hi, i use qubesos on a T490 with debian template as default.
i want to set up a vpn in a way that disable non vpn/tor connections, use my proton vpn for everything except qubes that run under tor and my work qube, which will use a custom wg vpn.
i didn’t manage to find similar setups online, and i do not understand how almost all of this networking black magic works, so sorry for my ignorance.
if there are any questions, please feel free to ask!
All you have to do is to attach the qubes you want to the net qube you want.
If you want to use the custom wg qube for work, attach work to that net qube.
If you want to use Tor for some specific qubes, attach them to sys-whonix
if you want to use protonvpn for everything else, set it the default net qube in global config so all new qubes will use it by default.
