All of which suggests that your template is lacking
qubes-core-agent-networking, or is irredeemably broken in some other way.
I’m going to repeat from last week:
Check that the update proxy is set to sys-net (or sys-firewall, as you will)
Check that you do not have a cacher qube or template-cacher.
Check that you are able to update a template.
Check that the template for your management_dispvm is a fedora template (preferably fedora 40)
sudo qubes-dom0-update 3isec-qubes-cacher
I noticed that I can keep running the ‘sudo dnf remove 3isec-qubes-cacher’ in Dom0–the uninstall doesn’t seem to complete. Any tips on how to get it completely uninstalled?
That really isnt helpful - you’ve given no detail which would suggest
what problem you think you see. Nor have you indicated which of the
steps you have taken, and which checks you have made, with what results.
I have already told you how to uninstall the package, and how to roll
back any changes. sudo dnf remove 3isec-qubes-cacher will try to remove the package, and
revert system changes.
Let’s think about what the package does:
It drops salt files in to /srv/salt/cacher
It clones a template, template-cacher, and creates a qube, cacher. (create.sls)
apt-cacher-ng and qubes-core-agent-networking are installed in the template (install.sls)
The cacher qube is configured (configure.sls)
The global preference is set to use cacher as update proxy by editing /etc/qubes/policy.d/50-config-updates.policy
The repository definitions are edited to replace references to https:// with http://HTTPS/// (change_templates.sls)
A salt pillar is created to hold the value for a caching proxy.
sudo dnf remove 3isec-qubes-cacher should roll back 7,6,5 and 1.
You can manually do, and check, this by the steps I have given you.
I assumed that I would only be able to run
sudo dnf remove 3isec-qubes-cacher once. I assumed after it was uninstalled, this command would not run, throw an error, or report that there was nothing to uninstall. I only mentioned this because it seemed like there was some remnant of this package somewhere because this command continues to run.
I installed the fedora-40 template. If uninstalling the package is just those 7 steps I’ll retry.
For whatever reason, the template-cacher TemplateVM the 3isec-qubes-cacher package created from my debian-12-minimal TemplateVM did not have whatever configuration changes the upgrade-template-standalone.sh implements.
I’m pretty sure when I upgraded from Qubes 4.1.2 to 4.2, Stage 4 (Upgrade templates and standalone VMs to R4.2 repository) did complete without errors, so I’m not sure how or why this is an issue now
I discovered this by
Reverting the settings in Dom0’s /etc/qubes/policy.d/50-config-updates.policy so that all @type:TemplateVM will update through my sys-net Qube instead of through cacher
Reverting the cacher https:// prefix in template-cacher’s apt lists sed -i 's^http://HTTPS///^https://^' /etc/apt/sources.list sed -i 's^http://HTTPS///^https://^' /etc/apt/sources.list.d/*.list
Attempting to run apt update and apt upgrade, which surfaced
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xen-utils-guest : Conflicts: xen-hypervisor-common but 4.17.3+10-g091466ba55-1~deb12u1 is to be installed
E: Broken packages
Made it executable and ran it from template-cacher
It seemed to do things and completed without any errors
I was then able to re-revert the settings in Dom0’s /etc/qubes/policy.d/50-config-updates.policy so that all @type:TemplateVM would resume updating through cacher and re-revert the cacher prefix in template-cacher’s apt lists sed -i 's^http://HTTPS///^https://^' /etc/apt/sources.list sed -i 's^http://HTTPS///^https://^' /etc/apt/sources.list.d/*.list
I was then able to update template-cacher and other debian templates through cacher without any issues
