I wanted to open this thread as there are many “solutions” I have tried (and broken Qubes with) but nothing seems to be really the right fix right now.
After trying many methods here I think the solution is probably:
Combining RAM-based DispVMs with dom0 live mode (from Whonix thread) using zram (with compression?) with ephemeral encryption on volatile volumes.
why? qubes run ephemerally in RAM, dom0 leaves no traces, and logs/metadata are nullified.
It’s superior to standard DispVMs (which persist logs) and secondary storage wipers (ineffective on SSDs due to wear-leveling).
So i am thinking to start with ZRAM setup with compression: (with maybe lz4?)
Continuing from the topic and making guide for those interested in, as well as a reminder for myself after clean install someday.
Goals / Possible Benefits
To minimize dedicated amounts of RAM
To maximize utilizing total amount of RAM
To extend lifespan of a SSD
Hopefully to reduce Qubes footprint
To increase overall performance
To prevent performance hits to a level at least as without zram.
Why?
By default swappiness is set to 60. This means that when 40% of RAM is used, swapping is start…
then
I’d like to reiterate that there is a better path towards anti-forensic DisposableVMs:
People might want to focus their energy on generalizing the already existing Qubes OS support for ephemerally encrypted ‘root’ volumes to ‘private’ volumes, which would entail something like the WIP in marmarek/qubes-linux-utils@volatile-thin-pool from, oh wow, 2016. That’s a much cleaner approach to anti-forensic DisposableVMs (#904 ) than creating and tearing down pools.
More generally, from #904 :
The …
dom0 in live mode
with Ephemeral Thin-Pool Full (encrypted volatile/private)
opened 12:39PM - 11 Nov 23 UTC
closed 02:30PM - 07 Dec 24 UTC
C: core
P: default
C: storage
affects-4.1
eol-4.1
### Qubes OS release
4.1.2
### Brief summary
`qvm-*` command line t… ools report unrealistic storage usage for disposable qubes.
### Steps to reproduce
Create a 1 GiB RAM based pool:
user@dom0:~ > mkdir -p ~/tmp/mydir
user@dom0:~ > sudo mount --types tmpfs --options size=1G my_ram_pool /home/user/tmp/mydir
user@dom0:~ > qvm-pool add my_ram_pool file --option revisions_to_keep=1 --option dir_path="${HOME}/tmp/mydir"
Create a named disposable qube:
user@dom0:~ > qvm-create --class DispVM AAA -P my_ram_pool --label=red
user@dom0:~ > qvm-pool info my_ram_pool | grep usage
usage 0
Start the qube:
user@dom0:~ > qvm-run AAA xterm
and create a 500 MiB in it:
user@AAA:~ > dd if=/dev/urandom of=~/500mb.img bs=4k iflag=fullblock,count_bytes count=500M
128000+0 records in
128000+0 records out
524288000 bytes (524 MB, 500 MiB) copied, 1.59195 s, 329 MB/s
user@AAA:~ > ls -l 500mb.img
-rw------- 1 user user 524288000 2023-11-11 14:11:37 500mb.img
Check space usage in dom0:
user@dom0:~ qvm-pool info my_ram_pool | grep usage
usage 8192
user@dom0:~ > df -h ~/tmp/mydir/
Filesystem Size Used Avail Use% Mounted on
my_ram_pool 1.0G 8.0K 1.0G 1% /home/user/tmp/mydir
user@dom0:~ > ls -l ~/tmp/mydir/appvms/AAA/volatile.img
-rw-r--r-- 1 root root 12884901888 2023-11-11 14:10:25 /home/user/tmp/mydir/appvms/AAA/volatile.img
user@dom0:~ > du -hs ~/tmp/mydir/appvms/AAA/volatile.img
8.0K /home/user/tmp/mydir/appvms/AAA/volatile.img
user@dom0:~ > qvm-volume info AAA:volatile | grep -E '(size|usage)'
size 12884901888
usage 8192
### Expected behavior
The numbers reported by the `qvm-` tools should match actuality. Then one can know how much space is left in a pool etc.
### Actual behavior
For any running DispVM the reported usage is always 8 KiB and the reported volatile volume size (as well as volatile.img file size) is always 12 GiB.
12 GiB is obviously much more than the actual capacity of the pool (only 1 GiB). The actual "disk" space used by the content inside the qube itself (500 MiB) is obviously much more than the 8 KiB reported by the qvm- tools.
It seems this happens only with disposables. For AppVMs it is possible to see actual increase of space usage while the qube is running.
I know there is the thread with @qubist (amazing work) that had alot of collaboration and I don’t want to thread hijack that one but just leave this open for more discussion.
Although that is a great solution I still think there is more dialogue needed.
I was also interested in what @rustybird commented
The …
that there maybe a simpler, less messy solution that I am unaware of now.
This is rough idea and wont work obviously but maybe something like a qubes-ephemeral manager?
#!/bin/bash
set -e
SCRIPT_VERSION="1.0.0"
SCRIPT_NAME="Qubes Ephemeral Volume Manager"
RED='\033[0;31m'
GREEN='\033[0;32m'
YELLOW='\033[1;33m'
BLUE='\033[0;34m'
CYAN='\033[0;36m'
NC='\033[0m'
show_header() {
clear
echo -e "${CYAN}═══════════════════════════════════════════════════════════${NC}"
echo -e "${CYAN} ${SCRIPT_NAME} v${SCRIPT_VERSION}${NC}"
echo -e "${CYAN} Manage truly ephemeral Qubes volumes with RAM-only encryption${NC}"
echo ""
show_info() {
echo -e "${BLUE}ℹ${NC} $1"
show_success() {
echo -e "${GREEN}✓${NC} $1"
show_warning() {
echo -e "${YELLOW}⚠${NC} $1"
show_error() {
echo -e "${RED}✗${NC} $1"
check_qubes_environment() {
if ! command -v qvm-volume &> /dev/null; then
show_error "This script must be run in Qubes OS dom0"
show_error "qvm-volume command not found"
exit 1
fi
if ! command -v qvm-pool &> /dev/null; then
show_error "qvm-pool command not found"
exit 1
fi
check_volume_properties() {
local vm_name="$1"
local volume_name="$2"
local snap_on_start=$(qvm-volume info "${vm_name}:${volume_name}" | grep "snap_on_start:" | awk '{print $2}')
local save_on_stop=$(qvm-volume info "${vm_name}:${volume_name}" | grep "save_on_stop:" | awk '{print $2}')
if [[ "$snap_on_start" != "False" ]] || [[ "$save_on_stop" != "False" ]]; then
return 1
fi
return 0
display_volume_info() {
local vm_name="$1"
echo ""
echo -e "${CYAN}Volume Information: ${vm_name}:${volume_name}${NC}"
echo "────────────────────────────────────────────────"
qvm-volume info "${vm_name}:${volume_name}" 2>/dev/null | grep -E "(ephemeral|snap_on_start|save_on_stop|size|pool)" | while read line; do
if echo "$line" | grep -q "ephemeral.*True"; then
echo -e "${GREEN}${line}${NC}"
elif echo "$line" | grep -q "ephemeral.*False"; then
echo -e "${YELLOW}${line}${NC}"
else
echo "$line"
fi
done
echo ""
list_all_vms() {
echo -e "${CYAN}Available VMs:${NC}"
qvm-ls --raw-list | sort
echo ""
list_vm_volumes() {
local vm_name="$1"
if ! qvm-ls --raw-list | grep -q "^${vm_name}$"; then
show_error "VM '${vm_name}' not found"
return 1
fi
echo ""
echo -e "${CYAN}Volumes for VM: ${vm_name}${NC}"
qvm-volume list "$vm_name" 2>/dev/null
echo ""
show_vm_ephemeral_status() {
local vm_name="$1"
return 1
fi
echo ""
echo -e "${CYAN}Ephemeral Status for: ${vm_name}${NC}"
echo "════════════════════════════════════════════════"
for volume in root private volatile; do
if qvm-volume info "${vm_name}:${volume}" &>/dev/null; then
local ephemeral=$(qvm-volume info "${vm_name}:${volume}" 2>/dev/null | grep "ephemeral:" | awk '{print $2}')
local snap_on_start=$(qvm-volume info "${vm_name}:${volume}" 2>/dev/null | grep "snap_on_start:" | awk '{print $2}')
local save_on_stop=$(qvm-volume info "${vm_name}:${volume}" 2>/dev/null | grep "save_on_stop:" | awk '{print $2}')
printf "%-12s " "$volume:"
if [[ "$ephemeral" == "True" ]]; then
echo -e "${GREEN}✓ EPHEMERAL ENABLED${NC} (RAM-only encryption)"
elif [[ "$snap_on_start" == "False" ]] && [[ "$save_on_stop" == "False" ]]; then
echo -e "${YELLOW}○ Eligible for ephemeral${NC} (snap_on_start=False, save_on_stop=False)"
else
echo -e " Not eligible (snap_on_start=$snap_on_start, save_on_stop=$save_on_stop)"
fi
fi
done
echo ""
show_pool_info() {
local pool_name="$1"
if ! qvm-pool list | grep -q "^${pool_name} "; then
show_error "Pool '${pool_name}' not found"
return 1
fi
echo ""
echo -e "${CYAN}Pool Information: ${pool_name}${NC}"
qvm-pool info "$pool_name" 2>/dev/null | grep -E "(ephemeral_volatile|driver|dir_path|usage|size)" | while read line; do
if echo "$line" | grep -q "ephemeral_volatile.*True"; then
elif echo "$line" | grep -q "ephemeral_volatile.*False"; then
else
echo "$line"
fi
done
echo ""
list_pools() {
echo ""
echo -e "${CYAN}Available Storage Pools:${NC}"
qvm-pool list
echo ""
enable_volume_ephemeral() {
local vm_name="$1"
return 1
fi
if ! qvm-volume info "${vm_name}:${volume_name}" &>/dev/null; then
show_error "Volume '${volume_name}' not found for VM '${vm_name}'"
return 1
fi
if ! check_volume_properties "$vm_name" "$volume_name"; then
show_error "Volume ${vm_name}:${volume_name} is not eligible for ephemeral encryption"
show_warning "Ephemeral encryption requires snap_on_start=False AND save_on_stop=False"
show_info "Only volatile volumes typically meet these requirements"
return 1
fi
show_info "Enabling ephemeral encryption for ${vm_name}:${volume_name}..."
if qvm-volume set "${vm_name}:${volume_name}" ephemeral True 2>/dev/null; then
show_success "Ephemeral encryption enabled successfully!"
show_info "Volume will be encrypted with a RAM-only key on next VM start"
display_volume_info "$vm_name" "$volume_name"
return 0
else
show_error "Failed to enable ephemeral encryption"
return 1
fi
disable_volume_ephemeral() {
local vm_name="$1"
return 1
fi
return 1
fi
show_info "Disabling ephemeral encryption for ${vm_name}:${volume_name}..."
if qvm-volume set "${vm_name}:${volume_name}" ephemeral False 2>/dev/null; then
show_success "Ephemeral encryption disabled successfully!"
return 0
else
show_error "Failed to disable ephemeral encryption"
return 1
fi
enable_pool_ephemeral() {
return 1
fi
show_info "Enabling ephemeral_volatile for pool: ${pool_name}..."
show_warning "This will affect all DispVM volatile volumes using this pool"
if qvm-pool set "$pool_name" -o ephemeral_volatile=True 2>/dev/null; then
show_success "Pool ephemeral_volatile enabled successfully!"
show_info "All new DispVMs using this pool will have ephemeral volatile volumes"
show_pool_info "$pool_name"
return 0
else
show_error "Failed to enable pool ephemeral_volatile"
return 1
fi
disable_pool_ephemeral() {
return 1
fi
show_info "Disabling ephemeral_volatile for pool: ${pool_name}..."
if qvm-pool set "$pool_name" -o ephemeral_volatile=False 2>/dev/null; then
show_success "Pool ephemeral_volatile disabled successfully!"
return 0
else
show_error "Failed to disable pool ephemeral_volatile"
return 1
fi
scan_ephemeral_volumes() {
echo ""
echo -e "${CYAN}Scanning All VMs for Ephemeral Volumes...${NC}"
local found_ephemeral=false
while IFS= read -r vm; do
if qvm-volume info "${vm}:${volume}" &>/dev/null; then
local ephemeral=$(qvm-volume info "${vm}:${volume}" 2>/dev/null | grep "ephemeral:" | awk '{print $2}')
echo -e "${GREEN}✓${NC} ${vm}:${volume} - EPHEMERAL ENABLED"
found_ephemeral=true
fi
fi
done
done < <(qvm-ls --raw-list)
if ! $found_ephemeral; then
show_info "No volumes with ephemeral encryption found"
fi
echo ""
echo -e "${CYAN}Storage Pool Ephemeral Settings:${NC}"
while IFS= read -r line; do
local pool_name=$(echo "$line" | awk '{print $1}')
if qvm-pool info "$pool_name" 2>/dev/null | grep -q "ephemeral_volatile.*True"; then
echo -e "${GREEN}✓${NC} $pool_name - ephemeral_volatile ENABLED"
fi
done < <(qvm-pool list | tail -n +2)
echo ""
interactive_menu() {
while true; do
show_header
echo -e "${CYAN}Main Menu:${NC}"
echo " 1) View VM ephemeral status"
echo " 2) Enable ephemeral encryption on volume"
echo " 3) Disable ephemeral encryption on volume"
echo " 4) Enable pool-wide ephemeral for DispVMs"
echo " 5) Disable pool-wide ephemeral for DispVMs"
echo " 6) Scan all ephemeral volumes"
echo " 7) List all VMs"
echo " 8) List storage pools"
echo " 9) Show detailed volume information"
echo " h) Help and information"
echo " q) Quit"
echo ""
read -p "Select option: " choice
case $choice in
1)
echo ""
read -p "Enter VM name: " vm_name
show_vm_ephemeral_status "$vm_name"
read -p "Press Enter to continue..."
2)
echo ""
read -p "Enter volume name (usually 'volatile'): " volume_name
enable_volume_ephemeral "$vm_name" "$volume_name"
3)
echo ""
read -p "Enter volume name: " volume_name
disable_volume_ephemeral "$vm_name" "$volume_name"
4)
echo ""
list_pools
read -p "Enter pool name (usually 'vm-pool'): " pool_name
enable_pool_ephemeral "$pool_name"
5)
echo ""
list_pools
read -p "Enter pool name: " pool_name
disable_pool_ephemeral "$pool_name"
6)
7)
list_all_vms
8)
list_pools
9)
echo ""
h|H)
show_help
q|Q)
echo ""
show_info "Exiting..."
exit 0
show_error "Invalid option"
sleep 1
esac
done
show_help() {
show_header
echo -e "${CYAN}What are Ephemeral Volumes?${NC}"
echo "Ephemeral volumes are encrypted with a temporary key stored"
echo "only in RAM. When the system shuts down, the key is lost,"
echo "making the data unrecoverable."
echo ""
echo -e "${CYAN}Security Benefits:${NC}"
echo " • Enhanced anti-forensics protection"
echo " • Protection against cold-boot attacks"
echo " • Data is truly ephemeral and cannot be recovered"
echo " • Useful for DispVMs and sensitive operations"
echo ""
echo -e "${CYAN}Requirements:${NC}"
echo " • Only works on volatile volumes"
echo " • Volume must have snap_on_start=False"
echo " • Volume must have save_on_stop=False"
echo ""
echo -e "${CYAN}Usage Examples:${NC}"
echo " ${GREEN}Per-VM Configuration:${NC}"
echo " qvm-volume set my-vm:volatile ephemeral True"
echo ""
echo " ${GREEN}Pool-Wide for DispVMs:${NC}"
echo " qvm-pool set vm-pool -o ephemeral_volatile=True"
echo ""
echo -e "${CYAN}Performance Note:${NC}"
echo " Ephemeral encryption adds an extra encryption layer,"
echo " which may slightly degrade performance."
echo ""
show_usage() {
echo "Usage: $0 [OPTIONS]"
echo ""
echo "Options:"
echo " -i, --interactive Launch interactive menu (default)"
echo " -s, --scan Scan and display all ephemeral volumes"
echo " -e, --enable VM:VOLUME Enable ephemeral encryption on volume"
echo " -d, --disable VM:VOLUME Disable ephemeral encryption on volume"
echo " -p, --pool-enable POOL Enable ephemeral_volatile on pool"
echo " -P, --pool-disable POOL Disable ephemeral_volatile on pool"
echo " -v, --view VM View VM ephemeral status"
echo " -h, --help Show this help message"
echo ""
echo "Examples:"
echo " $0 --scan"
echo " $0 --enable my-vm:volatile"
echo " $0 --pool-enable vm-pool"
echo " $0 --view my-dispvm"
echo ""
main() {
if [[ $# -eq 0 ]]; then
interactive_menu
exit 0
fi
case "$1" in
-i|--interactive)
interactive_menu
-s|--scan)
show_header
-e|--enable)
if [[ -z "$2" ]] || [[ ! "$2" =~ ^[^:]+:[^:]+$ ]]; then
show_error "Invalid format. Use: VM:VOLUME"
exit 1
fi
show_header
IFS=':' read -r vm_name volume_name <<< "$2"
-d|--disable)
exit 1
fi
show_header
-p|--pool-enable)
if [[ -z "$2" ]]; then
show_error "Pool name required"
exit 1
fi
show_header
enable_pool_ephemeral "$2"
-P|--pool-disable)
exit 1
fi
show_header
disable_pool_ephemeral "$2"
-v|--view)
show_error "VM name required"
exit 1
fi
show_header
show_vm_ephemeral_status "$2"
-h|--help)
show_header
show_usage
echo ""
show_help
show_error "Unknown option: $1"
show_usage
exit 1
esac
main "$@"
qubist
October 31, 2025, 7:59pm
3
@James369
If you make dom0’s journal volatile (or disable it completely) and use RAM-based disposables, I think that this can be considered truly disposable (though it can’t save one from karmic consequences).
ZRAM/compression and similar gym seems to me a CPU overhead and additional complexity.
Why combined with Zram / Compression? for those of us with not so much RAM, running Dom0 in RAM and increasing its RAM usage is not really feasible without a more efficient RAM utilization / swap / compression. Encrypted RAM also seems necessary.
Yes I agree it could lead to more CPU overhead I will try it. Ultimately it would be great to have the choice (as we do now with normal DispVMs), of which VM’s / disposables we would like to run in RAM.
Ideally I would like to be able to run dom0 as usual to make changes etc, and run / update other qubes and at the same time be able run a few qubes that are truly disposable in RAM.
Which is why I thought a ephemeral manager would be good. To be able to start, then wipe dispVM’s and also to better manage DispVM’s footprints.
I have other ongoing tasks and rarely reboot.
Having to go through the whole dom0 live process just run a truly DispVM is most unfortunately not really a solution to me. ( I also don’t have that much RAM).
qubist
November 3, 2025, 6:27pm
5
I am not sure I understand.
What is your actual goal with a VM being truly disposable?
What do you mean by:
running Dom0 in RAM
Why is it necessary and how is it related to having truly disposable domUs? (which IIUC is your desire)
For what?
rzg
November 4, 2025, 2:43pm
6
My opinion:
Avoid charges for war crimes in the International Criminal Court and for plotting coup when devices was forensically examined.
I agree.
Cold boot attack
https://www.forensicfocus.com/forums/general/freezing-ram-to-retain-data/
Sorry if I wasn’t clear.
The goal is the same with the current Kicksecure live mode.
Anti-forensics as well as leaving minimal traces on Dom0 of activities.
(as you can see when running your cleanup script, records of every dispVM etc…)
The current solutions as far as I can see here are:
Running dom0 in RAM:
Qubes dom0 ZRAM Live Mode
Qubes dom0 OverlayFS Live Mode
and your script:
Really disposable (RAM based) qubes
The advantages of dom0 in live mode seems to be better than deleting logs with a script as the latter can be quite easily found even after deleting.
The first solution requires copying the entire dom0 to RAM at boot, via a grub change.
Perhaps just mounting some directories in RAM rather than copying the whole dom0 ie:
[zram0]
zram-size = 8G
compression-algorithm = zstd
mount-point = /var
[zram1]
zram-size = 2G
mount-point = /tmp
Encrypted RAM not only for cold-boot attacks, side-chain etc…
qubist
November 5, 2025, 3:10pm
8
@James369
Consider this explanation:
Maybe use shred or wipe to delete logs? That would make your script truly antiforensic
Without firmware access, effective file-level shredding is simply not possible on SSD due to the way hardware works. If you look at the script, you will see it does something (IMO) better:
# Create void symlinks to prevent log saving
for file in "${logfiles[@]}"; do
sudo ln -sfT /dev/null "${file}"
done
I.e. no logging actually occurs (even to RAM). The only persistent info that remains is the metadata t…
and the man page of journald.conf:
Storage=
Controls where to store journal data. One of "volatile",
"persistent", "auto" and "none". If "volatile", journal log data
will be stored only in memory, i.e. below the /run/log/journal
hierarchy (which is created if needed).
Could you please explain what forensic traces in dom0 you are concerned with?
The ephemeral keys used by qvm-pool protect the pool (the “disk” of the VM) but not its memory. AFAIK, effective RAM encryption requires kernel-level support and/or proper hardware.
The only Xen-related thing I found is this:
https://lists.xenproject.org/archives/html/xen-devel/2017-07/msg01534.html
There is also:
Perhaps you know all that.
rzg
November 5, 2025, 3:52pm
9
1. Isn’t implementing rules for BleachBit shred in dom0 an easier solution?
The challange is the in-system data sanitization (not the whole disk). Can the DISCARD command (fstrim) also mark Logical Block Addressing as unused without the inconvenience of deleting all data?
Disk trimming is the procedure by which the operating system informs the underlying storage device of which storage blocks are no longer in use. It does this by issuing an ATA_TRIM command for the block. This is also known as a discard. In this way, the storage device can perform garbage collection of the unused blocks and internally prepare them for reuse. SSDs in general benefit from this, while HDDs do not.
In a Linux system running on bare metal, this is relatively straight-forward. When in…
Wear leveling (also written as wear levelling) is a technique for prolonging the service life of some kinds of erasable computer storage media, such as flash memory, which is used in solid-state drives (SSDs) and USB flash drives, and phase-change memory.
The idea underpinning wear leveling is similar to changing position of car tires, avoiding repetitive load from being used on the same wheel. Wear leveling algorithms distribute writes more evenly across the entire device, so no block is used m...
Plausible deniability is a social tactic that allows people to deny knowledge, participation, or an active role in carrying out an activity, relaying a loaded message, etc. The deniability exists due to a lack of culpable evidence, or more commonly, from multiple plausible intrepretations of the present evidence. Plausible deniablity is prime shield of defense against accountability, and forms the basis of covert attacks that make up human social behavior.
In a chain of command, senior officia...
2. Regarding memory encryption, something that protects against memory corruption vulnerabilities may already be a step forward in Qubes:
Hardened Malloc
Hardened allocator designed for modern systems. It has integration into Android's Bionic libc and can be used externally with musl and glibc as a dynamic library for use on other Linux-based platforms. It will gain more portability / integration over time.
qubist
November 5, 2025, 7:34pm
10
Recommended reading for anyone chasing disposability for hiding whatever:
