A Reasonably Secure Agentic System
A Reasonably Secure Agentic System:
Split-Brain Implementation of OpenClaw (Clawdbot)
– Introduction:
The rise of AI agents like OpenClaw (formerly Clawdbot) presents a significant security challenge: these agents require deep system access to be useful, but granting an LLM direct terminal access is a violation of basic security hygiene.
By leveraging Qubes OS, we can implement a Sovereign AI Orchestrator that is proactive and powerful, yet physically incapable of breaching the TCB (Trusted Computing Base).
– The Architecture: Split-Brain Isolation
Instead of a monolithic installation, we fragment the agent into three compartmentalized layers:
  1. The “Brain” (sys-clawd AppVM):
    Runs the OpenClaw Node.js environment and holds API keys. It has network access but zero private data. It communicates only via restricted qrexec calls.
  2. The “Nervous System” (Custom RPC):
    A set of sanitized scripts in dom0 that act as an API. It translates AI “intent tokens” into system actions.
  3. The “Muscles” (Target AppVMs):
    Your existing Work, Personal, or Disposable VMs where the actual tasks (browsing, research, emailing) occur.
    Technical Implementation
– 1. The dom0 Executor (The Policy Firewall)
We avoid passing raw strings to a shell. Instead, we use a strict case statement to whitelist allowed actions.
Path: /usr/local/bin/clawd-executor (in dom0)
#!/bin/bash
# Usage: <action> <target_vm> <parameter>
read -r action target_vm param
# Basic Sanitization: Ensure target_vm is alphanumeric
[[ ! "$target_vm" =~ ^[a-zA-Z0-9-]+$ ]] && exit 1
case "$action" in
    "open-url")
        # Opens a URL in the target VM's default browser
        qvm-run -q -a "$target_vm" "qubes-open-url '$param'"
    "search")
        # Triggers a search engine query in the target VM
        qvm-run -q -a "$target_vm" "firefox --search '$param'"
    "install-app")
        # Requires 'ask' policy for manual approval
        notify-send "AI Request" "Install $param in $target_vm?"
        qvm-run -u root "$target_vm" "apt-get update && apt-get install -y $param"
        exit 1
esac
–2. The Security Policy (The Gatekeeper)
Using the Qrexec Policy v2 (Qubes 4.1+), we ensure every mutating action requires a human OK.
Path: /etc/qubes/policy.d/30-user.policy
# Read-only status checks: Always allow
custom.ClawdRead  * sys-clawd  dom0  allow
# System changes: Always ask for confirmation
custom.ClawdWrite * sys-clawd  dom0  ask,default_target=dom0
-- Use Case: Parallel Multi-VM Orchestration
The primary benefit is Identity Isolation. A single prompt to the agent can orchestrate complex, cross-domain workflows:
"Open YouTube in social-vm, prepare an email draft in work-vm, and research pelican biology in a disp-vm."
The agent dispatches three separate RPC calls. dom0 validates the VM names and launches the processes. From the perspective of the web services, these are three different machines with three different fingerprints, yet they are coordinated by your personal AI.
-- Risk Mitigation
- Compromise of sys-clawd: If the agent's VM is hacked, the attacker is trapped. They cannot read your vault or your personal files. They can only attempt to trigger the pre-defined RPC actions, which will trigger a dom0 "Ask" prompt on your screen.
- Prompt Injection: Even if an LLM is tricked into trying "rm -rf /", that string will simply fail the case statement in dom0. The malware has no path to execution.
--Final Thoughts
Implementing AI agents in Qubes OS turns the OS from a collection of silos into a coordinated organism without sacrificing the security that makes us use Qubes in the first place. By shifting the trust from the AI's logic to the hypervisor's RPC policies, we can enjoy the benefits of agentic automation while keeping the digital kingdom under lock and key.
My own approach to this would be to run these processes in illumos Zones that talk on a private virtual subnet (within the illumos system). True containers (Zones) are likely not necessary. Even with all of the processes on the same Linux kernel with modern Linux sandboxing and firewall rules is way better than most of what we’re seeing out there.
Overall, I like this compartmentalization thinking.
I think it’s an interesting approach. I believe that an implicit assumption in your approach may not always hold: if I understand correctly, you’re assuming that reads are generally safe and writes may not be (and therefore require confirmation). Just think of a password file. Reading it is not automatically safe.
As far as “human in the loop”, that quality gate can be implemented within any sandboxing/virtualization tech. If you think the human in the loop part needs to be there, I’ll defer to you on that.
I’m completely new here, but I saw the potential for sandboxed sections of an agentic operating system with Qubes as the backbone. Right now. I have a core qube with Nemoclaw, my hopes is eventually HIPPA review ready and secure enough to be used in healthcare or similar scenarios. I have no idea what im doing, are there any resources that could help?
@dogwatergulper If you allow any local ai agents to run in a way that those ai agents can access any patient data, you would not only be violating hipaa you might also be committing a felony. Do not allow any ai agents to access any patient data under any circumstances. If you do anything like that people may come after you and punish you severely for doing it.
