Hi.
tl;dr
The Qubes installer completes, apparently successfully
But when I reboot, it’s clear that it’s missing important components: namely, the qube OS templates (for Debian, Whonix etc). Any help gratefully received. Thank you ![]()
more
I tried Qubes a few years ago, and I liked it a lot - it’s a brilliant project
I was able to install it fine, and I used it for a few months. But the laptop I was using at the time didn’t support VT-d (I/O MMU virtualisation) which I understand is sub-optimal in security terms.
My current laptop has a much better spec, and - importantly - supports both VT-x with EPT, and VT-d (…both of which are enabled in the BIOS, which I updated to the latest version).
The problem is that I can’t install Qubes on it
The installer boots OK, and I can:
- change l10n
- configure storage
- create a user account successfully
But the “software” page in Anaconda has no options for OS templates (Debian, Whonix etc.): the only option in the RH pane is dom0 with xfce (?)
I’m fairly confident the issue isn’t the USB sticks: I’ve tried two different sticks (one 8GB, one 16GB), I tested them both before use with badblocks and f3, and dd’ed the Qubes .isos to them in the recommended way. I carefully validated the .isos after downloading them, and I (re)validated the installers after creation (kudos to whoever wrote the documentation, BTW: I think it’s excellent
Other things I’ve tried:
- downloading the previous version of Qubes (4.1.2 instead of 4.2.1) (same result)
- going to a tty while the installer is running, to check what’s going on (see below)
I read this, which sounds like the same thing. But the suggested solution doesn’t work for me: there is no /mnt/sysimage (presumably because the installer mounts stuff elsewhere now).
If I run find / -name '*.repo' I can see:
/etc/anaconda.repos.d/fedora-updates.repo
/etc/anaconda.repos.d/fedora.repo
/etc/anaconda.repos.d/qubes-templates.repo
/etc/anaconda.repos.d/qubes-dom0.repo
…and I’m assuming they’re what I need. But they’re (apparently) not recognised by the installer(?)
Does anyone have any advice, please?
TIA and best regards
