After applying “Disable checking for updates for all existing qubes” in Qubes Global Config, poking around on a template:
[user@dom0 ~]$ qvm-features debian-12-xfce | grep 'qubes-update-check'
supported-service.qubes-update-check 1
[user@dom0 ~]$ qvm-service debian-12-xfce | grep 'qubes-update-check'
qubes-update-check off
Turning the service back on to see the effect on tool output, and then turning it back off again:
[user@dom0 ~]$ qvm-service debian-12-xfce qubes-update-check on
[user@dom0 ~]$ qvm-service debian-12-xfce | grep qubes-update-check
# Turning it back off again (correctly):
[user@dom0 ~]$ qvm-service debian-12-xfce qubes-update-check off
# (Everything is fine.)
Turning it off again, the wrong way (part 1):
# Mistake:
[user@dom0 ~]$ qvm-service --unset debian-12-xfce qubes-update-check
# Result:
# (No output)
By --unset’ing the service we revert it to its default, i.e. still enabled.
Turning it off the wrong way, part 2:
# Mistake:
[user@dom0 ~]$ qvm-features --unset debian-12-xfce service.qubes-update-check
# (No output)
Same as part 1, the service was reverted to its default, enabled.
Turning it off the wrong way, part 3:
# Mistake:
[user@dom0 ~]$ qvm-features debian-12-xfce service.qubes-update-check 0
Value ‘0’ does not disable service.qubes-update-check.
Correct ways to disable the service:
qvm-service debian-12-xfce qubes-update-check offqvm-service --disable debian-12-xfce qubes-update-checkqvm-features debian-12-xfce service.qubes-update-check ''
Incorrect ways to disable the service:
qvm-service --unset debian-12-xfce qubes-update-checkqvm-features --unset debian-12-xfce service.qubes-update-checkqvm-features debian-12-xfce service.qubes-update-check 0
