USB qube, such as the template for sys-usb: qubes-usb-proxy to provide USB devices to other Qubes and qubes-input-proxy-sender to provide keyboard or mouse input to dom0
and
Qubes to which USB devices are attached: libpam-systemd (Until #7689 is fixed, either pair it with qubes-core-agent-passwordless-root or manually activate the user session with loginctl activate <USER_SESSION_ID>.)
I don’t wanna use qubes-core-agent-passwordless-root
the loginctl session-status says c2 - user (1000) and it’s State is active.
I can’t loginctl activate <USER_SESSION_ID>, it says operation not supported
do I must install the qubes-usb-proxy in a template of a qube to which I want a usb flash drive to be attached(not a sys-usb)? Because otherwise it doesn’t work
Isn’t that the same thing I’m talking about?
I tried to attach an entire block drive and a single partition with same result.
Or can you please elaborate, what should I do practically(assume fresh debian 13 min template and a qube based on it)? maybe I didn’t catch something?
All I want is to be able to attach flash stick to my qube
qubes-usb-proxy is for attaching USB devices, not block devices. This is unnecessary. Attach the partition using the usb logo on the top right of the screen, then start a root terminal in the qube and run # mount /dev/xvdi /run/media/. If this passes with no stderr and you find your files in /run/media (you may want to chown to user), then your block devices are attaching correctly.
But if I don’t install qubes-usb-proxy and will try to attach my usb stick, it says I must install that package. Otherwise it doesn’t even let me attach anything.
What exactly the qubes-usb-proxy does to my qube if I install it? Does it expose anything or start to act as sys-usb?
Read this page about USB devices and this page
about block devices.
You do not need to install qubes-usb-proxy to attach a block
device, even if it is a USB storage device. You do need it
installed if you want to attach a device as a USB device
