Let’s note first that the last screenshot above is just not what I wanted to post, that would rather have shown a screen with the following.
To gather more info, I reinstalled the debian-10 template, and launched bash -x qubes-dist-upgrade --template-standalone-upgrade --only-update debian-10.
We see apt uninstalling a qrexec package and installing a new qrexec package, but not starting the service:
dpkg: qubes-core-agent-qrexec: dependency problems, but removing anyway as you requested:
qubes-core-agent depends on qubes-core-agent-qrexec; however:
Package qubes-core-agent-qrexec is to be removed.
Setting up qubes-core-qrexec (4.1.13-1+deb10u1) ...
/usr/sbin/policy-rc.d returned 101, not running 'start qubes-qrexec-agent.service'
Setting up qubes-core-agent (4.1.26-1+deb10u1) ...
With just that, at next start this domain aborts the same connection failure as above:
At first I thought it would be upgrade-template-standalone.sh failing to remove the policy-rc.d script preventing the run of qrexec service, but that one is removed.
Now if I before letting the just-updated VM be shutdown by qubes-dist-upgrade I get a terminal in there and take a look at the service, we can see it did start, but will fail to start again, with “a timeout”:
root@debian-10:~# systemctl |grep qrexec
qubes-qrexec-agent.service loaded active running Qubes remote exec agent
root@debian-10:~# systemctl stop qubes-qrexec-agent.service
root@debian-10:~# systemctl start qubes-qrexec-agent.service
Job for qubes-qrexec-agent.service failed because a timeout was exceeded.
See "systemctl status qubes-qrexec-agent.service" and "journalctl -xe" for details.
root@debian-10:~# systemctl status qubes-qrexec-agent.service
● qubes-qrexec-agent.service - Qubes remote exec agent
Loaded: loaded (/lib/systemd/system/qubes-qrexec-agent.service; enabled; vendor preset: enabled)
Active: failed (Result: timeout) since Thu 2021-07-22 18:54:14 EDT; 52s ago
Process: 25929 ExecStartPre=/bin/sh -c [ -e /dev/xen/evtchn ] || modprobe xen_evtchn (code=exited, status=0/SUCCESS)
Process: 25930 ExecStart=/usr/lib/qubes/qrexec-agent (code=killed, signal=TERM)
Main PID: 25930 (code=killed, signal=TERM)
Jul 22 18:52:44 debian-10 systemd[1]: Starting Qubes remote exec agent...
Jul 22 18:54:14 debian-10 systemd[1]: qubes-qrexec-agent.service: Start operation timed out. Terminating.
Jul 22 18:54:14 debian-10 systemd[1]: qubes-qrexec-agent.service: Main process exited, code=killed, status=15/TERM
Jul 22 18:54:14 debian-10 systemd[1]: qubes-qrexec-agent.service: Failed with result 'timeout'.
Jul 22 18:54:14 debian-10 systemd[1]: Failed to start Qubes remote exec agent.
root@debian-10:~# journalctl -xe
-- The job identifier is 5638.
Jul 22 18:52:33 debian-10 systemd[1]: qubes-qrexec-agent.service: Main process exited, code=killed, status=15/TERM
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStart= process belonging to unit qubes-qrexec-agent.service has exited.
-- The process' exit code is 'killed' and its exit status is 15.
Jul 22 18:52:33 debian-10 systemd[1]: qubes-qrexec-agent.service: Succeeded.
-- Subject: Unit succeeded
-- The unit qubes-qrexec-agent.service has successfully entered the 'dead' state.
Jul 22 18:52:33 debian-10 systemd[1]: Stopped Qubes remote exec agent.
-- Subject: A stop job for unit qubes-qrexec-agent.service has finished
-- A stop job for unit qubes-qrexec-agent.service has finished.
-- The job identifier is 5638 and the job result is done.
-- Subject: A start job for unit qubes-qrexec-agent.service has begun execution
-- A start job for unit qubes-qrexec-agent.service has begun execution.
-- The job identifier is 5639.
-- Subject: Unit failed
-- The unit qubes-qrexec-agent.service has entered the 'failed' state with result 'timeout'.
-- Subject: A start job for unit qubes-qrexec-agent.service has failed
-- A start job for unit qubes-qrexec-agent.service has finished with a failure.
-- The job identifier is 5639 and the job result is failed.
Trying stage2 on the fedora-32 template gives alarming traces without waiting to a VM restart:
Running scriptlet: qubes-core-qrexec-vm-4.1.13-1.fc32.x86_64 209/209
Created symlink /etc/systemd/system/qubes-core-agent.service ___ /usr/lib/systemd/system/qubes-qrexec-agent.service.
Created symlink /etc/systemd/system/multi-user.target.wants/qubes-qrexec-agent.service ___ /usr/lib/systemd/system/qubes-qrexec-agent.service.
warning: %posttrans(qubes-core-qrexec-vm-4.1.13-1.fc32.x86_64) scriptlet failed, exit status 1
Error in POSTTRANS scriptlet in rpm package qubes-core-qrexec-vm
Running scriptlet: qubes-core-agent-4.1.26-1.fc32.x86_64 209/209
Running scriptlet: qubes-gui-agent-4.1.18-1.fc32.x86_64 209/209
Running scriptlet: xen-runtime-4.13.3-1.fc32.x86_64 209/209
ls: cannot access '/usr/lib/xen': No such file or directory
Running scriptlet: qubes-kernel-vm-support-4.1.15-1.fc32.x86_64 209/209
Running scriptlet: qubes-db-libs-4.0.16-1.fc32.x86_64 209/209
From there the update script exits without shutting the domain down, and I cannot get a terminal to get launched in there for investigation.
