After Yubikey settings, can't login
Dear,
I m new user of QubesOs.
I set my yubikey like explain in the documentation.
I add the line : auth include yubikey
In the 2 next files :
/etc/pam.d/xscreensaver
/etc/pam.d/lightdm
But since I wrote it in lightdm , when I write my password on the lockscreen it tells me that my password is incorrect and I can t use my yubikey.
Does someone have an idea to fix this point ?
Thanks
Have you added the line to the beginning of the files?
Is your Yubikey attached? Not only physically, but also to the correct domain?
Are you entering the correct password (the one associated with Yubikey)?
