TL;DR I didn’t get the 4.2.3 update because my dom0 crond daemon creates a lot of coredumps. Why? Just a basic disk issue ![]()
No 4.2.3 update
I was surprise to not see the 4.2.3 update. I checked and the qubes-release-4.2-9.fc37.src.rpm has been publish in the current repository. So I search why I didn’t get the update.
/etc/cron.daily/qubes-dom0-updates.cron should check for dom0 updates. It runs qubes-dom0-update --check-only. I checked, and the qubes-dom0-update --check-only finds the qubes-release update:
[user@dom0 ~]$ qubes-dom0-update --check-only
qubes-release.noarch 4.2-9.fc37 qubes-dom0-current
So why doesn’t /etc/cron.daily/qubes-dom0-updates.cron work?
Crond creates core dumps
The crond daemon runs the `/etc/cron.daily/’ tasks. In the logs I see that the daemon creates a lot of core dumps:
[user@dom0 ~]$ journalctl -fu crond
Sep 29 10:44:37 dom0 systemd[1]: crond.service: Scheduled restart job, restart counter is at 189.
Sep 29 10:44:37 dom0 systemd[1]: Stopped crond.service - Command Scheduler.
Sep 29 10:44:37 dom0 systemd[1]: Started crond.service - Command Scheduler.
Sep 29 10:44:37 dom0 systemd[1]: crond.service: Main process exited, code=dumped, status=7/BUS
Sep 29 10:44:37 dom0 systemd[1]: crond.service: Failed with result 'core-dump'.
Sep 29 10:45:08 dom0 systemd[1]: crond.service: Scheduled restart job, restart counter is at 190.
Sep 29 10:45:08 dom0 systemd[1]: Stopped crond.service - Command Scheduler.
Sep 29 10:45:08 dom0 systemd[1]: Started crond.service - Command Scheduler.
Sep 29 10:45:08 dom0 systemd[1]: crond.service: Main process exited, code=dumped, status=7/BUS
Sep 29 10:45:08 dom0 systemd[1]: crond.service: Failed with result 'core-dump'.
Sep 29 10:45:38 dom0 systemd[1]: crond.service: Scheduled restart job, restart counter is at 191.
Sep 29 10:45:38 dom0 systemd[1]: Stopped crond.service - Command Scheduler.
Sep 29 10:45:38 dom0 systemd[1]: Started crond.service - Command Scheduler.
Sep 29 10:45:38 dom0 systemd[1]: crond.service: Main process exited, code=dumped, status=7/BUS
Sep 29 10:45:38 dom0 systemd[1]: crond.service: Failed with result 'core-dump'.
^C
[user@dom0 ~]$ systemctl status crond
● crond.service - Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/crond.service; enabled; preset: enabled)
Active: activating (auto-restart) (Result: core-dump) since Sun 2024-09-29 10:45:38 UTC; 13s ago
Process: 17486 ExecStart=/usr/sbin/crond -n $CRONDARGS (code=dumped, signal=BUS)
Main PID: 17486 (code=dumped, signal=BUS)
CPU: 10ms
Core dump frequency and content
The coredumpctl list command shows all the core dumps, so I get a crond core dump each 30s:
[user@dom0 ~]$ sudo coredumpctl list
Sun 2024-09-29 13:13:22 UTC 21768 0 0 SIGBUS present /usr/sbin/crond 43.2K
Sun 2024-09-29 13:13:52 UTC 21777 0 0 SIGBUS present /usr/sbin/crond 43.2K
Sun 2024-09-29 13:14:23 UTC 21789 0 0 SIGBUS present /usr/sbin/crond 43.2K
Sun 2024-09-29 13:14:53 UTC 21806 0 0 SIGBUS present /usr/sbin/crond 43.2K
Sun 2024-09-29 13:15:23 UTC 21830 0 0 SIGBUS present /usr/sbin/crond 43.3K
The coredumpctl info command shows the last core dump:
[user@dom0 ~]$ sudo coredumpctl info
PID: 21950 (crond)
UID: 0 (root)
GID: 0 (root)
Signal: 7 (BUS)
Timestamp: Sun 2024-09-29 13:20:25 UTC (29s ago)
Command Line: /usr/sbin/crond -n
Executable: /usr/sbin/crond
Control Group: /system.slice/crond.service
Unit: crond.service
Slice: system.slice
Boot ID: 58cd9555d8b64bf495f4359ef6306bfc
Machine ID: 38aab07ddc4b4ed488f3f81290b88c77
Hostname: dom0
Storage: /var/lib/systemd/coredump/core.crond.0.58cd9555d8b64bf495f4359ef6306bfc.21950.1727616025000000.>
Disk Size: 43.2K
Package: cronie/1.6.1-3.fc37
build-id: 83da550dea1764b03a0f041494e9c1df758ce1ca
Message: Process 21950 (crond) of user 0 dumped core.
Module linux-vdso.so.1 with build-id bb05304aa2fa20cc6c55d8d7fc5dda2a83ad8aac
Stack trace of thread 21950:
#0 0x00005b0d124da000 _init (crond + 0x3000)
ELF object binary architecture: AMD x86-64
The crond executable creates a small stack trace. It crashed in the _init() function. So maybe a problem with my crond setting files… I will search in this way.
crond binary origin
The /usr/sbin/crond executable comes from the cronie-1.6.1-3.fc37 which is the last package version available in fedora 37.
I checked the checkum from the cronie package:
[user@dom0 ~]$ sudo rpm -V cronie
..?...... /usr/sbin/crond
The rpm man page says:
a single “?” (question mark) indicates the test could not be performed (e.g. file permissions prevent reading)
So I can’t conclude ![]()
What is the binary checksum?
[user@dom0 ~]$ ls -al /usr/sbin/crond
-rwxr-xr-x 1 root root 75072 Jul 21 2022 /usr/sbin/crond
[user@dom0 ~]$ sudo sha256sum /usr/sbin/crond
sha256sum: /usr/sbin/crond: Input/output error
Why can’t sha256sum read the file ?
Same problem with md5sum …
A disk issue
The file command works:
user@dom0 ~]$ file /usr/sbin/crond
/usr/sbin/crond: ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=83da550dea1764b03a0f041494e9c1df758ce1ca, for GNU/Linux 3.2.0, stripped
The file command reads only the header of the file, whereas sha256sum reads all the file.
So is it an issue with my filesystem?
[user@dom0 ~]$ sudo dmesg -T
[Sun Sep 29 13:40:05 2024] nvme0n1: I/O Cmd(0x2) @ LBA 7792688, 8 blocks, I/O Error (sct 0x2 / sc 0x81)
[Sun Sep 29 13:40:05 2024] critical medium error, dev nvme0n1, sector 7792688 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Arghhh my SSD is dying…
But the good news is that I did frequent 3-2-1 backups. So now I will try to solve my disk issue, else I will buy a new SSD and use my backups.
