To use these commands you will need to have imported the key in to
gpg.
gpg --import RPM-GPG-KEY-unman
This isn’t stated on that tasks page - it should be. I’ll fix this.
As you do this in the disposable, there wont be any problem.
apt list --installed | grep mullvad in the dispvm only shows mullvad-vpn, no browser, presumably because I’m not able to run start-mullvad-browser. In dom0, I see that I have the tar file downloaded for version 13.0.10 and located in /srv/salt/mullvad/. The current version available at mullvad.net is 13.0.13.
There were no issues on install. Only one thing caught my eye right after install. The icon for Mullvad Browser in the start menu is the icon for the qube itself.
I also just tried chmod +x start-mullvad-browser.desktop in the dispvm. Which gave me the following error after ./start-mullvad-browser.desktop:
/usr/bin/env: './Browser/execdesktop': No such file or directory
The directory /home/user/mullvad-browser/ doesn’t exist either…
Seems like the browser is never extracted. /srv/salt/mullvad/browser.sls refers to the location of the tar file as /etc/skel/Downloads/, which is does not exist on my device. It’s instead located in /srv/salt/mullvad/, as noted above. Also looks like there might be a typo in this salt file: “mullvad_browser” instead of “mullvad-browser” in the name of the tar file.
Also:
Launching Mullvad Browser from mullvad-dvm → dispVM launches → enter account number in app → update required on Browser → download and restart Browser → qube shutdown, does not restart.
Update in template, all good. Stupid of me. (Update Mullvad extension too). Still manual re-entry of account number, still creation of new device on Mullvad app (that will have to be deleted later). Are my expectations simply too high?
Qubes question: Surprised actually that the template has what seems to be full access to the web. I thought templates were special and restricted? Is that different here in this setup specifically or is that because its a named dvm template?
I don’t meant to be ungrateful, by the way. I’m documenting this to contribute to improvements (I can’t write code).
You havent yet told me what version of the 3isec package you have installed.
I cant replicate your inability to run the browser.
Can you confirm that you have the Mullvad browser installed in the
disposable template?
This is expected. As it’s a disposable, it cant be restarted. It
disappears when it shuts down.
Feedback and issues are great contributions. Thanks.
I never presume to speak for the Qubes team. When I comment in the Forum I speak for myself.Here’s notes for future readers and some questions:
- Update by Qubes Updater immediately post-install
for mullvad-dvm disposable
- Update browser in
mullvad-dvmtemplate. Update Mullvad extension too. - Account number and settings (<- ?) will not be recalled for each instance of
mullvad-dvmdispVM.
Each login creates a new device on your Mullvad account. They build up, so they will have to be deleted/logged out of later (easy in the app, apparently not so in the cli). Tip - learn the names of your other existing devices so you don’t accidentally log them out.
For sys-mullvad service as netVM
Currently, I cannot get this to work on my system. Tried several approaches, using Mullvad cli and the app.
sys-mullvadhas no memory of previous settings, no autostart of app.template-mullvad>$ /opt/'Mullvad VPN/mullvad-guilaunches app, but can’t log in so no settings are available (autostart). Didn’t bother trying withcli.- even when app or cli used to manually log in to Mullvad on
sys-mullvad, client AppVMs aren’t connecting to anything.
I thought of perhaps putting something in rc.local, but I see there are issues there that I do not understand and don’t want to screw with.
If there are instructions for this, can I suggest they are placed in the description for this package in Qubes Task Manager? Right now, I don’t know where to look.
Notes on user experience
After a couple of hours of experimentation, I’ve had to kill the mullvad-vpn dispVM a few times now. The browser seems to place a really high CPU and memory demand and freezes. Are the default settings adequate for this qube?
Video playback is a challenge (although may be a problem with NoScript and uBlockOrigin settings), but e.g. youtube has no sound. I think this is currently the same in TorBrowser in Qubes (known issue).
3isec-qubes-task-manager 0.2-1 and 3isec-qubes-mullvad-vpn 2023.6-2.fc37
apt list --installed in mullvad-dvm lists only mullvad-vpn, not the mullvad browser.
Thanks - other users dont report your issues with that package.
I’ll push an updated version shortly with increased memory and an
updated Browser version.
This is to be expected, because the browser is installed from a tar
archive, not from a deb package.
That is because they are disposables - any settings you put here
will be lost when you close the disposable. That’s how disposables work.
This is called out in the package description.
The lack of autostart is by design, and at user request.
I could change this.
I cant replicate the failure to connect from client qubes.
Can you confirm how you installed the package?
If you set the netvm of a qube to sys-mullvad, can you access a site by
IP? https://195.10.223.181 should redirect to https://qubes.3isec.org
If you see the redirect but the page doesnt load then you have DNS
issue. If you dont see the redirect then there is general connectivity
issue.
You might want to use it in AppVMs rather than the template.
Perhaps not, although other users havent reported this. I’ll push up the
maxmem in the next version.
You’re right at the end there.
The template is restricted to the update proxy.
The disposable template has full access to the net, because you want
the disposables based on it to have that access. By default,
disposables inherit network and firewall settings from the disposable
template they are based on.
I expected to find evidence of extracted files from the tar archive in /home/user/mullvad-browser/ and /etc/skel/Downloads/, but neither folder exists. Is there a discrepancy in the browser.sls minion file that could be causing this? The tar file names differ between lines 4 and 12 (below copied from updated file on github):
4 - salt://mullvad/mullvad-browser-linux-x86_64-13.0.13.tar.xz
12 - source: /etc/skel/Downloads/mullvad_browser-linux-x86_64-13.0.13.tar.xz
You are looking in the wrong place.
mullvad/browser.sls is used to copy the browser tar file to
/etc/skel/Downloads/ in the template, and extract it to /etc/skel.
(The name change is not a typo - it was user request.)
This happens automatically when the package is installed, because the
post install commands include:
qubesctl --skip-dom0 --targets=template-mullvad state.apply mullvad.browser
When a qube is created using that template the file is in
/home/user/Downloads, and the mullvad-browser directory is in /home/user.
Both sys-mullvad and the mullvad disposable template are created after
the template configuration, so will inherit those files.
- Check in template-mullvad - are the files present in
/etc/skel/? - Create a new qube using template-mullvad as template - does it have
the files in/home/user?
/etc/skel/ in template-mullvad is empty aside from the hidden files and folders. In particular, the Downloads folder is missing from there.
Likewise in the new qube formed from template-mullvad. /home/user/Dowloads/ is empty and /home/user/mullvad-browser does not exist.
If it’s not in /etc/skel in the template it wont appear in /home/user in
newly created qubes.
I’m still not clear why this did not work for you, when it has worked
for other users.
Can you confirm what template is used by default-mgmt-dvm qube?
Could you also run this command in dom0:
sudo qubesctl --skip-dom0 --show-output --targets=template-mullvad state.apply mullvad.browser
This is the salt that should be run to copy the browser tarfile in to the
template, and extract the files. Running with --show-output will help
identify what is going wrong in your case.
The default-mgmt-dvm qube is debian-12-xfce. The output of the above command is the following:
template-mullvad:
- No matching sls found for ‘mullvad-browser’ in env ‘base’
check your command - it should be mullvad.browser
indeed, my mistake, thanks for your patience. out of 7 states run, only the first 2 failed:
Function: file.managed
Result: False
Comment: Unable to manage file: none of the specified sources were found
Function: archive.extracted
Result: False
Comment: Source file '/etc/skel/Downloads/mullvad_browser-linux-x86_64-13.0.10.tar.xz' does not exist
Note that the tar archive was downloaded into /srv/salt/mullvad/, not into /etc/skel/
Definitely a general connectivity issue, then - data not passing between qubes? IP doesn’t resolve in browser either. Can’t ping your IP or sitename (by design?) but can ping 8.8.8.8 and google.com. I had problems with other ways of connecting to Mullvad too - maybe that MTU thing. Have to investigate.
^ Re log out to avoid ‘clogging up’ your devices:
- Firstly, its definitely 5, not 6, devices.
- Secondly, a script that ran to logout automatically as part of qube shutdown procedures would be nice. Not sure if possible.
I’m not sure what the logic is there. With my use case, I want as minimal interaction with the qube as possible - I want it to launch and sit there doing its thing (connectivity) just like sys-firewall does, without input.
What I want is the disposable sys-mullvad remember my account settings. It would either remember device identity (for Mullvad’s count) or, more sanitarily, that auto-logout feature ^ would ensure it closes cleanly and doesn’t clog up Mullvad’s system.
Multiple accounts or location settings could be managed by cloning the qube and altering them individulally (e.g. personal-vm automatically launches a disposable Sweden-sys-mullvad, work-vm launches a disposable London-sys-mullvad and so-on).
I can’t play around with this until I solve that basic connectivity issue and my skills are limited anyway. At the moment I have some high work demands, but I remain interested.
Here’s a Qubes question: how can I tell if a running qube is a named disposable or a regular ‘remembered’ qube? (e.g. I can’t tell by looking at Qubes Domains that sys-firewall is disposable, but it is because that’s how I installed it).
Just to reinforce that autologout feature.
I have had to close a qube without logging out of Mullvad - so I will have to delete an extra device later - because I couldn’t figure out which icon it was.
To be clear:
- launch 2+ disp-mullvad or sys-mullvad qubes with Mullvad app run in each of them
- minimize app windows to icon in system tray.
- attempt to close one disp-mullvad instance
- try to figure out which green padlock is which in system tray and fail
- close qube without Mullvad’s device log-out.
