Hi, I have a Lenovo laptop Gen 4 X1 Carbon running the latest Qubes 4.1
When I shut down the laptop, it appears to be shut down, all lights are off. Then I noticed it stays slightly warm, with a very subtle high pitched sound if you put your ear to the bottom of it.
When it is shut down like this, I cannot turn the laptop back on using the power button. If I hold the power button for a long time the high pitch sound stops and then I would say it if fully shut down.
Once this happens, 1 press of the power button and the laptop boots normally
Very strange, and something that I have never seen before. Any ideas?
Exactly how do you power down the computer?
Do you use the screen shutdown?
and choose shutdown? Not Sleep or hibernate?, or log out?
Or do you quick press the power button to do a shutdown? Which puts it into computer into sleep or hibernation mode.
Windows 10 once did this thing. where when when after it was supposedly powered down, it would keep the drive active, to facilitate a fast start. The code to fix that once maybe being in one of several different places inside the Windows 10 OS itself. Perhaps in Windows 10 area of Power Controls.
Might be Qubes does not send the correct code for a full power down, for that model computer. I can’t help you with that.
I shut down by clicking my user name, and the drop down menu with “shut down”
Even though it seems fully shut down, unless i hold the power button for like 5+ seconds, i eventually hear that very slight high pitched sound stop.
I am new to Qubes and loving it, although taking some time to adjust, it is so good how to can compartmentalize so many things. I eventually want to buy a Librem 14 with Qubes. But i am using this old Lenovo to practice on first.
It is probably not that big a deal doing a hard shut down after this mini shutdown, but it is certainly strange, since the X1 Carbon gen 4 is pretty old now
It was originally a Windows laptop though bought from Lenovo, if it might has some windows crap in bios that could be causing it?
Hi there. I know it was 3 years ago, but I bought legeion slim 5 16( wirth Ryzen) and have exactly the same problem. I shutted down my laptop , and today in the morning I realised that it was still warm with high pitched sound ( which I can notice only when my ear on laptop keyboard). Today I will do some actions like turn off fast startup, update windows and turn off always USB on. But , can you exactly explain what did you do then if you could remember, please? Appreciate in advance. My laptop pretty expensive and i worry about it functionality if this problem stays.
