Advanced Network Fingerprint & Qubes: Will they know?
I often use Qubes when I need the highest levels of security or anonymity. I usually do not use Qubes when I don’t need that and in part this is to look more normal when I do normal activity.
I increasingly am concerned with network fingerprinting where a combination of MTU and latency and packet loss and TTL are being used to guess who I am. I dont think these things are always protected by a VPN and ask if the Tor network even fully protects against someone coming into the Tor network with a more unique network fingerprint.
I am considering moving to Qubes for all of my activities. I have concerns about doing this. I do not want any big tech, banks, Amazon, Facebook, Telegram, Google, X, Duckduckgo (Microsoft Bing) and even a VPN to know I use Qubes. I do not want this because it put me into a narrow pool of users. Many big tech players own part of the infrastructure (AWS… Azure) and it makes it harder to avoid network fingerprints.
I know that having multiple Qubes prior to using something like a browser in Debian is going to increase my TTL. I am not sure if it also increases my packet loss or does other unusual things. I usually alter my MTU slightly as it is for my network setup and worry that it makes me stand out but I get incredibly slow speeds if I don’t lower MTU. I am worried that it may still alter my network characteristics in ways I cant predict.
I also am concerned about the detection of the screen using javascript. Normally when I am on a webpage it run code locally using javascript and it is sensing my screen width and height etc. In Qubes the browser is contained in a small window. Does this stand out?
Is dom0 still using X11? I dont know if malicious Apps can see everything through X11 within the same Qube. I am not sure if I can use Wayland within a Qube if dom0 uses x11.
Is it pointless to believe that Qubes usage can be hidden from advanced adversaries?
If you used clean from scratch new email address and registered through multiple vpns and in a vm then the biggest attack vector for them will be you downloading Qubes. Then you also have the problem with updating Qubes. As I learned each template has Qubes repository enabled in them. So if you update a standalone vm qube manually you will get exposed. You also will need to make sure you use a vpn/proxy for the update qube and you will need to make sure it does not leak your ip
Also if you install any program from big tech like telegram or zoom for example they can see that you use Qubes
But the biggest issue in hiding the fact that you use Qubes is - you not having experience with Qubes when you start out. You will make mistakes and those mistakes will expose you
I have experience with Qubes.
I don’t use it for everything. Is there a way to use it for everything while concealing from personal KYC activities that I am using Qubes or will it be clear to them, even if I am doing something like running in a Windows Qube, etc?
I also think with network fingerprinting they may be able to figure it out. Does Qubes give off a unique network fingerprint?
