4.3 lock screen features not work correctly?
I’m not sure if it’s me but does anyone’s lock screen features work as intended? For example, if I have a 5 minute screen saver and I want to lock the screen after the screen saver is active for 1 hour, the screen locks after 5 minutes instead of 1 hour. This has been an issue for me since the rc versions.
I am seeing the same. Solutions anyone?
I had assumed maybe it’s because it’s a newer Z890 motherboard but I don’t really know.
It seems screen lock basically doesn’t work in Qubes as it should. I basically can’t disable it permanently. If in Qubes 4.2 you could do it by enabling Presentation Mode in battery settings, now, in Qubes 4.3 this already doesn’t work. Now I left with no known methods how disable it.
I can reproduce, there is currently no bug opened about this.
