Hello everybody! At times I can be pretty long-winded, and especially now when I got a lot of time on my hands due to the lockdown in my country. So if you feel like it, just scroll down to the last two paragraphs of this posts.
So, since I was still using 3.x after it went EOL I figured it was time to buy new hardware that could run 4.x. The hardware I bought is:
Asus Prime B460M-A motherboard
Intel Core i5-10500 processor
Asus TPM-SPI card
16GB of memory
and two 250GB NVME drives
The reason it has two hard drives is because I want to make it a dual boot system with bare metal Windows and Qubes.
When I tried to install Windows for the first time the computer crashed…
After the computer rebooted the Windows installer said there was an error, but if I would connect the LAN cable it could download something that would probably fix the error, and it did.
Don’t know if this has any relevance, but it certainly was something I had never seen before.
I also was not able to reproduce the error, so not sure what the message was exactly.
Anyway, Windows is now installed with all the correct drivers for the hardware and Bitlocker is enabled using the TPM (can be disabled if necessary, just enabled it for test purposes).
So, now the real fun started. I have used the freshly installed Windows to download and verify the Qubes 4.0.3 ISO, and I have used Rufus (in DD Image mode) to copy the ISO onto a USB drive. After errors occurred during the installation of Qubes I pulled a very old laptop out of the closet. This laptop is running Antix (based on Debian Stable) and I used the laptop to again download and verify the Qubes 4.0.3 ISO, and used dd to copy the ISO onto a USB drive. In the end I used four different USB drives (Kingston DT50 8GB, Kingston DTM30 16GB, Kingston DTM30 64GB, Transcend Jetflash 780 8GB) but still the same errors occur during the installation of Qubes.
I found out that there is a difference when I preform an UEFI boot or a legacy boot. When preforming an UEFI boot it always crashes with a fatal page fault. I copied the information of the boot screen by hand, so there could be some errors due to copying.
Xen 4.8.5-14.fc25 (c/s ) EFI loader
Using configuration file 'BOOTX64.cfg'
vmlinuz: 0x000000006c55f000-0x000000006cbaaca0
initrd.img: 0x000000006b192000-0x000000006c55ab1c
0x0000:0x04:0x00.0x0: ROM: 0xe000 bytes at 0x62d03018
(XEN) ACPI: Invalid sleep control/status register data: 0:0x8:0x3 0:0x8:0x3
(XEN) ACPI: 32/64X FACS address mismatch in FADT - 88e52000/0000000000000000, using 32
(XEN) IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
(XEN) Enabling APIC mode: Phys. Using 1 I/O APICs
(XEN) Switched to APIC driver x2apic_cluster.
(XEN) xstate: size 0x440 and states 0x1f
(XEN) Unrecognised CPU model 0xa5 - assuming not reptpoline safe
(XEN) Unrecognised CPU model 0xa5 - assuming vulnerable to LazyFPU
(XEN) Speculative mitigation facilities:
(XEN) Hardware features: IBRS/IBPB STIBP L1D_FLUSH SSBD MD_CLEAR IBRS_ALL RDCL_NO SKIP_L1DFL MDS_NO
(XEN) Compiled-in support: INDIRECT_THUNK
(XEN) Xen settings: BTI-Thunk JMP, SPEC_CTRL: IBRS+ SSBD-, Other: IBPB
(XEN) Support for VMs: PV: MSR_SPEC_CTRL RSB EAGER_FPU MD_CLEAR HVM: MSR_SPEC_CTRL RSB EAGER_FPU MD_CLEAR
(XEN) XPTI (64-bit PV only): Dom0 disabled, DomU disabled
(XEN) PV L1TF shadowing: Dom0 disabled, DomU disabled
(XEN) Using scheduler: SMP Credit Scheduler (credit)
(XEN) Platform timer is 23.999MHz HPET
(XEN) Detected 3096.216 MHz processor.
(XEN) Unknown cachability for MFNs 0xa0-0xff, assuming UC
(XEN) Unknown cachability for MFNs 0x4f000-0x8f7ff, assuming UC
(XEN) Initing memory sharing.
(XEN) CPU0: No irq handler for vector 6c (IRQ -2147483648, LAPIC)
(XEN) Intel VT-d iommu 0 supported page sizes: 4kB, 2MB, 1GB.
(XEN) Intel VT-d iommu 1 supported page sizes: 4kB, 2MB, 1GB.
(XEN) Intel VT-d Snoop Control not enabled.
(XEN) Intel VT-d Dom0 DMA Passthrough not enabled.
(XEN) Intel VT-d Queued Invalidation enabled.
(XEN) Intel VT-d Interrupt Remapping enabled.
(XEN) Intel VT-d Posted Interrupt not enabled.
(XEN) Intel VT-d Shared EPT tables enabled.
(XEN) I/O virtualisation enabled
(XEN) - Dom0 mode: Relaxed
(XEN) Interrupt remapping enabled
(XEN) Enabled directed EOI with ioapic_ack_old on!
(XEN) ENABLING IO-APIC IRQs
(XEN) -> Using old ACK method
(XEN) ----[ Xen-4.8.5-14.fc25 x86_64 debug=n Not tainted ]----
(XEN) CPU: 0
(XEN) RIP: e008:[<0000000089ee3d2a>] 0000000089ee3d2a
(XEN) RFLAGS: 0000000000010046 CONTEXT: hypervisor
(XEN) rax: 00000000fed00000 rbx: ffff82d080827c90 rcx: 0000000000000000
(XEN) rdx: 0000000000001830 rsi: 0000000089ec00e0 rdi: 0000000000000000
(XEN) rbp: 0000000089ec0140 rsp: ffff82d080827bd8 r8: 0000000089ee7bf8
(XEN) r9: ffff82d080827cff r10: ffff82d080827dff r11: 0000000000000000
(XEN) r12: ffff82d0808586a0 r13: 0000000000001830 r14: 00000000000fd0dc
(XEN) r15: ffff82d080806615 cr0: 0000000080050033 cr4: 00000000003506e0
(XEN) cr3: 00000004602f2000 cr2: 00000000fed00010
(XEN) fsb: 0000000000000000 gsb: 0000000000000000 gss: 0000000000000000
(XEN) ds: 0000 es: 0000 fs: 0000 gs: 0000 ss: 0000 cs: e008
(XEN) Xen code around <0000000089ee3d2a> (0000000089ee3d2a)
(XEN) 36 48 8b 05 c6 3e 00 00 <48> 8b 40 10 48 89 44 24 08 48 89 05 4e 4d 00 00
(XEN) Xen stack trace from rsp=ffff82d080827bd8:
(XEN) 0000000089edc6f9 0000000089ec0101 ffff010089ebe37d ffff82d080214726
(XEN) 0000000000000000 ffff82d0802147ef ffff82d0802147fb 0000000000000000
(XEN) 0000000089ebe785 ffff82d080827cb0 0000000000000000 00000000000002aa
(XEN) 0000000000000286 ffff82d080827c80 ffff82d080806e00 ffff82d0808066e0
(XEN) 000000000000000b 0000000000000206 ffff82d080817ef8 0000000000000206
(XEN) ffff82d080211641 ffff82d0802147ef ffff82d080827cc0 0000000000000003
(XEN) ffff82d080827d10 0000000000000000 0000000000000000 ff282d150d0107e5
(XEN) 0000000000000000 0000000000416000 ffff82d0808066e0 000000000000000b
(XEN) 0000000000000000 000000000003a981 0000000000000200 00000006e6fb2a56
(XEN) ffff82d080827d40 ffff82d0808586a0 ffff82d080827fff ffff83046390ffe0
(XEN) ffff82d0801886ed 0000000000000838 0000000000000000 0000000000000000
(XEN) ffff82d0801886ed 000000f000000000 ffff82d08061d182 000000000000e008
(XEN) 0000000000000206 ffff82d080827d70 00000006e6fb2a56 ffff83046390ffe0
(XEN) ffff82d0808586a0 ffff82d080827fff 000000000000000b ffff82d0808066e0
(XEN) ffff82d08062c152 ffff82d0808586a0 ffff82d080627fb3 ffff83006d252e80
(XEN) ffff83006d252220 00007d0000000002 ffff83006d23fd6b 00000000024ca000
(XEN) ffff82d08064f7e0 0000000000000000 0000003a00000000 0000000004fe4000
(XEN) 000000000046f800 ffff82d080000000 ffff82d080000000 0000000000000000
(XEN) 0000000000000002 0000000000000002 0000000000000002 0000000000000003
(XEN) 0000000000000003 0000000000000004 0000000000000004 0000000000000005
(XEN) Xen call trace:
(XEN) [<0000000089ee3d2a>] 0000000089ee3d2a
(XEN) [<ffff82d080214726>] int80_direct_trap+0x116/0x11d
(XEN) [<ffff82d0802147ef>] common-interrupt+0x8f/0x120
(XEN) [<ffff82d0802147fb>] common-interrupt+0x9b/0x120
(XEN) [<ffff82d080211641>] efi_get_time+0x71/0xc0
(XEN) [<ffff82d0801886ed>] time.c#get_cmos_time+0x1cd/0x2a0
(XEN) [<ffff82d08061d182>] setup_boot_APIC_clock+0x132/0x2d0
(XEN) [<ffff82d08062c152>] init_xen_time+0xa2/0x140
(XEN) [<ffff82d080627fb3>] __start_xen+0x2473/0x3650
(XEN)
(XEN) Pagetable walk from 00000000fed00010:
(XEN) L4[0x000] = 00000004602f1063 ffffffffffffffff
(XEN) L3[0x003] = 000000006d411063 ffffffffffffffff
(XEN) L2[0x1f6] = 00000004602f4063 ffffffffffffffff
(XEN) L1[0x100] = 0000000000000000 ffffffffffffffff
(XEN)
(XEN) ****************************************
(XEN) Panic on CPU 0:
(XEN) FATAL PAGE FAULT
(XEN) [error_code=0000]
(XEN) Faulting linear address: 00000000fed00010
(XEN)
(XEN) Reboot in five seconds...
But the reboot never happens.
When I preform a legacy boot I can see the Qubes OS boot screen and I can start the installation process. But when the process reaches anaconda I’m greeted with the “Not asking for VNC because we don’t have a network” / “X startup failed, aborting installation” error. In anaconda I do have a shell, so I could export log files (if I know where to find them) or the journal. (And probably do even more things I am not aware of.)
I consider myself a pretty tech-savvy guy, but when it comes to Linux I am a novice user at best. So any help installing Qubes would be greatly appreciated.
