I would like to make custom events to be listened by the qubes.events.EventDispatcher.
So currently, if I would like to do something on domain startup I could do something like this:
import qubesadmin.events
import qubesadmin
import asyncio
def print_starting_domain(*args, **kwargs):
print(args)
print(kwargs)
qubes = qubesadmin.Qubes()
dispatcher = qubesadmin.events.EventsDispatcher(qubes)
dispatcher.add_handler("domain-start", print_start_domain)
loop = asyncio.new_event_loop()
asyncio.set_event_loop(loop)
loop.run_until_complete(
asyncio.ensure_future(dispatcher.listen_for_events())
loop.run_forever()
This code allows me to handle and get the vm information on startup. Now, I would like to do something similar but add my custom event (e.g. handle-vm-network).
I found that (AppVM, TemplateVM, AdminVM, DispVM, and StandaloneVM) under qubes.vm are childs of qubes.events.Emitter. So, I would like to use something as follow and receive the event using qubes.events.EventsDispatcher
import qubes
class MyClass(qubes.events.Emitter):
def __init__(self) -> None:
super().__init__()
self.events_enabled = True
my_class = MyClass()
my_class.fire_event('handle-vm-network')
Now, I would like to see the handle-vm-network event in my previous code. Is there away to do so?
