When I boot normally, I have no internet. The network icon spins but does not connect (ethernet). However, with the qubes.skip_autostart kernel entry, the internet does work.
When I execute dmesg in sys-net, these logs are repeated:
igb 0000:00:06.0 ens6: Reset adapter
igb 0000:00:06.0 ens6: igb: ens6 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
There is also a repeated message Detected Tx Unit Hang
Further, I have been unable to recreate the context but in one instance the network manager returned that connection activation failed because the device ens did not have a carrier.
I tried the detaching, reattaching with ‘qvm-pci attach sys-net --persistent --option no-strict-reset=true dom0:05_00.0’, and rebooting but that did not solve the issue. I also used the GUI to detach and reattach.
I also configured sys-net(and childern) not to start on boot, and that didn’t work either.
I don’t think it is a driver issue since I can connect when I boot with skip_autostart.
Thanks!!
