Adding a key for a yum repository inside a template
I’m looking to install 1Password inside a template via their instructions here: Get the 1Password for Linux app. I’m realizing now that since the template has no network access, I cannot perform 1 and 2 of the three steps in these instructions.
What is the correct way to do this in Qubes? I’m looking for best practices here.
Thanks in advance!
I would split the first step in two:
  1. download the key to a disposable qube (didpVM) and verify it there, then copy it to the template (qvm-copy or “Copy to VM”)
  2. in the template, import it into rpm
Does that make sense to you?
Edit: What prevents you from performing the second of the three steps?
Misread second step. You’re totally right about it not needing net access. This is perfect!
