profile from users but it doesn’t in (4.3) maybe in the future it will…
Also cloning the template with apparmor profile loaded in the kernel don’t create any issue the profile is still enforced the vm.
And i tried to switch a appvm with sercurity=apparmor to a fedora vm with security=selinux and both works without any issue
Please share the scripts you wrote to run these tests or apply the relevant settings in the qubes and in dom0. If we can see the commands you are running and perhaps the small tools that run through a checklist that can spur more discussion on the topic.
