Try to use permissive=True
and no-strict-reset=True
options together:
qvm-pci detach sys-net dom0:xx_xx.x
qvm-pci attach -o permissive=True -o no-strict-reset=True --persistent sys-net dom0:xx_xx.x
Did you update your dom0 or templates before it stopped working again?
Do you have some other system on your PC besides Qubes OS? For example Windows in dual boot?
turns out my wifi card got partially disconnected, not a Qubes problem.
Hi all, just wanted to chime in that I’m also having this issue with a slightly different wifi card. I’ve tried setting strict reset and permissive to true. I’ve tried debian and fedora templates. And I think I’ve tried most available kernels up to 6.5. Any suggestions?
user@sys-net:~$ sudo dmesg | grep iwlwifi
[ 2.726620] iwlwifi 0000:00:0a.0: pci_enable_msi failed - -22
[ 2.735686] iwlwifi 0000:00:0a.0: api flags index 2 larger than supported by driver
[ 2.735726] iwlwifi 0000:00:0a.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 2.736236] iwlwifi 0000:00:0a.0: loaded firmware version 72.daa05125.0 ty-a0-gf-a0-72.ucode op_mode iwlmvm
[ 2.978410] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.042388] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x8576, CPU2 Status: 0xb03
[ 4.042507] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 4.042627] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 4.042746] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 4.042865] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 4.042985] iwlwifi 0000:00:0a.0: UMAC PC: 0xc0081234
[ 4.043100] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d168a
[ 4.043147] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.045043] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 4.045088] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[ 4.045106] iwlwifi 0000:00:0a.0: Loaded firmware version: 72.daa05125.0 ty-a0-gf-a0-72.ucode
[ 4.045146] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4.045205] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[ 4.045224] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[ 4.045262] iwlwifi 0000:00:0a.0: 0x004DB5D2 | branchlink2
[ 4.045277] iwlwifi 0000:00:0a.0: 0x00009662 | interruptlink1
[ 4.045320] iwlwifi 0000:00:0a.0: 0x00009662 | interruptlink2
[ 4.045338] iwlwifi 0000:00:0a.0: 0x004D485A | data1
[ 4.045378] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[ 4.045393] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[ 4.045407] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[ 4.045449] iwlwifi 0000:00:0a.0: 0x000EB70E | tsf low
[ 4.045463] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[ 4.045494] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[ 4.045508] iwlwifi 0000:00:0a.0: 0x001000EF | time gp2
[ 4.045522] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[ 4.045568] iwlwifi 0000:00:0a.0: 0x00000048 | uCode version major
[ 4.045610] iwlwifi 0000:00:0a.0: 0xDAA05125 | uCode version minor
[ 4.045627] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[ 4.045668] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[ 4.045685] iwlwifi 0000:00:0a.0: 0x8002FF03 | hcmd
[ 4.045726] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[ 4.045740] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[ 4.045753] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[ 4.045784] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[ 4.045798] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[ 4.045811] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[ 4.045842] iwlwifi 0000:00:0a.0: 0x004D485A | wait_event
[ 4.045856] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[ 4.045869] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[ 4.045900] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[ 4.045914] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[ 4.045958] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[ 4.045972] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[ 4.045985] iwlwifi 0000:00:0a.0: 0x002C0000 | flow_handler
[ 4.046262] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 4.046305] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[ 4.046322] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 4.046363] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[ 4.046380] iwlwifi 0000:00:0a.0: 0x8045F1D0 | umac branchlink2
[ 4.046421] iwlwifi 0000:00:0a.0: 0x8047EADA | umac interruptlink1
[ 4.046438] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac interruptlink2
[ 4.046479] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[ 4.046493] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac data2
[ 4.046506] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[ 4.046537] iwlwifi 0000:00:0a.0: 0x00000048 | umac major
[ 4.046551] iwlwifi 0000:00:0a.0: 0xDAA05125 | umac minor
[ 4.237904] iwlwifi 0000:00:0a.0: 0x001001ED | frame pointer
[ 4.237925] iwlwifi 0000:00:0a.0: 0xC0887F38 | stack pointer
[ 4.237968] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[ 4.237985] iwlwifi 0000:00:0a.0: 0x00000404 | isr status reg
[ 4.238099] iwlwifi 0000:00:0a.0: IML/ROM dump:
[ 4.238125] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[ 4.238218] iwlwifi 0000:00:0a.0: 0x00008576 | IML/ROM data1
[ 4.238326] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 4.238379] iwlwifi 0000:00:0a.0: Fseq Registers:
[ 4.238460] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[ 4.238520] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[ 4.238580] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 4.238639] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 4.238698] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 4.238757] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4.238816] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[ 4.238874] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[ 4.238932] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 4.238993] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 4.239055] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.239118] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.239216] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[ 4.239245] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.471299] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[ 6.498026] iwlwifi 0000:00:0a.0: retry init count 0
[ 6.506079] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 7.562709] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x8574, CPU2 Status: 0xb03
[ 7.563020] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 7.563124] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 7.563393] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 7.563616] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 7.563768] iwlwifi 0000:00:0a.0: UMAC PC: 0x8047eada
[ 7.563878] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d180a
[ 7.563895] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 7.566893] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 7.566929] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[ 7.566946] iwlwifi 0000:00:0a.0: Loaded firmware version: 72.daa05125.0 ty-a0-gf-a0-72.ucode
[ 7.566985] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7.567003] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[ 7.567043] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[ 7.567060] iwlwifi 0000:00:0a.0: 0x004DB5D2 | branchlink2
[ 7.567101] iwlwifi 0000:00:0a.0: 0x004D180A | interruptlink1
[ 7.567118] iwlwifi 0000:00:0a.0: 0x004D180A | interruptlink2
[ 7.567160] iwlwifi 0000:00:0a.0: 0x004D485A | data1
[ 7.567218] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[ 7.567232] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[ 7.567276] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[ 7.567291] iwlwifi 0000:00:0a.0: 0x000EAEC9 | tsf low
[ 7.567331] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[ 7.567345] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[ 7.567388] iwlwifi 0000:00:0a.0: 0x000FF8A8 | time gp2
[ 7.567402] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[ 7.567446] iwlwifi 0000:00:0a.0: 0x00000048 | uCode version major
[ 7.567464] iwlwifi 0000:00:0a.0: 0xDAA05125 | uCode version minor
[ 7.567504] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[ 7.567548] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[ 7.567566] iwlwifi 0000:00:0a.0: 0x8002FF03 | hcmd
[ 7.567606] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[ 7.567619] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[ 7.567663] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[ 7.567677] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[ 7.567721] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[ 7.567734] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[ 7.567779] iwlwifi 0000:00:0a.0: 0x004D485A | wait_event
[ 7.567792] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[ 7.567836] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[ 7.567850] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[ 7.567894] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[ 7.567910] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[ 7.567951] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[ 7.567965] iwlwifi 0000:00:0a.0: 0x002C0000 | flow_handler
[ 7.568668] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 7.568682] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[ 7.568730] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 7.568747] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[ 7.568788] iwlwifi 0000:00:0a.0: 0x8045F1D0 | umac branchlink2
[ 7.568805] iwlwifi 0000:00:0a.0: 0x8047EADA | umac interruptlink1
[ 7.568846] iwlwifi 0000:00:0a.0: 0x8047EADA | umac interruptlink2
[ 7.568863] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[ 7.568904] iwlwifi 0000:00:0a.0: 0x8047EADA | umac data2
[ 7.568917] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[ 7.568961] iwlwifi 0000:00:0a.0: 0x00000048 | umac major
[ 7.568975] iwlwifi 0000:00:0a.0: 0xDAA05125 | umac minor
[ 7.569018] iwlwifi 0000:00:0a.0: 0x000FF9A8 | frame pointer
[ 7.569035] iwlwifi 0000:00:0a.0: 0xC088625C | stack pointer
[ 7.569076] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[ 7.569093] iwlwifi 0000:00:0a.0: 0x00000400 | isr status reg
[ 7.569355] iwlwifi 0000:00:0a.0: IML/ROM dump:
[ 7.569370] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[ 7.763242] iwlwifi 0000:00:0a.0: 0x00008574 | IML/ROM data1
[ 7.763352] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 7.763413] iwlwifi 0000:00:0a.0: Fseq Registers:
[ 7.763496] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[ 7.763582] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[ 7.763643] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 7.763728] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 7.763814] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 7.763900] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7.763985] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[ 7.764069] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[ 7.764152] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 7.764276] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 7.764364] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7.764453] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7.764541] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[ 7.764569] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 9.351314] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[ 9.366807] iwlwifi 0000:00:0a.0: retry init count 1
[ 9.370020] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 10.442403] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x8573, CPU2 Status: 0xb03
[ 10.442479] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 10.442554] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[ 10.442621] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 10.442695] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 10.442770] iwlwifi 0000:00:0a.0: UMAC PC: 0x8047eada
[ 10.442836] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d180a
[ 10.442854] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 10.444072] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 10.444089] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[ 10.444107] iwlwifi 0000:00:0a.0: Loaded firmware version: 72.daa05125.0 ty-a0-gf-a0-72.ucode
[ 10.444131] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 10.444149] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[ 10.444177] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[ 10.444195] iwlwifi 0000:00:0a.0: 0x004DB5D2 | branchlink2
[ 10.444209] iwlwifi 0000:00:0a.0: 0x004D180A | interruptlink1
[ 10.444227] iwlwifi 0000:00:0a.0: 0x004D180A | interruptlink2
[ 10.444244] iwlwifi 0000:00:0a.0: 0x004D485A | data1
[ 10.444258] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[ 10.444272] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[ 10.444286] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[ 10.444301] iwlwifi 0000:00:0a.0: 0x000EE489 | tsf low
[ 10.444315] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[ 10.444329] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[ 10.444343] iwlwifi 0000:00:0a.0: 0x00102E67 | time gp2
[ 10.444357] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[ 10.444375] iwlwifi 0000:00:0a.0: 0x00000048 | uCode version major
[ 10.444392] iwlwifi 0000:00:0a.0: 0xDAA05125 | uCode version minor
[ 10.444410] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[ 10.444424] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[ 10.444442] iwlwifi 0000:00:0a.0: 0x8002FF03 | hcmd
[ 10.444456] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[ 10.444470] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[ 10.444484] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[ 10.444499] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[ 10.444513] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[ 10.444526] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[ 10.444541] iwlwifi 0000:00:0a.0: 0x004D485A | wait_event
[ 10.444555] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[ 10.444569] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[ 10.444583] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[ 10.444597] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[ 10.444615] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[ 10.444629] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[ 10.444643] iwlwifi 0000:00:0a.0: 0x002C0000 | flow_handler
[ 10.444746] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[ 10.444762] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[ 10.444779] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 10.444797] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[ 10.444815] iwlwifi 0000:00:0a.0: 0x8045F1D0 | umac branchlink2
[ 10.444832] iwlwifi 0000:00:0a.0: 0x8047EADA | umac interruptlink1
[ 10.444849] iwlwifi 0000:00:0a.0: 0x8047EADA | umac interruptlink2
[ 10.444867] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[ 10.444881] iwlwifi 0000:00:0a.0: 0x8047EADA | umac data2
[ 10.444897] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[ 10.444911] iwlwifi 0000:00:0a.0: 0x00000048 | umac major
[ 10.444925] iwlwifi 0000:00:0a.0: 0xDAA05125 | umac minor
[ 10.444940] iwlwifi 0000:00:0a.0: 0x00102F66 | frame pointer
[ 10.444957] iwlwifi 0000:00:0a.0: 0xC088625C | stack pointer
[ 10.444975] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[ 10.444992] iwlwifi 0000:00:0a.0: 0x00000400 | isr status reg
[ 10.445058] iwlwifi 0000:00:0a.0: IML/ROM dump:
[ 10.445073] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[ 10.445134] iwlwifi 0000:00:0a.0: 0x00008573 | IML/ROM data1
[ 10.445218] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 10.445287] iwlwifi 0000:00:0a.0: Fseq Registers:
[ 10.445345] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[ 10.445398] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[ 10.445458] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 10.445515] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 10.445569] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 10.445623] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 10.445676] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[ 10.445723] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[ 10.445787] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 10.445844] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 10.445904] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 10.445960] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 10.446022] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[ 10.446040] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 12.018397] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[ 12.034416] iwlwifi 0000:00:0a.0: retry init count 2
DVM
November 18, 2023, 6:48pm
44
Can you run the following commands in sys-net and report back with logs again?:
sudo mv /lib/firmware/iwlwifi-ty-a0-gf-a0-72.ucode.xz /home/user/
sudo modprobe -r iwlwifi
sudo modprobe -r iwlmvm
sudo modprobe iwlwifi
sudo modprobe iwlmvm
You can also try kernel 6.1, maybe there’s a problem in newer kernels.
Okay - I think I ran DVM’s suggested commends correctly. Here is the output from dmesg | grep iwlwifi.
I tried the 6.1 kernel but no luck. Does it matter what kernel dom0 is? Or just the appvm?
Thanks all for the help.
[39929.040851] iwlwifi 0000:00:0a.0: pci_enable_msi failed - -22
[39929.047684] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-72.ucode failed with error -2
[39929.047808] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-71.ucode failed with error -2
[39929.047913] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-70.ucode failed with error -2
[39929.048025] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-69.ucode failed with error -2
[39929.048127] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-68.ucode failed with error -2
[39929.048282] iwlwifi 0000:00:0a.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-67.ucode failed with error -2
[39929.099132] iwlwifi 0000:00:0a.0: api flags index 2 larger than supported by driver
[39929.099185] iwlwifi 0000:00:0a.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.63.2.2
[39929.099701] iwlwifi 0000:00:0a.0: loaded firmware version 66.f1c864e0.0 ty-a0-gf-a0-66.ucode op_mode iwlmvm
[39929.194675] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[39930.272245] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x847d, CPU2 Status: 0xb03
[39930.272325] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[39930.272399] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[39930.272482] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[39930.272564] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[39930.272631] iwlwifi 0000:00:0a.0: UMAC PC: 0xc0080e4c
[39930.272695] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d0b2e
[39930.272712] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39930.273943] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39930.273960] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[39930.273981] iwlwifi 0000:00:0a.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[39930.274005] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[39930.274026] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[39930.274043] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[39930.274063] iwlwifi 0000:00:0a.0: 0x004DA722 | branchlink2
[39930.274077] iwlwifi 0000:00:0a.0: 0x0000954A | interruptlink1
[39930.274094] iwlwifi 0000:00:0a.0: 0x0000954A | interruptlink2
[39930.274117] iwlwifi 0000:00:0a.0: 0x004D94DA | data1
[39930.274132] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[39930.274149] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[39930.274163] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[39930.274177] iwlwifi 0000:00:0a.0: 0x000EB4E8 | tsf low
[39930.274193] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[39930.274207] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[39930.274224] iwlwifi 0000:00:0a.0: 0x00100381 | time gp2
[39930.274237] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[39930.274254] iwlwifi 0000:00:0a.0: 0x00000042 | uCode version major
[39930.274275] iwlwifi 0000:00:0a.0: 0xF1C864E0 | uCode version minor
[39930.274292] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[39930.274306] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[39930.274326] iwlwifi 0000:00:0a.0: 0x8004FC12 | hcmd
[39930.274340] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[39930.274354] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[39930.274370] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[39930.274384] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[39930.274398] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[39930.274423] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[39930.274440] iwlwifi 0000:00:0a.0: 0x004D94DA | wait_event
[39930.274454] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[39930.274468] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[39930.274482] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[39930.274499] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[39930.274516] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[39930.274532] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[39930.274546] iwlwifi 0000:00:0a.0: 0x001C0000 | flow_handler
[39930.274657] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39930.274673] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[39930.274693] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[39930.274711] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[39930.274730] iwlwifi 0000:00:0a.0: 0x8045DFC6 | umac branchlink2
[39930.274747] iwlwifi 0000:00:0a.0: 0x8047FAB6 | umac interruptlink1
[39930.274767] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac interruptlink2
[39930.274784] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[39930.274799] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac data2
[39930.274814] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[39930.274829] iwlwifi 0000:00:0a.0: 0x00000042 | umac major
[39930.274857] iwlwifi 0000:00:0a.0: 0xF1C864E0 | umac minor
[39930.274871] iwlwifi 0000:00:0a.0: 0x0010047D | frame pointer
[39930.274888] iwlwifi 0000:00:0a.0: 0xC0887F38 | stack pointer
[39930.274905] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[39930.274922] iwlwifi 0000:00:0a.0: 0x00000404 | isr status reg
[39930.275000] iwlwifi 0000:00:0a.0: IML/ROM dump:
[39930.275014] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[39930.275079] iwlwifi 0000:00:0a.0: 0x0000847D | IML/ROM data1
[39930.275145] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[39930.275213] iwlwifi 0000:00:0a.0: Fseq Registers:
[39930.275264] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[39930.275322] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[39930.275376] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[39930.275431] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[39930.275485] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[39930.275540] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[39930.275594] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[39930.275649] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[39930.275703] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[39930.275758] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[39930.275809] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[39930.275868] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[39930.275930] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[39930.275947] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39932.589333] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[39932.603312] iwlwifi 0000:00:0a.0: retry init count 0
[39932.608244] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[39933.672309] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x8479, CPU2 Status: 0xb03
[39933.672399] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[39933.672481] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[39933.672553] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[39933.672619] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[39933.672699] iwlwifi 0000:00:0a.0: UMAC PC: 0xc0080e4c
[39933.672763] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d0b3a
[39933.672781] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39933.674025] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39933.674042] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[39933.674060] iwlwifi 0000:00:0a.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[39933.674083] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[39933.674101] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[39933.674118] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[39933.674135] iwlwifi 0000:00:0a.0: 0x004DA722 | branchlink2
[39933.674149] iwlwifi 0000:00:0a.0: 0x0000954A | interruptlink1
[39933.674167] iwlwifi 0000:00:0a.0: 0x0000954A | interruptlink2
[39933.674183] iwlwifi 0000:00:0a.0: 0x004D94DA | data1
[39933.674197] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[39933.674213] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[39933.674228] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[39933.674242] iwlwifi 0000:00:0a.0: 0x000EB8AD | tsf low
[39933.674256] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[39933.674270] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[39933.674284] iwlwifi 0000:00:0a.0: 0x00100742 | time gp2
[39933.674298] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[39933.674315] iwlwifi 0000:00:0a.0: 0x00000042 | uCode version major
[39933.674331] iwlwifi 0000:00:0a.0: 0xF1C864E0 | uCode version minor
[39933.674349] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[39933.674365] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[39933.674382] iwlwifi 0000:00:0a.0: 0x8004FC12 | hcmd
[39933.674396] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[39933.674410] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[39933.674424] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[39933.674441] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[39933.674455] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[39933.674469] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[39933.674482] iwlwifi 0000:00:0a.0: 0x004D94DA | wait_event
[39933.674497] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[39933.674514] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[39933.674527] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[39933.674541] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[39933.674561] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[39933.674575] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[39933.674589] iwlwifi 0000:00:0a.0: 0x001C0000 | flow_handler
[39933.674688] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39933.674703] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[39933.674721] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[39933.674738] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[39933.674755] iwlwifi 0000:00:0a.0: 0x8045DFC6 | umac branchlink2
[39933.674772] iwlwifi 0000:00:0a.0: 0x8047FAB6 | umac interruptlink1
[39933.674789] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac interruptlink2
[39933.674806] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[39933.674822] iwlwifi 0000:00:0a.0: 0xC0080B74 | umac data2
[39933.674836] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[39933.674850] iwlwifi 0000:00:0a.0: 0x00000042 | umac major
[39933.674864] iwlwifi 0000:00:0a.0: 0xF1C864E0 | umac minor
[39933.674881] iwlwifi 0000:00:0a.0: 0x0010083F | frame pointer
[39933.674898] iwlwifi 0000:00:0a.0: 0xC0887F38 | stack pointer
[39933.674915] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[39933.674932] iwlwifi 0000:00:0a.0: 0x00000404 | isr status reg
[39933.675002] iwlwifi 0000:00:0a.0: IML/ROM dump:
[39933.675019] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[39933.675087] iwlwifi 0000:00:0a.0: 0x00008479 | IML/ROM data1
[39933.675169] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[39933.675247] iwlwifi 0000:00:0a.0: Fseq Registers:
[39933.675298] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[39933.675358] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[39933.675412] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[39933.675466] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[39933.675521] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[39933.675575] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[39933.675627] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[39933.675683] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[39933.675736] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[39933.675791] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[39933.675841] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[39933.675898] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[39933.675959] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[39933.675978] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39935.258714] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[39935.286216] iwlwifi 0000:00:0a.0: retry init count 1
[39935.290384] iwlwifi 0000:00:0a.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[39936.352046] iwlwifi 0000:00:0a.0: SecBoot CPU1 Status: 0x8483, CPU2 Status: 0xb03
[39936.352121] iwlwifi 0000:00:0a.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[39936.352195] iwlwifi 0000:00:0a.0: HPM_SECONDARY_DEVICE_STATE: 0x42
[39936.352287] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[39936.352348] iwlwifi 0000:00:0a.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[39936.352424] iwlwifi 0000:00:0a.0: UMAC PC: 0xc0080b6c
[39936.352490] iwlwifi 0000:00:0a.0: LMAC PC: 0x4d0cce
[39936.352506] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39936.353758] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39936.353774] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 6
[39936.353792] iwlwifi 0000:00:0a.0: Loaded firmware version: 66.f1c864e0.0 ty-a0-gf-a0-66.ucode
[39936.353816] iwlwifi 0000:00:0a.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[39936.353834] iwlwifi 0000:00:0a.0: 0x002002F0 | trm_hw_status0
[39936.353854] iwlwifi 0000:00:0a.0: 0x00000000 | trm_hw_status1
[39936.353871] iwlwifi 0000:00:0a.0: 0x004DA722 | branchlink2
[39936.353886] iwlwifi 0000:00:0a.0: 0x004D0CCE | interruptlink1
[39936.353902] iwlwifi 0000:00:0a.0: 0x004D0CCE | interruptlink2
[39936.353919] iwlwifi 0000:00:0a.0: 0x004D94DA | data1
[39936.353933] iwlwifi 0000:00:0a.0: 0x01000000 | data2
[39936.353950] iwlwifi 0000:00:0a.0: 0x00000000 | data3
[39936.353964] iwlwifi 0000:00:0a.0: 0x00000000 | beacon time
[39936.353978] iwlwifi 0000:00:0a.0: 0x000EA9FE | tsf low
[39936.353992] iwlwifi 0000:00:0a.0: 0x00000000 | tsf hi
[39936.354007] iwlwifi 0000:00:0a.0: 0x00000000 | time gp1
[39936.354023] iwlwifi 0000:00:0a.0: 0x000FF89E | time gp2
[39936.354037] iwlwifi 0000:00:0a.0: 0x00000001 | uCode revision type
[39936.354054] iwlwifi 0000:00:0a.0: 0x00000042 | uCode version major
[39936.354071] iwlwifi 0000:00:0a.0: 0xF1C864E0 | uCode version minor
[39936.354091] iwlwifi 0000:00:0a.0: 0x00000420 | hw version
[39936.354105] iwlwifi 0000:00:0a.0: 0x18C89002 | board version
[39936.354122] iwlwifi 0000:00:0a.0: 0x8004FC12 | hcmd
[39936.354139] iwlwifi 0000:00:0a.0: 0x00020000 | isr0
[39936.354153] iwlwifi 0000:00:0a.0: 0x00000000 | isr1
[39936.354167] iwlwifi 0000:00:0a.0: 0x00F00002 | isr2
[39936.354184] iwlwifi 0000:00:0a.0: 0x00C0000C | isr3
[39936.354198] iwlwifi 0000:00:0a.0: 0x00000000 | isr4
[39936.354212] iwlwifi 0000:00:0a.0: 0x00000000 | last cmd Id
[39936.354229] iwlwifi 0000:00:0a.0: 0x004D94DA | wait_event
[39936.354243] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_control
[39936.354257] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_duration
[39936.354275] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_mhvalid
[39936.354289] iwlwifi 0000:00:0a.0: 0x00000000 | l2p_addr_match
[39936.354306] iwlwifi 0000:00:0a.0: 0x00000009 | lmpm_pmg_sel
[39936.354320] iwlwifi 0000:00:0a.0: 0x00000000 | timestamp
[39936.354334] iwlwifi 0000:00:0a.0: 0x001C0000 | flow_handler
[39936.354428] iwlwifi 0000:00:0a.0: Start IWL Error Log Dump:
[39936.354444] iwlwifi 0000:00:0a.0: Transport status: 0x00000042, valid: 7
[39936.354478] iwlwifi 0000:00:0a.0: 0x20000066 | NMI_INTERRUPT_HOST
[39936.354496] iwlwifi 0000:00:0a.0: 0x00000000 | umac branchlink1
[39936.354512] iwlwifi 0000:00:0a.0: 0x8045DFC6 | umac branchlink2
[39936.354532] iwlwifi 0000:00:0a.0: 0x8047FAB6 | umac interruptlink1
[39936.354549] iwlwifi 0000:00:0a.0: 0x8047FAB6 | umac interruptlink2
[39936.354566] iwlwifi 0000:00:0a.0: 0x01000000 | umac data1
[39936.354583] iwlwifi 0000:00:0a.0: 0x8047FAB6 | umac data2
[39936.354597] iwlwifi 0000:00:0a.0: 0x00000000 | umac data3
[39936.354611] iwlwifi 0000:00:0a.0: 0x00000042 | umac major
[39936.354625] iwlwifi 0000:00:0a.0: 0xF1C864E0 | umac minor
[39936.354642] iwlwifi 0000:00:0a.0: 0x000FF99C | frame pointer
[39936.354659] iwlwifi 0000:00:0a.0: 0xC088625C | stack pointer
[39936.354676] iwlwifi 0000:00:0a.0: 0x00000000 | last host cmd
[39936.354693] iwlwifi 0000:00:0a.0: 0x00000400 | isr status reg
[39936.354758] iwlwifi 0000:00:0a.0: IML/ROM dump:
[39936.354775] iwlwifi 0000:00:0a.0: 0x00000B03 | IML/ROM error/state
[39936.354832] iwlwifi 0000:00:0a.0: 0x00008483 | IML/ROM data1
[39936.354909] iwlwifi 0000:00:0a.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[39936.354980] iwlwifi 0000:00:0a.0: Fseq Registers:
[39936.355027] iwlwifi 0000:00:0a.0: 0x60000100 | FSEQ_ERROR_CODE
[39936.355078] iwlwifi 0000:00:0a.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[39936.355126] iwlwifi 0000:00:0a.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[39936.355172] iwlwifi 0000:00:0a.0: 0x0000A652 | FSEQ_OTP_VERSION
[39936.355219] iwlwifi 0000:00:0a.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[39936.355267] iwlwifi 0000:00:0a.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[39936.355314] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVI_ID
[39936.355362] iwlwifi 0000:00:0a.0: 0x00400410 | FSEQ_CNVR_ID
[39936.355409] iwlwifi 0000:00:0a.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[39936.355457] iwlwifi 0000:00:0a.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[39936.355500] iwlwifi 0000:00:0a.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[39936.355562] iwlwifi 0000:00:0a.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[39936.355611] iwlwifi 0000:00:0a.0: Failed to start RT ucode: -110
[39936.355629] iwlwifi 0000:00:0a.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[39938.634222] iwlwifi 0000:00:0a.0: Failed to run INIT ucode: -110
[39938.662163] iwlwifi 0000:00:0a.0: retry init count 2
It does matter what dom0 kernel is. Try with kernel 6.1 in dom0.
DVM
November 19, 2023, 12:50pm
49
A new firmware build was pushed to the fedora testing repo a few days ago. if you want to try it, run this command in your sys-net template (it should be fedora-38 by default):
sudo dnf install --enablerepo=updates-testing linux-firmware-20231111 iwlegacy-firmware-20231111 iwlwifi-dvm-firmware-20231111 iwlwifi-mvm-firmware-20231111
I don’t see anything related to iwlwifi in the changelog, but you can still test it and see.
Thanks. I ran this command and restarted my sys-net and my wifi was working! But none of my USB devices worked… (my sys-net also handles my usb). This made me think that I had screwed up something in my sys-net appvm. I created a new sys-net (“sys-net2”), set it as providing networking and attached all the network and USB devices to it. Now things seem to be working fine - wifi and USB devices are working. I don’t know if it was the new firmware or the new appvm that did it. If knowing the answer would be helpful to anyone, I’m happy to run diagnostic commands and share the output. But for now things seems too be working for me.
Thanks all for the help sorting this out.
DVM
November 20, 2023, 2:31pm
51
I don’t think there’s anything else to troubleshoot, I’m sure the USB issue is not related to the firmware. We’ll see if anyone else gets the same result with the new firmware. Glad you got it working.
