Adding needs-issue and needs-doc tags?
For some time now, when I encounter a topic or a post where I think that I could open an issue or edit the documentation, I bookmark it and I use the description of the bookmark as a way to tag it, either with needs-issue or needs-doc.
Later, I can then review my bookmarks and look for any of those “tags” and, eventually, open an issue or edit the documentation but that’s not so convenient.
I was wondering if it could be a good idea to use the forum tags to handle this?
It would be more effective and efficient to have two separate bookmark folders for issues or documentation. If the upstream issue or documentation becomes resolved, then the topics’ tags would also need to be updated, which creates unneccessary manual maintenance.
It’s cool that you are trying to systematize a way to follow-up on topics and cross-linking them to github. We need a lot of that.
You should now have the requested tags.
Thanks for your work!
Thanks, @parulin! There are a few of us here that can’t use GitHub for one reason or another, and we appreciate you.
