I was testing giving a PCI based storage device their own sys-qubes for backups, and accidentally attached the SATA device which is my Dom 0 generic SSD, to the new qube and slowly watched my system die, as all vms started halting, also got an error that said something like "can’t find dom 0 sata’ or something similar. I knew it was hopeless but I tried to detach and then delete that qube from the gui, but with no hard drive connected anymore… it didn’t respond.
I thought maybe this wouldn’t save and just hard reset. Nope, doesn’t boot anymore.
Is there any way to access shell and qvm-something to delete that sys-qube and reattach my sata drive mapping?
But it doesn’t make sense to me how I’ll be able to clone the vms of the external and get them detected or in a usable state in the working qubes install. So it’s probably pointless, but I’m getting desperate. Been a month without a properly working system.
You can boot from whatever linux rescue media you like, decrypt & mount the Qubes OS file system as with any other Linux.
Then either edit the Qubes config file that contains the attached device (probably /var/lib/qubes/qubes.xml - better create a backup first) or chroot to that install and use qvm-block etc. to detach the drive.
Anyway I don’t see too much security benefits from a dedicated SATA PCI controller.
Then tried to see if I can just delete the qube. Seems whatever command I enter in chroot I get the following:
failed to connect to qubesd service
And a bunch of other commands.
I tried going back and mounting all the folders on the drive for chroot, and redid the command to remove the template, now it says doesn’t exist, but when I do sudo pvs and lvs, still clearly there.
Hm looks like the qvm-* commands require qubesd to be running which of course it is not in a chroot environment. You also wouldn’t want it to be running as it would attempt to attach the device to that VM etc.
Then edit /var/lib/qubes.xml manually and remove the incorrect PCI device (should be in some tag). Ideally Qubes should start just fine afterwards. Better make a backup of the config file though…
I just ran into this same problem. I fixed my problem thanks to this forum post! Here’s what I did:
I booted the system in TAILS.
Found the Dom0 partition as per the instructions here: How to mount a Qubes partition from another OS | Qubes OS
Found /var/lib/Qubes/qubes.xml in Dom0.
Ran in TAILS lspci and found that SATA is: id="00_1f.2
Found the line that had 00_1f.2, and that was under sys-usb.
I deleted that line.
Rebooted the system.
It worked!
