thanks for the guide and showcase, this is awesome.
I’ve tried running snapchat on both the 64bit version and 32bit version and both crash, is there a way around it? i really need to run snapchat somehow on qubes anyways
any alternative to this for running snapchat? i tried 32 and 64 it crashes on both
You can try to install it on Waydroid, it has newer android version:
you think the cause of the app crashing is the android version?
Officially it should work on Android 4.4 or newer but maybe there is some problem with Android version or Android-x86 specifically. Personally I’d give it a try.
When attempting to launch the LiveCD with no installation, the “Android” graphic pops up and just keeps loading, and then it crashes and doesn’t boot.
Cannot boot without the above mentioned boot flag:
nomodeset vga=911
Once Android has been installed, should it still require booting via the bootloader menu?
In my case the installation to the disk doesn’t persist and I need to boot from the .iso
each time.
It requires a reinstall each time in order to boot Android, the installation doesn’t persist.
This shouldn’t be required.
That was my sense also. Just not sure why there is no persistence at the moment.
apps detect model as HVM domU and device name being domU by default, same goes for actual PC CPU and manufacture, is there a way to properly spoof CPU at the very least?, the ISO has built in android root which is useful, unsure it’s possible to get magisk on there with LSPosed to get some modules to spoof hardware, would be useful if you got any idea as i only plan to use some social media apps for communication, don’t want them knowing my CPU…, i know it’s technically counter productive to spoof those things because you’re still creating a unique finger print but even then, having the app know what CPU I’m running is not good.
Hello, ( i am noob)
step 2, I fail to increase initial memory, when initial memory exceeds 1024MB. VM crash “not enough memory to start domain”. if I run with 1024 MB, I get stuck on the Android installation step after Pick the “VirtWifi”
Is there no Android version 14 or 15?
Unfortunately, you can only install Android version 9.
As far as I know, there is already a new version on cell phones.
There is Android 13 available for BlissOS:
This guide doesn’t work for me. When I get to the stage of reboot it just never gives me the grub menu at all. I tried the auto installer and a manual install making sure to install grub. Either way grub menu doesn’t show up and the vm can’t boot.
Installation with this guide was a breeze (I’m on Q4.2), but I have no audio. In fact, when I open (Dom0) Volume Control (pulseaudio?) I don’t even see the Android-x86 qube in there.
Additional info: everything else in my Qubes machine has audio, no problems, no issues. I tried waydroid and the audio works there but it has many other problems so I try to make Android-x86 audio work.
Tips anyone?
So Android-x86 works better than Waydroid in general?
After some updates in dom0, the VirtWifi stopped working. Endless loop of “Connecting…”, “Obtaining ip address…”, “Connected, no internet” , “Saved” .
The android-x86 file is old and has not been updated from a long time (release 9, from march 2022).
Are there more recent version compatible for a VM installation? Even-better: is it possible to install directly a “de-googlized” android as idéaOS on a VM?
Thank you
