I have a disposable netVM running from a template, default-dvm-wifi that stores my home wifi password ( the template is just cloned from the system’s default VM fedora 39 but with a wifi connection set).
I’ve had to change my wifi password. I’d like to change the password in default-dvm-wifi, however every time I try to use nmcli, I get
Warning: nmcli (1.44.2) and NetworkManager (Unknown) versions don't match. Restarting NetworkManager is advised.
Error: NetworkManager is not running.
and
$ sudo systemctl start NetworkManager
appears to do nothing. I can’t get off first base.
Since I have a regularly updated system, and I trust the Qubes team to be on top of things, I’m not going to worry about the version mismatch except that I have to get past this.
What is the right way to go about this, if nmcli is not the tool?
