Could you please explain how I can do this.
Selecting the Xen …25.config
all options show the error of the last picture I uploaded
error: you need to load the kernel first.
Press any key to continue...
Selecting the Xen…4.8 and continue launching all ends in a frozen login screen (as before)
I have seen in the GRUB Boot Menu e and c allow additional option to launch. Is there any way to launch with a limited launcher “rescue mode” to be able to login in and fix the issue ?
PS: Maybe this give more insights: This is the display when I click on the power off button:
@deeplow could you help or point me to someone who or some docs which could help me?
Or would you suggest to “simple” reinstall a blank Qubes and restore the last backup?
Hi @whoami. I’ve been tracking this thread but didn’t say much since I don’t know how to help you in this case (not much experience with the boot process).
The only thing that I can say unless it’s because of lack of disk space, the installation of Transmission should not have caused this, otherwise it would mean that some of the security properties of Qubes be broken.
At this point, you can try to get a TTY terminal by pressing Ctrl+Alt+F2 (or any other F-key). You can press Ctrl+Alt+F1 to get back on the login screen. But I woudn’t know what to do after that.
Maybe someone more knowledgeable wants to jump in on the conversation.
Did you recently try to create the sys-usb qube via qubesctl?
If so, you might have locked yourself out of being able to use the keyboard/mouse once Qubes starts to boot (after GRUB)
My question that asked if other kernels boot meant - try to select kernels 4.19.132-1 or 4.19.94-1 as shown in your 6th image.
If you’re able, take a screenshot after you hit “e” in GRUB to edit the startup options so that we can see the kernel command line (this will have “vmlinuz” on the same line).
Can you clarify when exactly you are getting the “you need to load the kernel first” error from GRUB vs when you’re able to get to the login screen (but looks frozen)?
I have a sys-usb and it works (worked) for a long time. But you are right I also thought this could be somehow the issue. I just reinstalled with sys-firewall and sys-net only. I will do a sys-usb manually (not from backup) since it froze my previous res installation.
I have tested several things but I could not reproduce the frozen login screen.
Anyway, a re-installation plus restore Qubes (backup) set my system back to normal.
