Prerequisites
For this patch you must use fedora 39, a version above fedora 40 cannot be used as of writing. This guide works for R4.2 and R4.3, make sure to choose the corresponding version for your build.
Downloading the Qubes Builder
sudo dnf install git
git clone https://gitlab.com/QubesOS/qubes-builderv2.git
cd qubes-builderv2/
sudo dnf install $(cat dependencies-fedora.txt)
git submodule update --init
Qubes os r4.3
cp example-configs/qubes-os-r4.3.yml builder.yml
Qubes os r4.2
cp example-configs/qubes-os-r4.2.yml builder.yml
vim builder.yml
Use docker instead of qubes as executor
delete qubes, un-comment docker
systemctl enable --now docker
tools/generate-container-image.sh docker fedora-40-x86_64
sudo su
./qb -c vmm-xen package fetch;
./qb -c qubes-release package fetch
Copy & Paste patches
vim artifacts/sources/vmm-xen/9998-amd-ioapic-test.patch
vim artifacts/sources/vmm-xen/9999-amd-iommu-test.patch
vim artifacts/sources/vmm-xen/xen.spec.in
Paste this line 173
Patch9998: 9998-amd-ioapic-test.patch
Patch9999: 9999-amd-iommu-test.patch
Prep, then build.
./qb -c vmm-xen package prep
./qb -c vmm-xen package build
You now have the xen binary
rm -rf builder.yml
vim builder.yml
Qubes os r4.3
Qubes os r4.2
Again, use docker instead of qubes as executor
Delete qubes, replace with docker executor below
executor:
type: docker
options:
image: "qubes-builder-fedora:latest"
Now we can start buidling the ISO
./qb installer fetch
./qb installer init-cache
./qb installer prep
./qb installer build
You will now have an ISO file in the artifacts folder
ls artifacts/iso
All posts making leading this posts
*Note
this may or may not work for other AMD 8000 laptop cpus
