Hello,
I try to get a newly installed Intel AX210 Wifi card working in Qubes 4.1 with Fedora 36 templates.
[user@sys-net ~]$ lspci
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01)
00:04.0 VGA compatible controller: Device 1234:1111 (rev 02)
00:05.0 USB controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 10)
00:06.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:07.0 Ethernet controller: Intel Corporation Ethernet Connection (4) I219-V (rev 21)
00:08.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
I followed the instructions in AX210/211 WiFi card not showing any networks - #10 by ned and did
sudo mv /lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm.xz ~
Unfortunately, after restarting all qubes, I get only errors n dmesg.
$ sudo dmesg | grep "iwl"
3.705097] iwlwifi 0000:00:08.0: api flags index 2 larger than supported by driver
[ 3.705154] iwlwifi 0000:00:08.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.34
[ 3.705504] iwlwifi 0000:00:08.0: loaded firmware version 67.8f59b80b.0 ty-a0-gf-a0-67.ucode op_mode iwlmvm
[ 3.792559] iwlwifi 0000:00:08.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 3.801825] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[ 3.801851] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[ 3.801893] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[ 4.208116] iwlwifi 0000:00:08.0: Timeout waiting for PNVM load!
[ 4.208141] iwlwifi 0000:00:08.0: Failed to start RT ucode: -110
[ 4.208162] iwlwifi 0000:00:08.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.209299] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 4.209333] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 6
[ 4.209353] iwlwifi 0000:00:08.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[ 4.209378] iwlwifi 0000:00:08.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4.209397] iwlwifi 0000:00:08.0: 0x002002F0 | trm_hw_status0
[ 4.209415] iwlwifi 0000:00:08.0: 0x00000000 | trm_hw_status1
[ 4.209433] iwlwifi 0000:00:08.0: 0x004DAC6A | branchlink2
[ 4.209448] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink1
[ 4.209466] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink2
[ 4.209484] iwlwifi 0000:00:08.0: 0x004D9A0A | data1
[ 4.209499] iwlwifi 0000:00:08.0: 0x01000000 | data2
[ 4.209514] iwlwifi 0000:00:08.0: 0x00000000 | data3
[ 4.209529] iwlwifi 0000:00:08.0: 0x00000000 | beacon time
[ 4.209544] iwlwifi 0000:00:08.0: 0x000504C5 | tsf low
[ 4.209559] iwlwifi 0000:00:08.0: 0x00000000 | tsf hi
[ 4.209574] iwlwifi 0000:00:08.0: 0x00000000 | time gp1
[ 4.209588] iwlwifi 0000:00:08.0: 0x000626CD | time gp2
[ 4.209603] iwlwifi 0000:00:08.0: 0x00000001 | uCode revision type
[ 4.209622] iwlwifi 0000:00:08.0: 0x00000043 | uCode version major
[ 4.209640] iwlwifi 0000:00:08.0: 0x8F59B80B | uCode version minor
[ 4.209658] iwlwifi 0000:00:08.0: 0x00000420 | hw version
[ 4.209673] iwlwifi 0000:00:08.0: 0x18489002 | board version
[ 4.209691] iwlwifi 0000:00:08.0: 0x8005FC00 | hcmd
[ 4.209706] iwlwifi 0000:00:08.0: 0x00020000 | isr0
[ 4.209720] iwlwifi 0000:00:08.0: 0x00000000 | isr1
[ 4.209735] iwlwifi 0000:00:08.0: 0x48F00002 | isr2
[ 4.209749] iwlwifi 0000:00:08.0: 0x00C0000C | isr3
[ 4.209764] iwlwifi 0000:00:08.0: 0x00000000 | isr4
[ 4.209779] iwlwifi 0000:00:08.0: 0x00000000 | last cmd Id
[ 4.209794] iwlwifi 0000:00:08.0: 0x004D9A0A | wait_event
[ 4.209809] iwlwifi 0000:00:08.0: 0x00000000 | l2p_control
[ 4.209824] iwlwifi 0000:00:08.0: 0x00000000 | l2p_duration
[ 4.209839] iwlwifi 0000:00:08.0: 0x00000000 | l2p_mhvalid
[ 4.209854] iwlwifi 0000:00:08.0: 0x00000000 | l2p_addr_match
[ 4.209872] iwlwifi 0000:00:08.0: 0x00000009 | lmpm_pmg_sel
[ 4.209887] iwlwifi 0000:00:08.0: 0x00000000 | timestamp
[ 4.209916] iwlwifi 0000:00:08.0: 0x00000020 | flow_handler
[ 4.209982] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 4.209996] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 7
[ 4.210014] iwlwifi 0000:00:08.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 4.210032] iwlwifi 0000:00:08.0: 0x00000000 | umac branchlink1
[ 4.210050] iwlwifi 0000:00:08.0: 0x8045E20E | umac branchlink2
[ 4.210067] iwlwifi 0000:00:08.0: 0x8047FD96 | umac interruptlink1
[ 4.210085] iwlwifi 0000:00:08.0: 0xC00821D6 | umac interruptlink2
[ 4.210102] iwlwifi 0000:00:08.0: 0x01000000 | umac data1
[ 4.210117] iwlwifi 0000:00:08.0: 0xC00821D6 | umac data2
[ 4.210131] iwlwifi 0000:00:08.0: 0x00000000 | umac data3
[ 4.210146] iwlwifi 0000:00:08.0: 0x00000043 | umac major
[ 4.210249] iwlwifi 0000:00:08.0: 0x8F59B80B | umac minor
[ 4.210266] iwlwifi 0000:00:08.0: 0x00062827 | frame pointer
[ 4.210298] iwlwifi 0000:00:08.0: 0xC0887EF4 | stack pointer
[ 4.210316] iwlwifi 0000:00:08.0: 0x00000000 | last host cmd
[ 4.210333] iwlwifi 0000:00:08.0: 0x00000404 | isr status reg
[ 4.210370] iwlwifi 0000:00:08.0: IML/ROM dump:
[ 4.210384] iwlwifi 0000:00:08.0: 0x00000B03 | IML/ROM error/state
[ 4.210420] iwlwifi 0000:00:08.0: 0x00007695 | IML/ROM data1
[ 4.210456] iwlwifi 0000:00:08.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 4.210490] iwlwifi 0000:00:08.0: Fseq Registers:
[ 4.210516] iwlwifi 0000:00:08.0: 0x60000100 | FSEQ_ERROR_CODE
[ 4.210546] iwlwifi 0000:00:08.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 4.210577] iwlwifi 0000:00:08.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 4.210608] iwlwifi 0000:00:08.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 4.210637] iwlwifi 0000:00:08.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 4.225066] iwlwifi 0000:00:08.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4.225098] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVI_ID
[ 4.225126] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVR_ID
[ 4.225155] iwlwifi 0000:00:08.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 4.225188] iwlwifi 0000:00:08.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 4.225220] iwlwifi 0000:00:08.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.225257] iwlwifi 0000:00:08.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.814277] iwlwifi 0000:00:08.0: Failed to run INIT ucode: -110
[ 4.828112] iwlwifi 0000:00:08.0: retry init count 0
[ 4.828805] iwlwifi 0000:00:08.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.856914] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[ 4.856979] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[ 4.857003] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[ 5.256201] iwlwifi 0000:00:08.0: Timeout waiting for PNVM load!
[ 5.256297] iwlwifi 0000:00:08.0: Failed to start RT ucode: -110
[ 5.256382] iwlwifi 0000:00:08.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 5.257639] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 5.257705] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 6
[ 5.257782] iwlwifi 0000:00:08.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[ 5.257884] iwlwifi 0000:00:08.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 5.258000] iwlwifi 0000:00:08.0: 0x002002F0 | trm_hw_status0
[ 5.258075] iwlwifi 0000:00:08.0: 0x00000000 | trm_hw_status1
[ 5.258148] iwlwifi 0000:00:08.0: 0x004DAC6A | branchlink2
[ 5.258418] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink1
[ 5.258500] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink2
[ 5.258578] iwlwifi 0000:00:08.0: 0x004D9A0A | data1
[ 5.258639] iwlwifi 0000:00:08.0: 0x01000000 | data2
[ 5.258699] iwlwifi 0000:00:08.0: 0x00000000 | data3
[ 5.258759] iwlwifi 0000:00:08.0: 0x00000000 | beacon time
[ 5.258821] iwlwifi 0000:00:08.0: 0x0004EE49 | tsf low
[ 5.258883] iwlwifi 0000:00:08.0: 0x00000000 | tsf hi
[ 5.258942] iwlwifi 0000:00:08.0: 0x00000000 | time gp1
[ 5.259084] iwlwifi 0000:00:08.0: 0x00061054 | time gp2
[ 5.259148] iwlwifi 0000:00:08.0: 0x00000001 | uCode revision type
[ 5.259222] iwlwifi 0000:00:08.0: 0x00000043 | uCode version major
[ 5.259296] iwlwifi 0000:00:08.0: 0x8F59B80B | uCode version minor
[ 5.259369] iwlwifi 0000:00:08.0: 0x00000420 | hw version
[ 5.259433] iwlwifi 0000:00:08.0: 0x18489002 | board version
[ 5.259510] iwlwifi 0000:00:08.0: 0x8005FC00 | hcmd
[ 5.259570] iwlwifi 0000:00:08.0: 0x00020000 | isr0
[ 5.259630] iwlwifi 0000:00:08.0: 0x00000000 | isr1
[ 5.259688] iwlwifi 0000:00:08.0: 0x48F00002 | isr2
[ 5.259748] iwlwifi 0000:00:08.0: 0x00C0000C | isr3
[ 5.259808] iwlwifi 0000:00:08.0: 0x00000000 | isr4
[ 5.259867] iwlwifi 0000:00:08.0: 0x00000000 | last cmd Id
[ 5.259976] iwlwifi 0000:00:08.0: 0x004D9A0A | wait_event
[ 5.260038] iwlwifi 0000:00:08.0: 0x00000000 | l2p_control
[ 5.260100] iwlwifi 0000:00:08.0: 0x00000000 | l2p_duration
[ 5.260161] iwlwifi 0000:00:08.0: 0x00000000 | l2p_mhvalid
[ 5.260221] iwlwifi 0000:00:08.0: 0x00000000 | l2p_addr_match
[ 5.260294] iwlwifi 0000:00:08.0: 0x00000009 | lmpm_pmg_sel
[ 5.260355] iwlwifi 0000:00:08.0: 0x00000000 | timestamp
[ 5.260416] iwlwifi 0000:00:08.0: 0x00000020 | flow_handler
[ 5.260541] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 5.260602] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 7
[ 5.260678] iwlwifi 0000:00:08.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 5.260751] iwlwifi 0000:00:08.0: 0x00000000 | umac branchlink1
[ 5.260825] iwlwifi 0000:00:08.0: 0x8045E20E | umac branchlink2
[ 5.260900] iwlwifi 0000:00:08.0: 0x8047FD96 | umac interruptlink1
[ 5.261028] iwlwifi 0000:00:08.0: 0x8047FD96 | umac interruptlink2
[ 5.261104] iwlwifi 0000:00:08.0: 0x01000000 | umac data1
[ 5.261166] iwlwifi 0000:00:08.0: 0x8047FD96 | umac data2
[ 5.261229] iwlwifi 0000:00:08.0: 0x00000000 | umac data3
[ 5.261289] iwlwifi 0000:00:08.0: 0x00000043 | umac major
[ 5.261350] iwlwifi 0000:00:08.0: 0x8F59B80B | umac minor
[ 5.261410] iwlwifi 0000:00:08.0: 0x000611AD | frame pointer
[ 5.261485] iwlwifi 0000:00:08.0: 0xC088625C | stack pointer
[ 5.261556] iwlwifi 0000:00:08.0: 0x00000000 | last host cmd
[ 5.261629] iwlwifi 0000:00:08.0: 0x00000400 | isr status reg
[ 5.261736] iwlwifi 0000:00:08.0: IML/ROM dump:
[ 5.261796] iwlwifi 0000:00:08.0: 0x00000B03 | IML/ROM error/state
[ 5.261903] iwlwifi 0000:00:08.0: 0x0000772B | IML/ROM data1
[ 5.262060] iwlwifi 0000:00:08.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 5.262163] iwlwifi 0000:00:08.0: Fseq Registers:
[ 5.262248] iwlwifi 0000:00:08.0: 0x60000100 | FSEQ_ERROR_CODE
[ 5.262347] iwlwifi 0000:00:08.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 5.262446] iwlwifi 0000:00:08.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 5.262545] iwlwifi 0000:00:08.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 5.262644] iwlwifi 0000:00:08.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 5.262745] iwlwifi 0000:00:08.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 5.262842] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVI_ID
[ 5.262963] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVR_ID
[ 5.263051] iwlwifi 0000:00:08.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 5.263154] iwlwifi 0000:00:08.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 5.263253] iwlwifi 0000:00:08.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 5.263368] iwlwifi 0000:00:08.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 5.858163] iwlwifi 0000:00:08.0: Failed to run INIT ucode: -110
[ 5.871105] iwlwifi 0000:00:08.0: retry init count 1
[ 5.871769] iwlwifi 0000:00:08.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 6.085316] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[ 6.085353] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[ 6.085380] iwlwifi 0000:00:08.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[ 6.490413] iwlwifi 0000:00:08.0: Timeout waiting for PNVM load!
[ 6.490447] iwlwifi 0000:00:08.0: Failed to start RT ucode: -110
[ 6.490473] iwlwifi 0000:00:08.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.491614] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 6.491666] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 6
[ 6.491697] iwlwifi 0000:00:08.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[ 6.491734] iwlwifi 0000:00:08.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 6.491756] iwlwifi 0000:00:08.0: 0x002082F0 | trm_hw_status0
[ 6.491777] iwlwifi 0000:00:08.0: 0x00000000 | trm_hw_status1
[ 6.491798] iwlwifi 0000:00:08.0: 0x004DAC6A | branchlink2
[ 6.491816] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink1
[ 6.491837] iwlwifi 0000:00:08.0: 0x004D108E | interruptlink2
[ 6.491858] iwlwifi 0000:00:08.0: 0x004D9A0A | data1
[ 6.491874] iwlwifi 0000:00:08.0: 0x01000000 | data2
[ 6.491891] iwlwifi 0000:00:08.0: 0x00000000 | data3
[ 6.491909] iwlwifi 0000:00:08.0: 0x00000000 | beacon time
[ 6.491940] iwlwifi 0000:00:08.0: 0x0005021C | tsf low
[ 6.491957] iwlwifi 0000:00:08.0: 0x00000000 | tsf hi
[ 6.491974] iwlwifi 0000:00:08.0: 0x00000000 | time gp1
[ 6.491991] iwlwifi 0000:00:08.0: 0x00062391 | time gp2
[ 6.492010] iwlwifi 0000:00:08.0: 0x00000001 | uCode revision type
[ 6.492032] iwlwifi 0000:00:08.0: 0x00000043 | uCode version major
[ 6.492052] iwlwifi 0000:00:08.0: 0x8F59B80B | uCode version minor
[ 6.492074] iwlwifi 0000:00:08.0: 0x00000420 | hw version
[ 6.492093] iwlwifi 0000:00:08.0: 0x18489002 | board version
[ 6.492113] iwlwifi 0000:00:08.0: 0x8005FC00 | hcmd
[ 6.492131] iwlwifi 0000:00:08.0: 0x20028000 | isr0
[ 6.492148] iwlwifi 0000:00:08.0: 0x00000000 | isr1
[ 6.492166] iwlwifi 0000:00:08.0: 0x48F00002 | isr2
[ 6.492183] iwlwifi 0000:00:08.0: 0x00C0000C | isr3
[ 6.492289] iwlwifi 0000:00:08.0: 0x00000000 | isr4
[ 6.492307] iwlwifi 0000:00:08.0: 0x00000000 | last cmd Id
[ 6.492324] iwlwifi 0000:00:08.0: 0x004D9A0A | wait_event
[ 6.492342] iwlwifi 0000:00:08.0: 0x00000000 | l2p_control
[ 6.492359] iwlwifi 0000:00:08.0: 0x00000000 | l2p_duration
[ 6.492511] iwlwifi 0000:00:08.0: 0x00000000 | l2p_mhvalid
[ 6.492529] iwlwifi 0000:00:08.0: 0x00000000 | l2p_addr_match
[ 6.492560] iwlwifi 0000:00:08.0: 0x00000009 | lmpm_pmg_sel
[ 6.492593] iwlwifi 0000:00:08.0: 0x00000000 | timestamp
[ 6.492611] iwlwifi 0000:00:08.0: 0x00000020 | flow_handler
[ 6.492669] iwlwifi 0000:00:08.0: Start IWL Error Log Dump:
[ 6.492687] iwlwifi 0000:00:08.0: Transport status: 0x00000042, valid: 7
[ 6.492709] iwlwifi 0000:00:08.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 6.492731] iwlwifi 0000:00:08.0: 0x00000000 | umac branchlink1
[ 6.492752] iwlwifi 0000:00:08.0: 0x8045E20E | umac branchlink2
[ 6.492772] iwlwifi 0000:00:08.0: 0x8047FD96 | umac interruptlink1
[ 6.492793] iwlwifi 0000:00:08.0: 0xC00821D6 | umac interruptlink2
[ 6.492814] iwlwifi 0000:00:08.0: 0x01000000 | umac data1
[ 6.492832] iwlwifi 0000:00:08.0: 0xC00821D6 | umac data2
[ 6.492849] iwlwifi 0000:00:08.0: 0x00000000 | umac data3
[ 6.492866] iwlwifi 0000:00:08.0: 0x00000043 | umac major
[ 6.492883] iwlwifi 0000:00:08.0: 0x8F59B80B | umac minor
[ 6.492901] iwlwifi 0000:00:08.0: 0x000624EA | frame pointer
[ 6.492935] iwlwifi 0000:00:08.0: 0xC0887EF4 | stack pointer
[ 6.492956] iwlwifi 0000:00:08.0: 0x00000000 | last host cmd
[ 6.492977] iwlwifi 0000:00:08.0: 0x00000404 | isr status reg
[ 6.493017] iwlwifi 0000:00:08.0: IML/ROM dump:
[ 6.493034] iwlwifi 0000:00:08.0: 0x00000B03 | IML/ROM error/state
[ 6.493073] iwlwifi 0000:00:08.0: 0x00007693 | IML/ROM data1
[ 6.493113] iwlwifi 0000:00:08.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 6.493150] iwlwifi 0000:00:08.0: Fseq Registers:
[ 6.493180] iwlwifi 0000:00:08.0: 0x60000100 | FSEQ_ERROR_CODE
[ 6.493213] iwlwifi 0000:00:08.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 6.493252] iwlwifi 0000:00:08.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 6.493286] iwlwifi 0000:00:08.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 6.493319] iwlwifi 0000:00:08.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 6.493575] iwlwifi 0000:00:08.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 6.493600] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVI_ID
[ 6.493630] iwlwifi 0000:00:08.0: 0x00400410 | FSEQ_CNVR_ID
[ 6.493660] iwlwifi 0000:00:08.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 6.493695] iwlwifi 0000:00:08.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 6.493730] iwlwifi 0000:00:08.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 6.493771] iwlwifi 0000:00:08.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7.149124] iwlwifi 0000:00:08.0: Failed to run INIT ucode: -110
[ 7.171047] iwlwifi 0000:00:08.0: retry init count 2
Any ideas on what’s wrong and/or how it can be solved will be appreciated.
Thanks,
George
