user@debian-11-clone-1:~$ sudo apt-get install quiterss
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libqt5sensors5 libqt5webkit5
The following NEW packages will be installed:
libqt5sensors5 libqt5webkit5 quiterss
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 13.1 MB of archives.
After this operation, 53.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://deb.debian.org/debian bullseye/main amd64 libqt5sensors5 amd64 5.15.2-2 [112 kB]
Get:2 https://deb.debian.org/debian bullseye/main amd64 libqt5webkit5 amd64 5.212.0~alpha4-11 [11.7 MB]
Get:3 https://deb.debian.org/debian bullseye/main amd64 quiterss amd64 0.19.4+dfsg-1 [1,272 kB]
Fetched 13.1 MB in 3s (5,207 kB/s)
Selecting previously unselected package libqt5sensors5:amd64.
(Reading database ... 132439 files and directories currently installed.)
Preparing to unpack .../libqt5sensors5_5.15.2-2_amd64.deb ...
Unpacking libqt5sensors5:amd64 (5.15.2-2) ...
Selecting previously unselected package libqt5webkit5:amd64.
Preparing to unpack .../libqt5webkit5_5.212.0~alpha4-11_amd64.deb ...
Unpacking libqt5webkit5:amd64 (5.212.0~alpha4-11) ...
Selecting previously unselected package quiterss.
Preparing to unpack .../quiterss_0.19.4+dfsg-1_amd64.deb ...
Unpacking quiterss (0.19.4+dfsg-1) ...
Setting up libqt5sensors5:amd64 (5.15.2-2) ...
Setting up libqt5webkit5:amd64 (5.212.0~alpha4-11) ...
Setting up quiterss (0.19.4+dfsg-1) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.31-13+deb11u2) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for qubes-core-agent (4.1.27-1+deb11u1) ...
*/etc/qubes-rpc/qubes.GetAppmenus: line 51: cd: /home/user/.local/share/applications: No such file or directory*
*/etc/qubes-rpc/qubes.GetAppmenus: line 51: cd: /usr/local/share//applications: No such file or directory*
Processing triggers for mailcap (3.69) ...
anyone noticing that mouse pointer size can NOT be increased ? 2 systems so far, both don’t allow in XFCE settings
