Here is my partition setup currently. Still has some errors. What exactly?
Can i get some normal explananation with / and /swap ? I just want to resize a bit of windows to free space and try system.
Theres another option in comment reply posting im trying to edit in Blivet-Gui partition manager with LVM2 partition and in it needed to make something inside also.
Heres LVM2 partition test, also not working.
How to delete this reply, cant. I put all in one post, since now i can put more pics in one post. Admin plz detele this reply. I move deez pics in one post, since now i can put more pics in one post.
yeah. there will a pop up because you need some space, delete some partition that you have shrinked from win 10 and proceed. it’s okay to upload image again if you not sure. as long as you don’t click Begin Installation, everything you configure in gui wouldn’t be applied.
In windows theres nothing. I backed up. Just keeping in case will need to do TPM 2 to 1.2 downgrade to test 4.1 with AEM. I like Kubuntu, doing a lot bugreports for all Ubuntu distros, but now will test Qubes OS.
Oh, wow. Cool. This Automatic needs to be renamed Automatic resizing partitioning wizzard.
Otherwise i thought other 2 options do the resizing, but Automatic i thought will take all.
So i selected windows 10 partition, shrink, no button to finishing shringing, so on shrinking cant do any other options, but clicking shrinking needs to be last option that keeps the amount in field renamed Total reclaimed space for Qubes Os sinstallation. That would be needed to write also. 2 bug suggestions for better UX understanding of simple dimple installers.
Thanks!
well this has nothing to do with qubes, since we use anaconda installer.
btw, i would suggest that you shrink partition in win10 diskmgmt first, so you know the exact partition / size, then back here and delete the partition, after that reclaim space and just proceed with installation.
Got in setup resizing info already. Anaconda doing all commands.
Yes, ive read all the time in all installers to do better windows resizing, in case some error bug happens. Havent yet got one, but testing with clean systems. On real system need better to have windows disk managment use to do resizing to resize their systems.
Im waiting until some bug happens with linux resizers, looks like gnu/linux installers do so far allways perfect resizing.
Im specially allways, if installers offer resizing, then letting linux do that, since ive never yet got any bug. Im just doing without windows resizing to find error and bug in linux resizers gparted editors.
Now already all systems allow at least windows resizing. Next step would be also linux partition moving and resizing.
And got system up!
Soon ill write what to do to make Qubes OS working.
Should i test 4.0.4 also? It was not starting in UEFI as 4.1, so i read that a lot something new, so maybe not to even try 4.0.4 since only new year need to wait and wake up from hangover and 4.1 could be decided that is final?
So now after installation Qubes started, i didnt noticed windows choosing option.
So i entered disk decrypt password once, it continued loading, but still asking disk password, then 2nd time used wrong password, then still asking, 3rd time entered same 1st time entered correct password. It loaded slowly a bit more. Found already that left right i cen get console and this is error i got. Then i pressed CTRL+D and now its not moving.
Rebooted, from bios boot menu checked windows is working. Was only windows selection, thats normal since disk size changed.
So windows working, thats cool.
Rebooted again and let qubes finish loading. Loads long, entered password. Turns out password i forgot?
Maybe too many other bios setting i set up? I turned on all, what was not on in bios, except secure boot i kept off.
just go with qubes 4.1-rc3, looks like it would go stable in 1-2 months
this called dracut emergency shell, could be you entered wrong password or wrong fstab, normally with automatic partition there should be no issue with fstab, since you are installing in middle sector this could be an issue too.
I would suggest that you use separate disk instead of dual booting in the same disk, or if you want, you can install win 10 in beginning sector - 120GB , then leave the rest of space unpartitioned, so qubes os isn’t in the middle sector.
Good morning. I fell asleep while testing. Now i can write a book- adventures on 1st day of mistakes with qube sos. Now got all running but now turns out Dell lattitude e5470 wifi 8260 not working. Found google discussions. There no problems mentioned. Maybe tpm 2.0 makes it not work? Is that possible?
So back to experience story where we left on wrong password and in end where im stuck now:
Ah, yes lol i made password mistake not looking at keyboard i set one symbol lower when setting passowrd. I got in now guessing correct. Tried symbol one left, one right, one down. Worked when found correct.
Now before finishing installation went into CTRL+f1 or f2 did again ctrl+alt+del estart on purpouse this time with worng password to check commands.
So now i rebooted again and now continued with correct passw.
In setup i changed only to default to be Debian 11
All loading, installing.
Language change shows multiple english and come C language??
After some time loading of of installation moving all the time then this last template stopped moving. Mouse moves, but this last loading bar isnt moving, but i will wait this time.
Ctrl+F1 just hide the mouse, TTy was not openeging any tty. ctrl+f2 got back showing mouse. So i toggle multiple times like that until the non moving loading gone and showing LOG IN.
Cool BUT
FORGOT user PASSWORD
Oh, then it asked for log in.
OH OH. Now this password i made also such that i dont remember? Tested multiple. Ok will remake password or reinstall.
Booted usb install recovery. Something didnt like after auto detecting sda6 and unlocking it.
Got shell.
Found commands to fix (space for links later)
I got into root cause was no root pasword set even if root disabled?
Changed one symbol password- got warning palindrome (what?)
Changed different passowrd- got warning 8 symbols needed (what?)
Changed another password- got warning dictionary based word something (what?)
Changed another password- ok.
QUBES WORKING
Testing i dont know what. Something Whonix asking to do some wizzard for internet. its not moving- maybe cause no initernet.
Getting to know system. Manually adding wifi.
Morning- woke up. So all working Except wifi Showing only ethernet
Went to connect to lan.
Updating
Opened some disposable firefox.
Update app star in notification came up.
Clicked update not from there but from menu qubes update.
Clicked all. Updating. Very slow.
Clicked disposable firefox about- it also starts updating.
Got in updated finishing updating- but error for whonix-ws-16.
After update process finishing did again that what failed alone- but circle was not moving rotation.
Also got this error before on after reboot and another update test since wifi wasnt still updated to work. Or maybe i opened something and it was this error while updating.
Disposable firefox opening it asks for restart it. Restarted. Updated version. Closed. Reopened disposble firefox. It start updating again.
Other updates someting failing.
Clicked only failed one. All ok.
Did again all update- all went ok. But why its showing that each time something updated even if i updated all- Succeeded 2 )changed-1(
Wifi troubleshooting and how i rocked vm templates and got back correct or incorrect
Dont remember if sys-net had wifi 8260 in or i shut down each that said that cant shut down that need to shutdown other something so shut down each template. So i added 8260 wifi or it was there.
Starting all. No wifi still
Clicked usb devices Broadcomm (im thinking is this my wifi with differend name now? lets try) clicked to connect it to sys-net.
Added in usb i think wifi 8260.
Closing 4 active vm templates.
Got some error. App hanging.
Reboot. sys-usb not starting.
Removed sys-usb with commands.
As i mentioned before- wifi i put in sys-net when shutting down each related templates.
Lan and wifi are in sys-net template. Maybe something else also need to add from drivers in here?
Hmm. cant post clipbord screenshot or drag here screenshot. Very secure. But what to do when i want to allow for second? I cant put screenshot here, cant paste dom0 screenshot clipboard here and cant move saved screenshot file to another vm
Qubes domains Qube manager settings of template and changing to fedora or right click to change template.
Even better shut down is here then from notification. In here it asks do i want to shutdown all related ones. In notifications only one by one i can.
So i changed to Fedora and works- auto connected since in nm-applet i already put all credentials.
But i havend tried fedora, since dont want to learn too confusing commands, but for testing i installed without removing fedora. What to do to thouse who didnt installed Fedora? So then theres Debian thing bug then we have found.
Also did one more command- maybe this helps to find bug?
dmesg in net-sys shows some error
[ 3.746288] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-36.ucode failed with error -2
Here about error -33 but debian users get (as i got now here got) -36
Theres mentioned to install sudo apt install linux-firmware but i get E: Unable to locate package linux-firmware
TL:DR dmesg wifi error TL:DR part of error i see related to wifi
dmesg TL full result dmesg TL full result - Pastebin.com but i copied out main things i understood that are around wifi.
Since this error is at end of dmesh then copied till end and a bit before error lines where i think its about wifi
[ 2.696771] Adding 1048572k swap on /dev/xvdc1. Priority:-2 extents:1 across:1048572k SSFS
[ 2.770626] EXT4-fs (xvda3): re-mounted. Opts: discard
[ 2.772395] lp: driver loaded but no devices found
[ 2.786324] systemd-journald[226]: Received client request to flush runtime journal.
[ 2.790356] ppdev: user-space parallel port driver
[ 2.822780] xen:xen_evtchn: Event-channel device installed
[ 2.886912] memmap_init_zone_device initialised 32768 pages in 0ms
[ 3.229922] FDC 0 is a S82078B
[ 3.255016] piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
[ 3.317061] e1000e: Intel(R) PRO/1000 Network Driver
[ 3.317085] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.318609] xen: --> pirq=16 -> irq=44 (gsi=44)
[ 3.322329] e1000e 0000:00:07.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 3.349127] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.357030] ehci-pci: EHCI PCI platform driver
[ 3.360602] ehci-pci 0000:00:05.0: EHCI Host Controller
[ 3.372595] ehci-pci 0000:00:05.0: new USB bus registered, assigned bus number 1
[ 3.374205] ehci-pci 0000:00:05.0: irq 39, io mem 0xf2035000
[ 3.382727] ehci-pci 0000:00:05.0: USB 2.0 started, EHCI 1.00
[ 3.386224] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 3.406537] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.406590] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.406620] usb usb1: Product: EHCI Host Controller
[ 3.406640] usb usb1: Manufacturer: Linux 5.10.76-1.fc32.qubes.x86_64 ehci_hcd
[ 3.406683] usb usb1: SerialNumber: 0000:00:05.0
[ 3.425644] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.446992] hub 1-0:1.0: USB hub found
[ 3.447983] hub 1-0:1.0: 6 ports detected
[ 3.465777] Error: Driver 'pcspkr' is already registered, aborting...
[ 3.512843] e1000e 0000:00:07.0 0000:00:07.0 (uninitialized): registered PHC clock
[ 3.578254] e1000e 0000:00:07.0 eth0: (PCI Express:2.5GT/s:Width x1) 84:7b:eb:2a:1c:d3
[ 3.578318] e1000e 0000:00:07.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.578442] e1000e 0000:00:07.0 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[ 3.639892] e1000e 0000:00:07.0 ens7: renamed from eth0
[ 3.644228] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.646462] EXT4-fs (xvdb): mounted filesystem with ordered data mode. Opts: discard
[ 3.647316] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 3.739879] Intel(R) Wireless WiFi driver for Linux
[ 3.740784] xen: --> pirq=17 -> irq=40 (gsi=40)
[ 3.745363] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 3.746302] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-35.ucode failed with error -2
[ 3.746314] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-34.ucode failed with error -2
[ 3.746325] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-33.ucode failed with error -2
[ 3.746337] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-32.ucode failed with error -2
[ 3.746349] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-31.ucode failed with error -2
[ 3.746361] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-30.ucode failed with error -2
[ 3.746373] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-29.ucode failed with error -2
[ 3.746384] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-28.ucode failed with error -2
[ 3.746395] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-27.ucode failed with error -2
[ 3.746407] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-26.ucode failed with error -2
[ 3.746417] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-25.ucode failed with error -2
[ 3.746429] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-24.ucode failed with error -2
[ 3.746440] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-23.ucode failed with error -2
[ 3.746451] iwlwifi 0000:00:06.0: Direct firmware load for iwlwifi-8000C-22.ucode failed with error -2
[ 3.746452] iwlwifi 0000:00:06.0: no suitable firmware found!
[ 3.746453] iwlwifi 0000:00:06.0: minimum version required: iwlwifi-8000C-22
[ 3.746454] iwlwifi 0000:00:06.0: maximum version supported: iwlwifi-8000C-36
[ 3.746455] iwlwifi 0000:00:06.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
[ 3.905335] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
[ 3.905369] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
[ 3.905412] usb 1-1: Product: QEMU USB Tablet
[ 3.905432] usb 1-1: Manufacturer: QEMU
[ 3.905455] usb 1-1: SerialNumber: 42
[ 3.929687] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:05.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input6
[ 3.929788] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:05.0-1/input0
[ 3.969862] audit: type=1400 audit(1640180780.674:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=430 comm="apparmor_parser"
[ 3.971817] audit: type=1400 audit(1640180780.680:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=432 comm="apparmor_parser"
[ 3.976842] audit: type=1400 audit(1640180780.685:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=434 comm="apparmor_parser"
[ 3.976913] audit: type=1400 audit(1640180780.685:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=434 comm="apparmor_parser"
[ 3.988656] audit: type=1400 audit(1640180780.696:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=431 comm="apparmor_parser"
[ 3.997077] audit: type=1400 audit(1640180780.701:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=440 comm="apparmor_parser"
[ 3.997258] audit: type=1400 audit(1640180780.701:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=440 comm="apparmor_parser"
[ 4.037808] audit: type=1400 audit(1640180780.701:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=440 comm="apparmor_parser"
[ 4.058767] audit: type=1400 audit(1640180780.765:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=442 comm="apparmor_parser"
[ 14.575405] vif vif-28-0 vif28.0: Guest Rx ready
[ 14.575438] IPv6: ADDRCONF(NETDEV_CHANGE): vif28.0: link becomes ready
[ 37.491696] e1000e 0000:00:07.0 ens7: NIC Link is Up 100 Mbps Half Duplex, Flow Control: Rx/Tx
[ 37.491780] e1000e 0000:00:07.0 ens7: 10/100 speed: disabling TSO
[ 37.493294] e1000e 0000:00:07.0 ens7: NIC Link is Down
[ 39.182279] e1000e 0000:00:07.0 ens7: NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 39.182401] e1000e 0000:00:07.0 ens7: 10/100 speed: disabling TSO
[ 39.182761] IPv6: ADDRCONF(NETDEV_CHANGE): ens7: link becomes ready
Another thing i found here- GPU disabled maybe meakes use more battery?
Windows i had 8h left if using a bit. 12h if not moving.
If using Windows then 6h. If non stop then 4h-2h even.
Qubes OS currently if no battery wrong showing erros then showed 4h, but i didnt let it go to zero, to see if theres no wrong calculations.
Maybe need to disable nomodeset?
[ 0.056416] Kernel command line: root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 xen_scrub_pages=0 apparmor=1 security=apparmor
[ 0.056439] You have booted with nomodeset. This means your GPU drivers are DISABLED
[ 0.056440] Any video related functionality will be severely degraded, and you may not even be able to suspend the system properly
[ 0.056441] Unless you actually understand what nomodeset does, you should reboot without enabling it
even disabling ethernet can reduce battery consumption. so yes.
And i think editing thread tittle to something like “kangarooo qubes os journal” is preferred. Since there’s a ton of problem and you solve it by yourself
Yeah, it became a draft for a Qubes Os advertisement it blog post about 1st user testing and how to solve.
Also will help new users for multiple problems especially Debian users with Dell latitude e5470 wifi intel 8260. Could be a blog of this specification testing of compatibility.
I thought would be weird for each problem new post.
Maybe could each hw setup have one thread with posts of related problems. Somehow it became like that.
But thouse are things that came up and usual user would not be able to solve, so needs some fixings so works out-of-box.
Another idea- whole Qubes OS website in github is cool so could be imported in installation also, so without internet could browse all. Its showing its only 2.2MB.
But since its possible to install only debian, then if its not working wifi, then that should be fixed to work out-of-box and i still dont know how to fix it in-the-box.
@Kangarooo : please don’t write your life in the title, thank.
The original title was : 4.1 rc3 testing How to Dual Boot Qubes OS with Windows 10 automatic partitioning wizzard? Wifi Not working Dell latitude e5470 UEFI TPM 2.0. UX story: some no indications of system beeing busy, fixing vm domain templates, wifi is installed but not working
Hey man im getting into Qubes myself and im having a hardtime getting sys-net to connect to a network so I can actually use the thing… im having a hardtime understanding how you made it work and how you changed the template of sys-net
