kkscr
April 10, 2023, 3:38pm
21
Ok, that what I did then.
well, I did follow your step, but didn’t succeeded.
adb didn’t listed any devices.
After running:
$ sudo modprobe ashmem_linux
$ sudo modprobe binder_linux
I could see the emulator listed by adb, but still anbox wouldn’t launch.
Anbox seems to be totally broken generaly speaking , but it’s weird that I can’t reproduce on my machine. The only difference is that I downloaded the img from a mirror ( the link from the post is broken ) and that debian template is a bit more up to date since your post.
Any idea what I could also try ?
Did you start anbox-container-manger.service before starting anbox?
kkscr
April 10, 2023, 3:56pm
23
not manually but I can see it with ps -aux
When anbox start, it pop a window with an android logo ( I thing its loading ) and then break
If you start anbox from the command line, do you get an error when it fails to start?
kkscr
April 10, 2023, 4:16pm
25
So I start my anbox standalone VM, this is my full prompt:
user@anbox:~$ ps -aux | grep anbox
root 760 0.0 1.6 113168 5552 ? Ssl 18:12 0:00 /usr/bin/anbox container-manager --daemon --privileged --data-path=/var/lib/anbox
user 1342 0.0 0.2 6320 704 pts/0 S+ 18:12 0:00 grep anbox
user@anbox:~$ adb devices
* daemon not running; starting now at tcp:5037
* daemon started successfully
List of devices attached
user@anbox:~$ sudo modprobe ashmem_linux
user@anbox:~$ sudo modprobe binder_linux
user@anbox:~$ anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
[ 2023-04-10 16:16:00] [launch.cpp:202@operator()] Session manager failed to become ready
emulator-5558 device
Don’t know why you are loading the kernel modules.
Just follow this guide, for me it works, but you need to manually start the service
Hello, here is how i did it:
Create a new qube StandAloneVM (Fully persistent) with Debian-11 template and check “Launch settings after creation”
[01]
On Settings window, go to “Advanced”, uncheck “Include in memory balancing”, set your initial memory.
2.1 On kernel, set it to (none).
2.2 On Virtualization, set HVM.
[02]
Run the vm, open the terminal to update the package list and upgrade the system to install adb, fastboot and anbox: sudo apt update && sudo apt full-upgrade && sudo…
kkscr
April 10, 2023, 4:54pm
27
How do you manually start the server ?
sudo systemctl start anbox-container-manager.service
I just need to run that command before it start anbox.
kkscr
April 10, 2023, 4:59pm
29
sudo systemctl stus anbox-container-manager.service
show me that the status is already active.
I still get the same error
xmpriv
August 5, 2023, 11:42pm
30
Bravo. This works today and is to-date the best method I’ve come across. The performance is blazing.
Thanks for sharing!
Unfortunately the anbox.io .img’s are no longer being officially served. Grab it from a mirror:
(probably a good idea to check the SHA actually matches, thus a legit mirror file. I only used it to test install so wasn’t worried)
qubiq
August 7, 2023, 9:32am
31
user@anbox:~$ sudo systemctl restart anbox-container-manager.service
user@anbox:~$ sudo systemctl status anbox-container-manager.service
● anbox-container-manager.service - Anbox Container Manager
Loaded: loaded (/lib/systemd/system/anbox-container-manager.service; enabl>
Active: active (running) since Mon 2023-08-07 08:28:23 EDT; 1s ago
Docs: man:anbox(1)
Ctrl+C
user@anbox:~$ adb devices && anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
I am able to install everything but cannot run anbox. I also get the session manager error:
[ 2023-08-30 18:32:13] [launch.cpp:202@operator()] Session manager failed to become ready
Sometimes a window opens with the android logo, but it closes and then the error is printed.
I do have the anbox-container-manager.service systemd service active.
Hi, I’m trying this but
sudo apt install abd fastboot anbox
Doesn’t seem to work. Getting error:
unable to locate package anbox
Seem like it’s not in the repository. Using debian-12
Works with debian-11
There’s a community guide on how to do this now. Those instructions should help.
Please provide the link I Can’t find it
