I accidentally deleted everything in /etc/salt with “sudo rm -r *” How can i restore everything there? Sadly dom0 backups only include /home directory
Where can i download default /etc/salt files?
You should try to reinstall all salt-related packages and see if you can recover from that:
sudo qubes-dom0-update --action=reinstall $(rpm -qa --qf "%{NAME}\n" | grep salt | tr '\n' ' ')
dnf provides /etc/salt/minion.dom0.conf
qubes-mgmt-salt-config-4.2.2-1.fc37.noarch : Qubes+Salt Management base configuration for SaltStack's Salt Infrastructure
: automation and management system.
Dépôt : @System
Correspondances trouvées dans :
Nom de fichier : /etc/salt/minion.dom0.conf
Reinstalling package qubes-mgmt-salt-config may help.
Best reply would be to say “recover from backups” but I guess you have no backups? I always either install etckeeper that keeps track of all /etc in git, or do it manually by adding everything in /etc/ in a git repository
i used integrated qubes os backup tool, but i didn’t knew that it only backups /home in dom0
How can i reset all salt configuration and get default one? I feel like by deleting everything /etc/salt i broke something in other configuration files that may be located somewhere else
did you try the command above to reinstall the package qubes-mgmt-salt-config? This may be enough to fix the problem.
yeah, it fixed the problem completely. But, resetting salt to default completely may prevent unexpected problems in the future
Can you share the output of this command? This will allow to check if some files were changed on my computer compared to yours.
$ sudo find /etc/salt/ -type f -exec sha256sum {} +
My results are
f1492d2590bf0197a947eafccce51644fb5de75f2c395b39b7a03c9c5a64b27a /etc/salt/minion.vm.conf
c4508b7583d8bbd769b78bd5a3240868e26358d0b0b45dfe4952d701eb62c74e /etc/salt/minion.d/f_defaults.conf
a8b3f6eadb1f260b27acb66ba5713acf0148f595ff96fd74c59ed860a0f2db5f /etc/salt/minion.d/formula-virtual-machines.conf
792b8238f342ade66d2fcc6363aba411594db489e39379344de65995370854a0 /etc/salt/minion.d/qubes_ext_pillar.conf
7611db6af0e9da27bb829fd89dbc50cc3492c2f6ec25dc82c5fd9dc6c420f114 /etc/salt/minion.d/formula-update.conf
d5db8ed53d6e0f95188c52168f7802d33bf32028547591509d242e8d7480dbc7 /etc/salt/spm
480ff43ea084d5f576f60091ddbe3a88bcb64c27a217292b7d8207fb408d16bc /etc/salt/minion_id
90b2a7581fb71b16714feeec90fd3bcb6bc39bbe6d46caab898375d441512aa3 /etc/salt/minion
77c3bdd85ad2dc959c419a2c308f80b69431db13afaca74c7b16dd216217a559 /etc/salt/minion.dom0.conf
f5c8220c57bd0fd73cc314c6ddfe1bb95c21772af049cb1e3cad4282e914945f /etc/salt/proxy
055f1c4e7bcc1b2846127eef631f4c68cab840d08ff1afddeab15b7950a36bf5 /etc/salt/spm.repos.d/local.repo
ad285a8304df7539e823d4aca5da2e12722e6930bfe6d0c4a34fc482a9dca634 /etc/salt/minion.dist
Please also share the output of
Hashes:
e73832118e200778e8ff18a792e85e288b24af9188338f22b10ef213c2788c55 /etc/salt/minion.d/qusal.conf
I don’t know if results are useful at all, probably not, since i installed ben’s gradle salt scripts and that probably changed some things or all things in the folder
find /etc/salt:
/etc/salt/
/etc/salt/minion
/etc/salt/pki
/etc/salt/pki/minion
/etc/salt/spm
/etc/salt/minion.d
/etc/salt/minion.d/minion.dom0.conf
/etc/salt/proxy
/etc/salt/minion_id
The checksum list matches exactly the one I shared earlier, except the extra qusal.conf file, so I think your salt install is correctly restored.
