After hard crash of QubesOS 4.3: Check of pool qubes_dom0/vm-pool failed
I am running a QubesOS 4.3 setup with a MooltiPass hardware password manager integrated with the CTAP proxy. Works like a charm, but occasionally the system hard crashes when unplugging the MooltiPass. Until yesterday that was just inconvenient and rebooting brought everything back up.
Following a crash/reboot cycle yesterday, dom0 boots and the GUI is rudimentarily functional, but qubesd and all sys-* appVMs fail to start.
qubes is stuck in a restart loop that systemctl start/stop can overcome.
Using systemctl to start the appVM services, however, fails with
Error: Check of pool qubes_dom0/vm-pool failed (status:64). Manual repair required!
I attempted the repair unsing
PROMPT:# lvchange -an /dev/qubes_dom0/vm*
PROMPT:# lvconvert --repair qubes_dom0/vm-pool
That, unfortunately produces the error
Transaction ID 341668 from poom "qubes_dom0/vm-pool" does not match repaired transaction id 341667 from /dev/qubes_dom0/lvoll_pmspare.
Is that fixable and if yes, how?
Thank you for any pointers.
When you get your system working again, can you share the journal of the last boot of dom0 and sys-usb?
On dom0:
sudo journalctl -b -1
And for sys-usb, still on dom0, the file:
/var/log/xen/console/guest-sys-usb.log
I don’t know.
Search the forum for "repaired transaction id", e.g.
