Hit:1 Index of /debian bullseye InRelease
Hit:2 https://deb.debian.org/debian-security bullseye-security InRelease
Get:3 Index of /deb/r4.1/vm/ bullseye InRelease [2,150 B]
Err:3 Index of /deb/r4.1/vm/ bullseye InRelease
The following signatures were invalid: EXPKEYSIG A8F7A1DC99F29DAA Qubes OS Contrib Release 4 Signing Key
Hit:4 Index of /r4.1/vm/ bullseye InRelease
Hit:5 Index of /r4.1/vm/ bullseye-testing InRelease
Hit:6 Index of /r4.1/vm/ bullseye-securitytesting InRelease
Reading package lists⦠Done
W: GPG error: Index of /deb/r4.1/vm/ bullseye InRelease: The following signatures were invalid: EXPKEYSIG A8F7A1DC99F29DAA Qubes OS Contrib Release 4 Signing Key
E: The repository āIndex of /deb/r4.1/vm/ bullseye InReleaseā is not signed.
N: Updating from such a repository canāt be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
sudo gpg -v /etc/blablablabla ⦠key expired on the 25th of this month
its the default debian 10 template that i updated to debian 11 and i used sudo apt update to get this. i added the contrib repos through the CLI commands that the documentation tells
works fine for debian buster and bullseye repos works fine for fedora34 repos and works fine for dom0 repos
contrib repos work fine in fedora34 and dom0 templates
only thing that isnāt working is the contrib repos for debian , both the buster and bullseye repos say the same thing for the contrib repos⦠that theyāre unsigned
when i check wthe gpg key for them it says the key expired on september 25
and yes im trying to use sudo apt update in the temple vm
How do I correctly update the keys for contrib repo?
I downloaded the new qubesos-contrib-release-4-debian.asc. key, and gpg imported the file to /etc/apt/trusted.gpg.d/qubesos-contrib-release-4.0-debian.gpg. When running sudo apt-get update (even though I know not recommended in Template Debain-11), I get the following error:
With the bullseye-testing repository enabled in /etc/apt/sources.list.d/qubes-r4.list, you can run sudo apt update; sudo apt install qubes-repo-contrib to install the new key. (Then bullseye-testing can be disabled again.)
i donāt know how to update the repo, i have searched for hour, i can find a solution, the only generic solution that i find was update the keyā¦or some generic info on debian when the apt-key was marked as non correct metod, iām tring to add de qubes-repo-contib on debian-11 tp clone on qubes r4 ā¦can please some one give instruction? thank you
