4.3 upgrade Error: Check of pool qubes_dom0/vm-pool failed
I had a 4.3 upgrade Stage 3 failure where an old kernel-qubes-vm package couldn’t be removed. I fixed that issue and manually removed the package. I then manually ran the remaining commands (systemctl preset-all and systemctl enable) from the Stage 3 part of the upgrade script.
I rebooted into Qubes 4.3 to complete Stages 4-6. After rebooting, none of my qubes are able to start. If I manually start a qube, I see this error:
Error: Check of pool qubes_dom0/vm-pool failed (status:64). Manual repair required!
Aborting. Failed to locally activate thin pool qubes_dom0/vm-pool.
How can I troubleshoot or fix this?
I successfully ran lvconvert --repair qubes_dom0/vm-pool. It showed a warning while running: WARNING: Sum of all thin volume sizes exceeds the size of thin pools and the size of whole volume group but still completed.
I rebooted and my qubes started normally. I continued with Stages 4-6 from the upgrade with no issues. I rebooted again and no issues.
I’m concerned about the warning since I also saw it earlier in the upgrade during the dom0 snapshot. It’s unclear if I should do something to address the warning or ignore it.
I had the same error as you!
I had previously run into this error during stage 3 of the upgrade process and followed the advice suggested by unman which involved resizing the space allocated for dom0.
I am not sure if that had something to do with this failed to locally activate thin pool error that you’re describing occurring later on, but I was able to fix it with your suggested methods!
I got the warning as well and it also said:
WARNING: Sum of all thin volume sizes (<1.1 TiB) exceeds the size of thin pools and the size of whole volume group (<475 GiB).
WARNING: LV qubes_dom0/vm-pool_meta0 holds a backup of the unrepaired metadata. Use lvremove when no longer required.
I am not sure how the sun of all volume sizes could be that large as my SSD is not even 1TiB large. Furthermore I don’t know how or on what to use lvremove but just as in your case, even without doing this, everything ended up working.
I would appreciate some further insight however, if anyone understands or knows more about this!
Thanks for sharing that. I had the same issue. You certainly save me some time.
Hello everybody,
I am facing the same issue right now. (not during upgrade. it just popped up today for some reason.)
I ran the journalctl cleaning commands and extended the filesystem as described in the advice above.
As I have before and I still do, when running
sudo lvconvert --repair qubes_dom0/vm-pool
I still get an error:
Transaction id 15231 from pool "qubes_dom0/vm-pool" does not match repaired transaction id 15230 from /dev/qubes_dom0/lvol0_pmspare.
Please help.
Faced the same issue today. May be this will help:
This solved it! Thank you very very much :pray:
The repair command output that my sum of all thin pools is 6.53 TERABYTES which is crazy! No idea how that happened heh.
