"An unknown error ocurred" during installation on empty partition
I am a beginner, so please bare with me. I will try to be as detailed as possible.
I have tried to install Qubes (version 4.2.2) from two different USBs on a machine running fedora workstation (latest version). I have done this with the dd command, and I have verified the signatures & all downloaded files successfully. Verifying the written USBs has also been successful.
When I tried to install via the first USB I selected test and install Qubes and it failed the check. I tried afterwards to install (from the same USB) via the troubleshooting option to see what was wrong, Qubes installer runs normally, chose automatic configuration of an empty drive with no partitions, but then I get “An unknown error occurred” when I begin installation. When I check the debug section, it says “dnf.exceptions.Error: Some packages from local repository have incorrect checksum” and "msg: Package “{}” from local repository “{} has incorrect checksum.”
I tried another USB, 16gb. Passed all the verification checks for the written USB verification guide too.I tried to install through this one, and I get to the Qubes boot menu. But when I select any of the options to install, it gives me this error: “error: xz file corrupted or unsupported block options”.
I have tried to re-write both USBs but the same issue persists. I have enabled virtualization in BIOS and I have also enabled legacy boot. I am running a NVIDIA (NV167) graphics card so maybe that is an issue.
I have tried to re-write the USB multiple times (first with dd command, then with rufus on windows, verifying the files in both windows and fedora), and I have tried different ports. What can I do?
Thank you for your time.
Try this:
  • Write the image on the USB disk in Fedora and don’t connect it to the WIndows after writing
  • Re-verify the USB disk after writing:
    Verifying signatures | Qubes OS
  • Boot from the USB disk and run the test media before installation
  • If it fails then boot in Fedora again and re-verify the USB disk again to check if it was modified
Thanks for your response. Just tried this (I was in the process of re-writing in Fedora again already).I ran test media and the check failed.
I then ran this:
sudo dd if=/dev/sdd bs=1M count=$(stat -c %s Qubes-R4.2.2-x86_64.iso) iflag=count_bytes | sha256sum
The check failed, it does not match the original. (When I did the verification just after writing, I ran sha256sum, md5sum, sha1sum and sha512sum, this time I skipped the rest of them due to the fail). Then I ran:
sudo dd if=/dev/sdd bs=1M count=6897252352 iflag=count_bytes | gpg -v --verify Qubes-R4.2.2-x86_64.iso.asc -
And got Bad signature. It seems something while attempting to install modifies the USB? The install destination is an external SSD drive, if that’s relevant.
Try to compare the ISO image to the USB disk like this to see where was it modified:
E.g.:
cmp -n $(stat -c %s Qubes-R4.2.2-x86_64.iso) -l Qubes-R4.2.2-x86_64.iso /dev/sdd | gawk '{printf "%08X %02X %02X\n", $1-1, strtonum(0$2), strtonum(0$3)}'
I tried this command, and it gave an impossibly long output that’s all like this:
Spoilered because it's too big, this isn't the complete output either, it's long enough that I can't scroll far enough up to see the command I typed
`19B0081F1 00 33
19B0081F2 00 BB
19B0081F3 00 EE
19B0081F4 00 33
19B0081F5 00 DD
19B0081F6 00 99
19B0081F7 00 99
19B0081F8 EC 64
19B0081F9 13 DF
19B0081FB 00 AA
19B0081FC 00 55
19B0081FD 00 22
19B0081FE 00 66
19B0081FF 00 FF
19B008202 00 FF
19B00820B 00 88
19B00820C 00 22
19B00820E 00 22
19B00820F 00 88
19B008210 F9 60
19B008213 00 66
19B008214 00 EE
19B008215 00 22
19B008216 00 22
19B008219 00 11
19B00821A 00 22
19B00821C 02 20
19B00821D 00 88
19B00821E 00 BB
19B00821F 00 88
19B008221 02 8A
19B008222 00 22
19B008224 00 BB
19B008225 00 88
19B008226 00 EE
19B008227 00 88
19B008228 06 AC
19B008229 14 9C
19B00822A 00 22
19B00822C 00 99
19B00822F 00 EE
19B008230 01 EF
19B008231 00 22
19B008232 00 99
19B008234 EE 44
19B008235 00 66
19B008237 00 88
19B008238 00 EE
19B00823A 00 33
19B00823B 00 AA
19B00823D 00 11
19B00823E 00 22
19B008241 14 9C
19B008242 00 66
19B008246 00 BB
19B008247 00 99
19B008248 01 98
19B00824A 00 CC
19B00824B 00 EE
19B00824C 02 A8
19B00824D 00 AA
19B00824E 00 88
19B008251 02 8A
19B008252 00 22
19B008254 00 99
19B008256 00 99
19B008257 00 66
19B008259 14 36
19B00825B 00 22
19B00825C 00 FF
19B00825D 00 AA
19B00825E 00 CC
19B00825F 00 AA
19B008261 00 33
19B008262 00 99
19B008264 33 AA
19B008265 00 88
19B008266 00 88
19B008267 00 EE
19B008268 00 11
19B008269 00 AA
19B00826A 00 BB
19B00826B 00 88
19B00826C 00 AA
19B00826D 00 66
19B00826E 00 EE
19B00826F 00 88
19B008270 32 45
19B008272 00 99
19B008273 00 CC
19B008274 00 AA
19B008275 00 BB
19B008276 00 BB
19B008277 00 AA
19B008278 01 CD
19B008279 00 CC
19B00827A 00 88
19B00827B 00 22
19B00827C C8 62
19B00827D 00 88
19B00827F 00 AA
19B008280 00 DD
19B008281 00 AA
19B008282 00 EE
19B008283 00 CC
19B008284 00 22
19B008285 00 33
19B008286 00 AA
19B008287 00 AA
19B008289 14 9C
19B00828A 00 DD
19B00828B 00 88
19B00828C 00 66
19B00828D 00 88
19B00828E 00 BB
19B00828F 00 99
19B008292 00 CC
19B008293 00 88
19B008294 AB 76
19B008295 00 88
19B008296 00 AA
19B008297 00 88
19B008298 00 11
19B008299 00 99
19B00829A 00 88
19B00829B 00 66
19B00829C 00 11
19B00829D 00 AA
19B00829E 00 66
19B00829F 00 EE
19B0082A0 4A 68
19B0082A1 14 36
19B0082A2 00 BB
19B0082A3 00 BB
19B0082A4 00 66
19B0082A5 00 CC
19B0082A6 00 99
19B0082A9 00 99
19B0082AA 00 33
19B0082AB 00 88
19B0082AC C4 D5
19B0082AD 00 AA
19B0082AE 00 22
19B0082AF 00 88
19B0082B0 00 88
19B0082B4 00 11
19B0082B6 00 FF
19B0082B7 00 66
19B0082B8 56 ED
19B0082B9 14 36
19B0082BA 00 55
19B0082BB 00 66
19B0082BC 00 22
19B0082BD 00 44
19B0082BF 00 AA
19B0082C0 01 EF
19B0082C1 00 AA
19B0082C2 00 99
19B0082C3 00 AA
19B0082C4 B4 0F
19B0082C5 00 22
19B0082C6 00 BB
19B0082C7 00 44
19B0082C8 00 44
19B0082C9 00 88
19B0082CA 00 88
19B0082CC 00 77
19B0082CD 00 11
19B0082CE 00 11
19B0082CF 00 22
19B0082D0 62 51
19B0082D1 14 AF
19B0082D2 00 55
19B0082D3 00 44
19B0082D4 00 11
19B0082D5 00 22
19B0082D6 00 88
19B0082D7 00 77
19B0082D8 01 BA
19B0082D9 00 22
19B0082DA 00 55
19B0082DB 00 AA
19B0082DC 04 BF
19B0082DD 00 44
19B0082DE 00 77
19B0082DF 00 66
19B0082E0 10 89
19B0082E1 00 AA
19B0082E2 00 33
19B0082E3 00 44
19B0082E4 00 11
19B0082E5 00 AA
19B0082E6 00 33
19B0082E7 00 22
19B0082E8 6F 81
19B0082E9 14 D8
19B0082EA 00 11
19B0082EB 00 88
19B0082EC 00 77
19B0082ED 00 AA
19B0082EE 00 EE
19B0082EF 00 CC
19B0082F0 01 EF
19B0082F1 00 11
19B0082F2 00 99
19B0082F3 00 66
19B0082F4 6B E3
19B0082F5 00 77
19B0082F6 00 22
19B0082F7 00 AA
19B0082F8 00 11
19B0082FA 00 66
19B0082FB 00 44
19B0082FC 00 88
19B0082FD 00 88
19B0082FE 00 44
19B0082FF 00 99
19B008300 81 4D
19B008301 14 FA
19B008302 00 66
19B008303 00 AA
19B008304 00 11
19B008305 00 11
19B008306 00 88
19B008308 01 67
19B008309 00 22
19B00830B 00 88
19B00830C 0E 3D
19B00830D 00 22
19B00830F 00 44
19B008310 00 66
19B008311 00 88
19B008312 00 66
19B008314 00 CC
19B008315 00 FF
19B008316 00 EE
19B008317 00 88
19B008318 97 1F
19B008319 14 27
19B00831A 00 DD
19B00831C 00 CC
19B00831E 00 AA
19B00831F 00 BB
19B008320 01 98
19B008322 00 CC
19B008323 00 66
19B008324 02 EC
19B008325 00 22
19B008326 00 DD
19B008327 00 88
19B008328 4A 97
19B008329 02 9B
19B00832A 00 AA
19B00832B 00 66
19B00832C 00 AA
19B00832D 00 BB
19B00832E 00 77
19B008330 A4 68
19B008332 00 AA
19B008333 00 BB
19B008334 00 CC
19B008335 00 22
19B008336 00 11
19B008337 00 EE
19B008338 01 CD
19B008339 00 33
19B00833A 00 44
19B00833B 00 22
19B00833D 00 BB
19B00833E 00 22
19B00833F 00 44
19B008341 00 88
19B008342 00 44
19B008343 00 AA
19B008344 00 77
19B008345 00 44
19B008346 00 66
19B008347 00 77
19B008348 B0 83
19B008349 14 BE
19B00834A 00 AA
19B00834B 00 22
19B00834C 00 66
19B00834D 00 EE
19B00834F 00 22
19B008350 01 FE
19B008351 00 33
19B008352 00 33
19B008353 00 CC
19B008354 17 9F
19B008355 00 88
19B008356 00 CC
19B008357 00 22
19B008358 00 77
19B008359 00 CC
19B00835B 00 FF
19B00835C 00 AA
19B00835D 00 33
19B00835E 00 88
19B00835F 00 88
19B008360 C1 F2
19B008362 00 66
19B008363 00 CC
19B008364 00 11
19B008366 00 99
19B008367 00 DD
19B008368 01 23
19B008369 00 AA
19B00836A 00 77
19B00836B 00 22
19B00836C 04 15
19B00836E 00 BB
19B00836F 00 22
19B008371 00 22
19B008372 00 55
19B008373 00 88
19B008374 00 AA
19B008377 00 44
19B008378 D1 7B
19B00837A 00 BB
19B00837B 00 EE
19B00837C 00 FF
19B00837D 00 44
19B00837E 00 EE
19B00837F 00 CC
19B008380 01 10
19B008381 00 11
19B008382 00 AA
19B008383 00 EE
19B008384 8E 60
19B008385 00 EE
19B008387 00 AA
19B008388 00 88
19B008389 00 55
19B00838A 00 33
19B00838B 00 88
19B00838C 00 BB
19B00838D 00 22
19B00838E 00 66
19B00838F 00 88
19B008390 06 71
19B008391 15 9D
19B008392 00 AA
19B008393 00 44
19B008394 00 33
19B008395 00 11
19B008396 00 55
19B008397 00 CC
19B008398 01 54
19B008399 00 88
19B00839A 00 AA
19B00839B 00 44
19B00839C 48 6A
19B00839D 00 EE
19B00839E 00 33
19B00839F 00 88
19B0083A2 00 77
19B0083A3 00 AA
19B0083A4 00 88
19B0083A5 00 33
19B0083A6 00 11
19B0083A7 00 CC
19B0083A8 4B B4
19B0083A9 15 9D
19B0083AA 00 44
19B0083AB 00 CC
19B0083AC 00 EE
19B0083AD 00 BB
19B0083AE 00 BB
19B0083AF 00 77
19B0083B0 01 98
19B0083B1 00 22
19B0083B2 00 88
19B0083B3 00 66
19B0083B4 6B 94
19B0083B5 00 44
19B0083B6 00 33
19B0083B7 00 DD
19B0083B8 00 BB
19B0083B9 00 33
19B0083BA 00 44
19B0083BB 00 88
19B0083BC 00 88
19B0083BD 00 CC
19B0083BE 00 FF
19B0083BF 00 CC
19B0083C0 61 52
19B0083C1 15 9D
19B0083C2 00 11
19B0083C3 00 77
19B0083C4 00 EE
19B0083C5 00 22
19B0083C6 00 AA
19B0083C7 00 CC
19B0083C8 01 32
19B0083C9 00 FF
19B0083CA 00 88
19B0083CB 00 CC
19B0083CC 6B 3E
19B0083CD 00 EE
19B0083CE 00 CC
19B0083CF 00 CC
19B0083D0 00 AA
19B0083D1 00 99
19B0083D2 00 AA
19B0083D3 00 EE
19B0083D4 00 33
19B0083D5 00 CC
19B0083D6 00 DD
19B0083D7 00 44
19B0083D8 2D B4
19B0083D9 16 BC
19B0083DA 00 EE
19B0083DB 00 EE
19B0083DC 00 99
19B0083DD 00 22
19B0083DE 00 55
19B0083DF 00 88
19B0083E0 01 98
19B0083E1 00 66
19B0083E2 00 99
19B0083E3 00 44
19B0083E4 04 8C
19B0083E5 00 11
19B0083E7 00 44
19B0083E8 28 39
19B0083E9 00 AA
19B0083EA 00 99
19B0083EB 00 88
19B0083EC 00 EE
19B0083ED 00 77
19B0083EE 00 11
19B0083EF 00 22
19B0083F0 4B 1E
19B0083F1 16 25
19B0083F2 00 BB
19B0083F3 00 EE
19B0083F4 00 33
19B0083F5 00 DD
19B0083F6 00 99
19B0083F7 00 99
19B0083F8 01 89
19B0083F9 00 CC
19B0083FB 00 AA
19B0083FC BB EE
19B0083FD 00 22
19B0083FE 00 66
19B0083FF 00 FF
19B008402 00 FF
19B00840B 00 88
19B00840C 00 22
19B00840E 00 22
19B00840F 00 88
19B008410 01 98
19B008413 00 66
19B008414 04 EA
19B008415 00 22
19B008416 00 22
19B008419 00 11
19B00841A 00 22
19B00841C 00 22
19B00841D 00 88
19B00841E 00 BB
19B00841F 00 88
19B008421 16 9E
19B008422 00 22
19B008424 00 BB
19B008425 00 88
19B008426 00 EE
19B008427 00 88
19B008428 01 AB
19B008429 00 88
19B00842A 00 22
19B00842C 04 9D
19B00842F 00 EE
19B008430 38 D6
19B008431 00 22
19B008432 00 99
19B008434 00 AA
19B008435 00 66
19B008437 00 88
19B008438 84 6A
19B00843A 00 33
19B00843B 00 AA
19B00843D 00 11
19B00843E 00 22
19B008441 00 88
19B008442 00 66
19B008446 00 BB
19B008447 00 99
19B008448 38 A1
19B00844A 00 CC
19B00844B 00 EE
19B00844C 00 AA
19B00844D 00 AA
19B00844E 00 88
19B008451 16 9E
19B008452 00 22
19B008454 00 99
19B008456 00 99
19B008457 00 66
19B008459 00 22
19B00845B 00 22
19B00845C 04 FB
19B00845D 00 AA
19B00845E 00 CC
19B00845F 00 AA
19B008461 00 33
19B008462 00 99
19B008464 00 99
19B008465 00 88
19B008466 00 88
19B008467 00 EE
19B008468 B2 A3
19B008469 16 BC
19B00846A 00 BB
19B00846B 00 88
19B00846C 00 AA
19B00846D 00 66
19B00846E 00 EE
19B00846F 00 88
19B008470 01 76
19B008472 00 99
19B008473 00 CC
19B008474 04 AE
19B008475 00 BB
19B008476 00 BB
19B008477 00 AA
19B008478 34 F8
19B008479 00 CC
19B00847A 00 88
19B00847B 00 22
19B00847C 00 AA
19B00847D 00 88
19B00847F 00 AA
19B008480 CF 12
19B008481 16 BC
19B008482 00 EE
19B008483 00 CC
19B008484 00 22
19B008485 00 33
19B008486 00 AA
19B008487 00 AA
19B008489 00 88
19B00848A 00 DD
19B00848B 00 88
19B00848C 04 62
19B00848D 00 88
19B00848E 00 BB
19B00848F 00 99
19B008492 00 CC
19B008493 00 88
19B008494 00 DD
19B008495 00 88
19B008496 00 AA
19B008497 00 88
19B008498 FA EB
19B008499 16 8F
19B00849A 00 88
19B00849B 00 66
19B00849C 00 11
19B00849D 00 AA
19B00849E 00 66
19B00849F 00 EE
19B0084A0 01 23
19B0084A1 00 22
19B0084A2 00 BB
19B0084A3 00 BB
19B0084A4 D4 B2
19B0084A5 00 CC
19B0084A6 00 99
19B0084A9 00 99
19B0084AA 00 33
19B0084AB 00 88
19B0084AC 00 11
19B0084AD 00 AA
19B0084AE 00 22
19B0084AF 00 88
19B0084B0 19 91
19B0084B4 00 11
19B0084B6 00 FF
19B0084B7 00 66
19B0084B8 01 BA
19B0084B9 00 22
19B0084BA 00 55
19B0084BB 00 66
19B0084BC 04 26
19B0084BD 00 44
19B0084BF 00 AA
19B0084C0 34 DA
19B0084C1 00 AA
19B0084C2 00 99
19B0084C3 00 AA
19B0084C4 00 BB
19B0084C5 00 22
19B0084C6 00 BB
19B0084C7 00 44
19B0084C8 33 77
19B0084C9 17 9F
19B0084CA 00 88
19B0084CC 00 77
19B0084CD 00 11
19B0084CE 00 11
19B0084CF 00 22
19B0084D0 01 32
19B0084D1 00 BB
19B0084D2 00 55
19B0084D3 00 44
19B0084D4 04 15
19B0084D5 00 22
19B0084D6 00 88
19B0084D7 00 77
19B0084D8 34 8F
19B0084D9 00 22
19B0084DA 00 55
19B0084DB 00 AA
19B0084DC 00 BB
19B0084DD 00 44
19B0084DE 00 77
19B0084DF 00 66
19B0084E0 3F A6
19B0084E1 17 BD
19B0084E2 00 33
19B0084E3 00 44
19B0084E4 00 11
19B0084E5 00 AA
19B0084E6 00 33
19B0084E7 00 22
19B0084E8 01 EF
19B0084E9 00 CC
19B0084EA 00 11
19B0084EB 00 88
19B0084EC 04 73
19B0084ED 00 AA
19B0084EE 00 EE
19B0084EF 00 CC
19B0084F0 34 DA
19B0084F1 00 11
19B0084F2 00 99
19B0084F3 00 66
19B0084F4 00 88
19B0084F5 00 77
19B0084F6 00 22
19B0084F7 00 AA
19B0084F8 4F 5E
19B0084FA 00 66
19B0084FB 00 44
19B0084FC 00 88
19B0084FD 00 88
19B0084FE 00 44
19B0084FF 00 99
19B008500 01 CD
19B008501 00 EE
19B008502 00 66
19B008503 00 AA
19B008504 04 15
19B008505 00 11
19B008506 00 88
19B008508 34 52
19B008509 00 22
19B00850B 00 88
19B00850C 00 33
19B00850D 00 22
19B00850F 00 44
19B008510 5B 3D
19B008511 17 9F
19B008512 00 66
19B008514 00 CC
19B008515 00 FF
19B008516 00 EE
19B008517 00 88
19B008518 01 89
19B008519 00 33
19B00851A 00 DD
19B00851C 04 C8
19B00851E 00 AA
19B00851F 00 BB
19B008520 20 B9
19B008522 00 CC
19B008523 00 66
19B008524 00 EE
19B008525 00 22
19B008526 00 DD
19B008527 00 88
19B008528 69 B4
19B008529 17 8E
19B00852A 00 AA
19B00852B 00 66
19B00852C 00 AA
19B00852D 00 BB
19B00852E 00 77
19B008530 01 CD
19B008532 00 AA
19B008533 00 BB
19B008534 04 C8
19B008535 00 22
19B008536 00 11
19B008537 00 EE
19B008538 34 F8
19B008539 00 33
19B00853A 00 44
19B00853B 00 22
19B00853D 00 BB
19B00853E 00 22
19B00853F 00 44
19B008541 17 9F
19B008542 00 44
19B008543 00 AA
19B008544 00 77
19B008545 00 44
19B008546 00 66
19B008547 00 77
19B008548 01 32
19B008549 00 AA
19B00854A 00 AA
19B00854B 00 22
19B00854C 04 62
19B00854D 00 EE
19B00854F 00 22
19B008550 30 CF
19B008551 00 33
19B008552 00 33
19B008553 00 CC
19B008554 00 88
19B008555 00 88
19B008556 00 CC
19B008557 00 22
19B008558 81 F6
19B008559 17 DB
19B00855B 00 FF
19B00855C 00 AA
19B00855D 00 33
19B00855E 00 88
19B00855F 00 88
19B008560 01 32
19B008562 00 66
19B008563 00 CC
19B008564 04 15
19B008566 00 99
19B008567 00 DD
19B008568 34 16
19B008569 00 AA
19B00856A 00 77
19B00856B 00 22
19B00856C 00 11
19B00856E 00 BB
19B00856F 00 22
19B008571 17 35
19B008572 00 55
19B008573 00 88
19B008574 00 AA
19B008577 00 44
19B008578 01 AB
19B00857A 00 BB
19B00857B 00 EE
19B00857C 04 FB
19B00857D 00 44
19B00857E 00 EE
19B00857F 00 CC
19B008580 34 25
19B008581 00 11
19B008582 00 AA
19B008583 00 EE
19B008584 00 EE
19B008585 00 EE
19B008587 00 AA
19B008588 9D 15
19B008589 17 42
19B00858A 00 33
19B00858B 00 88
19B00858C 00 BB
19B00858D 00 22
19B00858E 00 66
19B00858F 00 88
19B008590 01 76
19B008591 00 88
19B008592 00 AA
19B008593 00 44
19B008594 04 37
19B008595 00 11
19B008596 00 55
19B008597 00 CC
19B008598 30 65
19B008599 00 88
19B00859A 00 AA
19B00859B 00 44
19B00859C 00 22
19B00859D 00 EE
19B00859E 00 33
19B00859F 00 88
19B0085A2 00 77
19B0085A3 00 AA
19B0085A4 00 88
19B0085A5 00 33
19B0085A6 00 11
19B0085A7 00 CC
19B0085A8 01 FE
19B0085A9 00 88
19B0085AA 00 44
19B0085AB 00 CC
19B0085AC 04 EA
19B0085AD 00 BB
19B0085AE 00 BB
19B0085AF 00 77
19B0085B0 30 A9
19B0085B1 00 22
19B0085B2 00 88
19B0085B3 00 66
19B0085B4 00 FF
19B0085B5 00 44
19B0085B6 00 33
19B0085B7 00 DD
19B0085B8 D3 68
19B0085B9 17 24
19B0085BA 00 44
19B0085BB 00 88
19B0085BC 00 88
19B0085BD 00 CC
19B0085BE 00 FF
19B0085BF 00 CC
19B0085C0 01 32
19B0085C1 00 88
19B0085C2 00 11
19B0085C3 00 77
19B0085C4 04 EA
19B0085C5 00 22
19B0085C6 00 AA
19B0085C7 00 CC
19B0085C8 28 1B
19B0085C9 00 FF
19B0085CA 00 88
19B0085CB 00 CC
19B0085CC 00 55
19B0085CD 00 EE
19B0085CE 00 CC
19B0085CF 00 CC
19B0085D0 E6 4C
19B0085D1 17 8E
19B0085D2 00 AA
19B0085D3 00 EE
19B0085D4 00 33
19B0085D5 00 CC
19B0085D6 00 DD
19B0085D7 00 44
19B0085D8 01 98
19B0085D9 00 AA
19B0085DA 00 EE
19B0085DB 00 EE
19B0085DC 48 D1
19B0085DD 00 22
19B0085DE 00 55
19B0085DF 00 88
19B0085E0 00 99
19B0085E1 00 66
19B0085E2 00 99
19B0085E3 00 44
19B0085E4 00 88
19B0085E5 00 11
19B0085E7 00 44
19B0085E8 F7 E6
19B0085E9 17 BD
19B0085EA 00 99
19B0085EB 00 88
19B0085EC 00 EE
19B0085ED 00 77
19B0085EE 00 11
19B0085EF 00 22
19B0085F0 01 54
19B0085F1 00 33
19B0085F2 00 BB
19B0085F3 00 EE
19B0085F4 04 37
19B0085F5 00 DD
19B0085F6 00 99
19B0085F7 00 99
19B0085F8 38 B0
19B0085F9 00 CC
19B0085FB 00 AA
19B0085FC 00 55
19B0085FD 00 22
19B0085FE 00 66
19B0085FF 00 FF
19B008602 00 FF
19B00860B 00 88
19B00860C 04 26
19B00860E 00 22
19B00860F 00 88
19B008610 20 B9
19B008613 00 66
19B008614 00 EE
19B008615 00 22
19B008616 00 22
19B008619 18 09
19B00861A 00 22
19B00861C 00 22
19B00861D 00 88
19B00861E 00 BB
19B00861F 00 88
19B008621 00 88
19B008622 00 22
19B008624 04 BF
19B008625 00 88
19B008626 00 EE
19B008627 00 88
19B008628 30 9A
19B008629 00 88
19B00862A 00 22
19B00862C 00 99
19B00862F 00 EE
19B008630 30 DE
19B008631 18 3A
19B008632 00 99
19B008634 00 AA
19B008635 00 66
19B008637 00 88
19B008638 01 EF
19B00863A 00 33
19B00863B 00 AA
19B00863D 00 11
19B00863E 00 22
19B008641 00 88
19B008642 00 66
19B008646 00 BB
19B008647 00 99
19B008648 4D D4
19B00864A 00 CC
19B00864B 00 EE
19B00864C 00 AA
19B00864D 00 AA
19B00864E 00 88
19B008651 00 88
19B008652 00 22
19B008654 04 9D
19B008656 00 99
19B008657 00 66
19B008659 00 22
19B00865B 00 22
19B00865C 00 FF
19B00865D 00 AA
19B00865E 00 CC
19B00865F 00 AA
19B008661 18 2B
19B008662 00 99
19B008664 00 99
19B008665 00 88
19B008666 00 88
19B008667 00 EE
19B008668 01 10
19B008669 00 AA
19B00866A 00 BB
19B00866B 00 88
19B00866C 48 E2
19B00866D 00 66
19B00866E 00 EE
19B00866F 00 88
19B008670 00 77
19B008672 00 99
19B008673 00 CC
19B008674 00 AA
19B008675 00 BB
19B008676 00 BB
19B008677 00 AA
19B008678 6C A0
19B008679 18 D4
19B00867A 00 88
19B00867B 00 22
19B00867C 00 AA
19B00867D 00 88
19B00867F 00 AA
19B008680 01 DC
19B008681 00 AA
19B008682 00 EE
19B008683 00 CC
19B008684 04 26
19B008685 00 33
19B008686 00 AA
19B008687 00 AA
19B008689 00 88
19B00868A 00 DD
19B00868B 00 88
19B00868C 00 66
19B00868D 00 88
19B00868E 00 BB
19B00868F 00 99
19B008692 00 CC
19B008693 00 88
19B008694 00 DD
19B008695 00 88
19B008696 00 AA
19B008697 00 88
19B008698 01 10
19B008699 00 99
19B00869A 00 88
19B00869B 00 66
19B00869C 04 15
19B00869D 00 AA
19B00869E 00 66
19B00869F 00 EE
19B0086A0 28 0A
19B0086A1 00 22
19B0086A2 00 BB
19B0086A3 00 BB
19B0086A4 00 66
19B0086A5 00 CC
19B0086A6 00 99
19B0086A9 18 81
19B0086AA 00 33
19B0086AB 00 88
19B0086AC 00 11
19B0086AD 00 AA
19B0086AE 00 22
19B0086AF 00 88
19B0086B0 01 89
19B0086B4 04 15
19B0086B6 00 FF
19B0086B7 00 66
19B0086B8 20 9B
19B0086B9 00 22
19B0086BA 00 55
19B0086BB 00 66
19B0086BC 00 22
19B0086BD 00 44
19B0086BF 00 AA
19B0086C0 9E 70
19B0086C1 18 B2
19B0086C2 00 99
19B0086C3 00 AA
19B0086C4 00 BB
19B0086C5 00 22
19B0086C6 00 BB
19B0086C7 00 44
19B0086C8 01 45
19B0086C9 00 88
19B0086CA 00 88
19B0086CC 04 73
19B0086CD 00 11
19B0086CE 00 11
19B0086CF 00 22
19B0086D0 30 03
19B0086D1 00 BB
19B0086D2 00 55
19B0086D3 00 44
19B0086D4 00 11
19B0086D5 00 22
19B0086D6 00 88
19B0086D7 00 77
19B0086D8 C4 7F
19B0086D9 18 3A
19B0086DA 00 55
19B0086DB 00 AA
19B0086DC 00 BB
19B0086DD 00 44
19B0086DE 00 77
19B0086DF 00 66
19B0086E0 01 98
19B0086E1 00 AA
19B0086E2 00 33
19B0086E3 00 44
19B0086E4 48 59
19B0086E5 00 AA
19B0086E6 00 33
19B0086E7 00 22
19B0086E8 00 EE
19B0086E9 00 CC
19B0086EA 00 11
19B0086EB 00 88
19B0086EC 00 77
19B0086ED 00 AA
19B0086EE 00 EE
19B0086EF 00 CC
19B0086F0 D7 39
19B0086F1 18 09
19B0086F2 00 99
19B0086F3 00 66
19B0086F4 00 88
19B0086F5 00 77
19B0086F6 00 22
19B0086F7 00 AA
19B0086F8 01 10
19B0086FA 00 66
19B0086FB 00 44
19B0086FC D4 5C
19B0086FD 00 88
19B0086FE 00 44
19B0086FF 00 99
19B008700 00 CC
19B008701 00 EE
19B008702 00 66
19B008703 00 AA
19B008704 00 11
19B008705 00 11
19B008706 00 88
19B008708 E3 85
19B008709 18 3A
19B00870B 00 88
19B00870C 00 33
19B00870D 00 22
19B00870F 00 44
19B008710 01 67
19B008711 00 88
19B008712 00 66
19B008714 04 C8
19B008715 00 FF
19B008716 00 EE
19B008717 00 88
19B008718 20 A8
19B008719 00 33
19B00871A 00 DD
19B00871C 00 CC
19B00871E 00 AA
19B00871F 00 BB
19B008720 F2 6B
19B008722 00 CC
19B008723 00 66
19B008724 00 EE
19B008725 00 22
19B008726 00 DD
19B008727 00 88
19B008728 01 DC
19B008729 00 99
19B00872A 00 AA
19B00872B 00 66
19B00872C 04 AE
19B00872D 00 BB
19B00872E 00 77
19B008730 30 FC
19B008732 00 AA
19B008733 00 BB
19B008734 00 CC
19B008735 00 22
19B008736 00 11
19B008737 00 EE
19B008738 02 CE
19B008739 19 2A
19B00873A 00 44
19B00873B 00 22
19B00873D 00 BB
19B00873E 00 22
19B00873F 00 44
19B008741 00 88
19B008742 00 44
19B008743 00 AA
19B008744 04 73
19B008745 00 44
19B008746 00 66
19B008747 00 77
19B008748 38 0B
19B008749 00 AA
19B00874A 00 AA
19B00874B 00 22
19B00874C 00 66
19B00874D 00 EE
19B00874F 00 22
19B008750 0E F1
19B008751 19 2A
19B008752 00 33
19B008753 00 CC
19B008754 00 88
19B008755 00 88
19B008756 00 CC
19B008757 00 22
19B008758 01 76
19B008759 00 CC
19B00875B 00 FF
19B00875C 04 AE
19B00875D 00 33
19B00875E 00 88
19B00875F 00 88
19B008760 34 07
19B008762 00 66
19B008763 00 CC
19B008764 00 11
19B008766 00 99
19B008767 00 DD
19B008768 2C 0E
19B008769 19 B3
19B00876A 00 77
19B00876B 00 22
19B00876C 00 11
19B00876E 00 BB
19B00876F 00 22
19B008771 00 22
19B008772 00 55
19B008773 00 88
19B008774 04 AE
19B008777 00 44
19B008778 30 9A
19B00877A 00 BB
19B00877B 00 EE
19B00877C 00 FF
19B00877D 00 44
19B00877E 00 EE
19B00877F 00 CC
19B008780 3F 2E
19B008781 19 08
19B008782 00 AA
19B008783 00 EE
19B008784 00 EE
19B008785 00 EE
19B008787 00 AA
19B008788 01 89
19B008789 00 55
19B00878A 00 33
19B00878B 00 88
19B00878C 04 BF
19B00878D 00 22
19B00878E 00 66
19B00878F 00 88
19B008790 20 57
19B008791 00 88
19B008792 00 AA
19B008793 00 44
19B008794 00 33
19B008795 00 11
19B008796 00 55
19B008797 00 CC
19B008798 57 02
19B008799 19 91
19B00879A 00 AA
19B00879B 00 44
19B00879C 00 22
19B00879D 00 EE
19B00879E 00 33
19B00879F 00 88
19B0087A2 00 77
19B0087A3 00 AA
19B0087A4 04 8C
19B0087A5 00 33
19B0087A6 00 11
19B0087A7 00 CC
19B0087A8 28 D7
19B0087A9 00 88
19B0087AA 00 44
19B0087AB 00 CC
19B0087AC 00 EE
19B0087AD 00 BB
19B0087AE 00 BB
19B0087AF 00 77
19B0087B0 BA 23
19B0087B1 19 3B
19B0087B2 00 88
19B0087B3 00 66
19B0087B4 00 FF
19B0087B5 00 44
19B0087B6 00 33
19B0087B7 00 DD
19B0087B8 01 BA
19B0087B9 00 33
19B0087BA 00 44
19B0087BB 00 88
19B0087BC 04 8C
19B0087BD 00 CC
19B0087BE 00 FF
19B0087BF 00 CC
19B0087C0 28 1B
19B0087C1 00 88
19B0087C2 00 11
19B0087C3 00 77
19B0087C4 00 EE
19B0087C5 00 22
19B0087C6 00 AA
19B0087C7 00 CC
19B0087C8 DA E9
19B0087C9 19 E6
19B0087CA 00 88
19B0087CB 00 CC
19B0087CC 00 55
19B0087CD 00 EE
19B0087CE 00 CC
19B0087CF 00 CC
19B0087D0 01 AB
19B0087D1 00 99
19B0087D2 00 AA
19B0087D3 00 EE
19B0087D4 D4 E7
19B0087D5 00 CC
19B0087D6 00 DD
19B0087D7 00 44
19B0087D8 00 99
19B0087D9 00 AA
19B0087DA 00 EE
19B0087DB 00 EE
19B0087DC 00 99
19B0087DD 00 22
19B0087DE 00 55
19B0087DF 00 88
19B0087E0 EE 77
19B0087E1 19 7F
19B0087E2 00 99
19B0087E3 00 44
19B0087E4 00 88
19B0087E5 00 11
19B0087E7 00 44
19B0087E8 01 10
19B0087E9 00 AA
19B0087EA 00 99
19B0087EB 00 88
19B0087EC 04 EA
19B0087ED 00 77
19B0087EE 00 11
19B0087EF 00 22
19B0087F0 28 7D
19B0087F1 00 33
19B0087F2 00 BB
19B0087F3 00 EE
19B0087F4 00 33
19B0087F5 00 DD
19B0087F6 00 99
19B0087F7 00 99
19B0087F8 11 99
19B0087F9 1A D6
19B0087FB 00 AA
19B0087FC 00 55
19B0087FD 00 22
19B0087FE 00 66
19B0087FF 00 FF
19B008802 00 FF
19B00880B 00 88
19B00880C 00 22
19B00880E 00 22
19B00880F 00 88
19B008810 20 B9
19B008813 00 66
19B008814 00 EE
19B008815 00 22
19B008816 00 22
19B008819 00 11
19B00881A 00 22
19B00881C 04 26
19B00881D 00 88
19B00881E 00 BB
19B00881F 00 88
19B008821 00 88
19B008822 00 22
19B008824 00 BB
19B008825 00 88
19B008826 00 EE
19B008827 00 88
19B008828 42 E8
19B008829 1A 92
19B00882A 00 22
19B00882C 00 99
19B00882F 00 EE
19B008830 01 EF
19B008831 00 22
19B008832 00 99
19B008834 A0 0A
19B008835 00 66
19B008837 00 88
19B008838 00 EE
19B00883A 00 33
19B00883B 00 AA
19B00883D 00 11
19B00883E 00 22
19B008841 1A 92
19B008842 00 66
19B008846 00 BB
19B008847 00 99
19B008848 01 98
19B00884A 00 CC
19B00884B 00 EE
19B00884C 74 DE
19B00884D 00 AA
19B00884E 00 88
19B008851 00 88
19B008852 00 22
19B008854 00 99
19B008856 00 99
19B008857 00 66
19B008859 1A 38
19B00885B 00 22
19B00885C 00 FF
19B00885D 00 AA
19B00885E 00 CC
19B00885F 00 AA
19B008861 00 33
19B008862 00 99
19B008864 04 9D
19B008865 00 88
19B008866 00 88
19B008867 00 EE
19B008868 28 39
19B008869 00 AA`
What’s the output of these commands?
cmp -n $(stat -c %s Qubes-R4.2.2-x86_64.iso) -l Qubes-R4.2.2-x86_64.iso /dev/sdd | gawk '{printf "%08X %02X %02X\n", $1-1, strtonum(0$2), strtonum(0$3)}' | head
cmp -n $(stat -c %s Qubes-R4.2.2-x86_64.iso) -l Qubes-R4.2.2-x86_64.iso /dev/sdd | gawk '{printf "%08X %02X %02X\n", $1-1, strtonum(0$2), strtonum(0$3)}' | tail
Output:
180006002 62 9D
18000600B 79 F1
18000600C 45 67
18000600E DB F9
18000600F 5A D2
180006010 D5 4C
180006013 8F E9
180006014 06 E8
180006015 F5 D7
180006016 95 B7
Output:
19B00AFF5 00 DD
19B00AFF6 00 99
19B00AFF7 00 99
19B00AFF8 49 C1
19B00AFF9 4D 81
19B00AFFB 00 AA
19B00AFFC 00 55
19B00AFFD 00 22
19B00AFFE 00 66
19B00AFFF 00 FF
I have no idea what could cause the USB disk modification starting with 6442475522 byte and up to 6895480831 byte specifically out of total 6895480831 bytes of the image.
Maybe it’s some issue with USB disks but I don’t know why the re-verification right after write is successful.
Try this:
  • Disconnect the USB disk and connect it back
I have now tried multiple times to re-write the USB in order to try this, but now, it keeps failing the check right away.
Tried a final time to format and re-write the USB, this time with balenaEtcher on Linux. Immediately fails the written media check again. I will buy a new USB and report back. Hopefully maybe that can fix it, in case someone also has the problem in the future. Other than that I don’t know what else to try.
I have successfully installed Qubes with a new USB, in case anyone has this issue in the future.
