Hello everyone,
Firstly, thanks to all the community of Qubes that allowed me to install Qubes and have it properly running.
Here my qubes HCL report:
layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Acer
model: |
Aspire AV15-51
bios: |
V1.08
cpu: |
11th Gen Intel(R) Core(TM) i5-1155G7 @ 2.50GHz
cpu-short: |
FIXME
chipset: |
00.0 Host bridge [0600]: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers [8086:9a14] (rev 02)
chipset-short: |
FIXME
gpu: |
02.0 VGA compatible controller [0300]: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] [8086:9a49] (rev 03) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
14.3 Network controller [0280]: Intel Corporation Wi-Fi 6 AX201 [8086:a0f0] (rev 30)
00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
memory: |
16163
scsi: |
usb: |
1
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.3
xen: |
4.17.5
kernel: |
6.6.48-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
I have suspend/resume issue and after searching for a solution for a couple of days I saw that it is quite common for Qubes. Solving this issue seems quite complicated considering all the different hardwares possible, so I know there is very little chance that it will work. I created this topic to add something to the database and, if a miracle happen, to describe a solution in a Qubes HCL report.
Shortly, to not waste everyone’s time, here is what I have tried and what I know:
- S3 is supported (
ACPI: PM: (supports S0 S3 S5)). - I added
mem_sleep_default=deepto/etc/default/grub. - I cannot disable hyperthreading in the BIOS.
- When I try to suspend a qube from the command line (
systemctl suspend), then the qube crashes and I cannot shut id down (I have to poweroff the computer). - Choosing
Lock screenwhen closing the laptop works, and I see bothLid closedandLid openedin the journal. - Finally, I tried to have some information from
journalctlto see what happens, so I tried to do something precise and read the journal:
| Time | Action | Computer |
| 0m | Closing the lid | Screen & Vents shutdown |
| 5m | Opening the lid | Vents go on |
| 10m | Pressing keys, Enter, Escape, etc. | Keyboard light goes on |
| 15m | Shutting down with power button | Shuts down |
| 20m | Powering on | Powers on |
And here is the journal:
Oct 23 17:05:06 dom0 systemd-logind[1902]: Lid closed.
Oct 23 17:05:09 dom0 systemd[1]: /usr/lib/systemd/system/qubes-suspend.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, a>
Oct 23 17:05:09 dom0 systemd[1]: Starting qubes-suspend.service - Qubes suspend hooks...
Oct 23 17:05:09 dom0 pkexec[5033]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
Oct 23 17:05:09 dom0 audit[5033]: USER_START pid=5033 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix acct="root" exe="/usr/bin/pkexec>
Oct 23 17:05:09 dom0 kernel: audit: type=1105 audit(1729695909.112:347): pid=5033 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_keyinit,pam_limits,pam_systemd,pam_unix acct>
Oct 23 17:05:09 dom0 pkexec[5033]: user Executing command [USER=root] [TTY=unknown] [CWD=/home/user] [COMMAND=/usr/sbin/xfpm-power-backlight-helper --set-brightness 5575]
Oct 23 17:05:10 dom0 52qubes-pause-vms[5045]: 0
Oct 23 17:05:10 dom0 systemd[1]: Finished qubes-suspend.service - Qubes suspend hooks.
Oct 23 17:05:10 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? re>
Oct 23 17:05:10 dom0 systemd[1]: Reached target sleep.target - Sleep.
Oct 23 17:05:10 dom0 kernel: audit: type=1130 audit(1729695910.842:348): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hos>
Oct 23 17:05:10 dom0 systemd[1]: Starting systemd-suspend.service - System Suspend...
Oct 23 17:05:10 dom0 systemd-sleep[5065]: Entering sleep state 'suspend'...
Oct 23 17:05:10 dom0 kernel: PM: suspend entry (deep)
-- Boot 49c8a3f33dfd459b9c41eb603eefd9ff --
Oct 23 17:25:38 localhost kernel: Linux version 6.6.48-1.qubes.fc37.x86_64 (mockbuild@065a31b3c1ba4c34ab3938416488814f) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1), GNU ld version 2.38-27>
Oct 23 17:25:38 localhost kernel: Command line: placeholder root=/dev/mapper/qubes_dom0-root ro rd.luks.uuid=luks-228a9d0e-62f0-42d0-a2ac-67448ff479e7 rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qu>
Oct 23 17:25:38 localhost kernel: Released 0 page(s)
Oct 23 17:25:38 localhost kernel: BIOS-provided physical RAM map:
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000000000000-0x000000000007ffff] usable
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000000080000-0x00000000000fffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000000100000-0x000000003fd98fff] usable
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x000000003fd99000-0x0000000040698fff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000040699000-0x00000000424aefff] usable
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000424af000-0x00000000442fefff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000442ff000-0x0000000044b2efff] ACPI NVS
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000044b2f000-0x0000000044bfefff] ACPI data
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000044bff000-0x0000000044bfffff] usable
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000044c00000-0x0000000048ffffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000049e00000-0x000000004f7fffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000fed90000-0x00000000fed91fff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000fee00000-0x00000000feefffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x00000000ff500000-0x00000000ffffffff] reserved
Oct 23 17:25:38 localhost kernel: Xen: [mem 0x0000000100000000-0x00000001be4cffff] usable
Oct 23 17:25:38 localhost kernel: NX (Execute Disable) protection: active
Oct 23 17:25:38 localhost kernel: APIC: Static calls initialized
Oct 23 17:25:38 localhost kernel: efi: EFI v2.7 by INSYDE Corp.
Oct 23 17:25:38 localhost kernel: efi: ACPI=0x44bfe000 ACPI 2.0=0x44bfe014 TPMFinalLog=0x44ac5000 SMBIOS=0x429de000 SMBIOS 3.0=0x429dc000 (MEMATTR=0x3bdbe018 unusable) ESRT=0x44b78018
Oct 23 17:25:38 localhost kernel: SMBIOS 3.3.0 present.
Oct 23 17:25:38 localhost kernel: DMI: Acer Aspire AV15-51/Jade_TL, BIOS V1.08 08/23/2023
Oct 23 17:25:38 localhost kernel: Hypervisor detected: Xen PV
Oct 23 17:25:38 localhost kernel: tsc: Fast TSC calibration using PIT
Oct 23 17:25:38 localhost kernel: tsc: Detected 2495.998 MHz processor
Oct 23 17:25:38 localhost kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Oct 23 17:25:38 localhost kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
and then the computer just works normally.
So, literally nothing happens in the journal while suspending it, and I have absolutely no clue of why it is not working. What else can I do to have more information on what is happening?
(Topic removed & reopend because of finger trouble).
